I tried dual opposed and decided it wasn't for me because I lost too much of the feel.
Interesting. I may have experienced a bit of the same.
My dual opposed vented sub (PPSL), is basically two single vented boxes I had built, put into opposition in a single box.
The single vented boxes were a home run, so i duped them in the PPSL by doubling internal box volume and port size.
The leading attack edge of strong bass transients seemed a wee bit less with the PPSL than two stacked singles.
I dunno if that has to do with the nature of the wavefront emanating from the PPSL slot, or perhaps a potential reduction in distortion from the PPSL design.
PPSL stands for either push-push slot loaded, or push-pull slot loaded. Push-push is with the drivers facing each other clam shell, and push-pull is with the motor of one hanging in the slot, facing the cone of the other. (You probably know all that, but for others reading along, thought i should explain.)
Supposedly, push-pull helps cancel out non-linearities and reduce distortion (in addition to the dramatic overall vibration reduction).
So I measured the PPSL both ways, push-push and push-pull. Didn't see any significant distortion difference, but i did hear more motor noise with push-pull with a motor hanging in the slot.
So I've stuck with push-push.
Anyway, getting back to tactile feel.....
Again, i don't know what to think about the leading attack edge of strong bass transients.
I know from a lot of multi-way measurements and listening, that much of what i think is subwoofer transient response, is really full-range response combined with the sub.
And I know that harmonics from a sub are part of the full-range response...giving sub transients some bite, some attack.
The distortion plots of the PPSL were nicely low. Here's plots with processing in place.
SPL was a bit over 125 dB at 1m !
Maybe the cleanliness of the PPSL is reducing some pseudo transient behavior..... i simply dunno.
Never managed to test the single vented boxes for distortion at the same SPL level...hope to someday.
Hey, my favorite tactile feel track is AWOL Nation's "Sail"....that tune rattles nearly every body part when cranked Lol.
Personally, i think bass without tactile feel is not bass......
Oh, one last throw in....the MT-4 pro sound sub i posted a pict of......AC/DC's go-to subs
