You do know a pair of mission LX 3 MK II are ported and rated down to 40hz -6db with a 6.½ midrange/bass unit (think many speakers don't measure as good as they are rated, especially sensitivity and bass something when the bass is down by -6 db), the sub has an 8" woofer and are sealed
Also when the crossover is very low to hear it you need to turn the volume up, and when it's high like 100hz and down the bass have to play a wider range where you might not need to turn it up to hear it as much as when it's from 50hz and down so both could be about the same load, excursion
Finally found it
This is the subwoofer's MAX output, this says nothing about how flat its frequency response is.
so you don't do do anything with sub gain
he does need to do something about it, and that is to match it to the gain of the speakers (and move based on preference from there, usually people like the gain of the subwoofer to be +4dB louder based on Harman research).
For someone who doesn't even have a measurement microphone, I'm kind of happy that he took the initiative to use his ears as microphones, with inaccuracies and all.
Also depens on what i listen to,how deep the bass is and how loud, somewhere i read that most chest pouding beats are not sub bas, just bas, so what most consider chest pounding that many likes at a techno,edm partys (armin van buuren,italobrothers,Gifi D' Agostino,David guetta) is often more 80-120hz than 80hz down to 50hz of course with alot of exceptions, i also like listening to som good jazz with deeper bass than most pop,rock songsI think you're confusing two unrelated thing here. Yes human hearing is less sensitive at 50 Hz than 100 Hz, and so higher SPLs are needed at 50 Hz to sound as loud as at 100 Hz. However, this is already accounted for during music creation and recording so you don't do do anything with sub gain because of this ie. if 50 Hz and 100 Hz notes are intended to sound as loud as each other then the recorded signal level at 50 Hz is higher to achieve this.
When a combination of high and low-pass filters are used to minimise overlap of sound from main speakers and subwoofer then obptimal subwoofer gain is basicially unrelated to crossover frequency. In the situation where there is substantial overlap as you may have, then you may well find you want to adjust the sub gain when you vary the sub crossover frequency, but not because of the reason you described.
There migt be frequencys where bass need to be raised 4 db or lowered. Generally a bass that is more flat down to 40-50 hz is more likely to play the bass how THEY want it to sound, thats why i never use an eq with 2 speakers other than studio monitors, i like how music sounds different, i just think i need to get a minidsp or the DSpeaker Anti-Mode 2.0 Dual Core to optimize the bass, i really don't have to much to adjust the bass with if 120hz down 40hz can't be optimized with a bass control, on most amps often at 100hz, how much under and over 100hz they effect (Q) i don't know.Please don't quote something completely out of context like this. You've either totally missed my point or wildly misrepresented it. Neither is helpful.
What would a good price be for a 2012 DSpeaker Anti-Mode 2.0 Dual Core ?
what fullrange units is there besides the minidsp and the one i found used DSpeaker Anti-Mode 2.0 Dual Core ?
The dayton dsp unit for 82 euros at audiophonics is only for the bass and only offers room correction with an iphone, which i don't own
Anti-Mode 2.0 Dual Core features fully customizable highpass and lowpass filters. I think it's both for the front speakers + the subMy gut reaction is that I wouldn't buy one, since it doesn't offer the same functionality for you as a miniDSP 2x4 HD despite it's higher RRP. In particular it wouldn't allow you to apply a high-pass filter to your main speakers.
It only has two outputs, not four as far as I could see? So you'd need two units to apply both a high pass filter to your main speakers and a low-pass filter to a subwoofer. If you only applied it to your main speaker then you could apply a high-pass filter but not then apply EQ to the most important frequency range that would be covered by the subwoofer.Anti-Mode 2.0 Dual Core features fully customizable highpass and lowpass filters. I think it's both for the front speakers + the sub
No it has 2 pair of in and outputs but you can only use 1 pair of input but 2 outputs rca for the sub and xlr for the ampIt only has two outputs, not four as far as I could see? So you'd need two units to apply both a high pass filter to your main speakers and a low-pass filter to a subwoofer. If you only applied it to your main speaker then you could apply a high-pass filter but not then apply EQ to the most important frequency range that would be covered by the subwoofer.
I do need something that will let me get most (sound quality) out of my mission and the sub or else im afraid i vil have to return the sub and buy different front speakers, i don't think it's possible to get someting cheap (amp) with room correction and time alignment unless i find a good surround receiver
