Hi there. I have a question. I have my studio monitors which are klipsch the sevens. They have a sub output on the back which plugs into my svs pb 2000 pro sub. The sevens have a dsp in them that hard codes the crossover at 60hz. I cannot change this function as it is static set when I plug a sub into its sub out port.
I have my sub in the svs app set to LFE mode. What I wanted to know is, is there anyway I can get my sub to take over duties for the entire 120hz LFE range while using my speakers? I heard that is what a sub is supposed to do is play the entire range of the LFE 120hz. How would that work if my speakers would be playing bass also from 60 to 120hz?
I do not have a AV receiver I just basically have my speakers and the sub connected to each other. I am running this on a desktop pc.
Thanks for the help!!!
