Subwoofer Time Alignment
waynel
Read through this thread with interest and have a basic question:
Assuming that the sub phase and level are adjusted properly to give a smooth frequency response (and then perhaps smoothed out further with DSP room correction) , does time alignment matter? Is there any evidence that the effect of time alignment over what can be represented in a frequency response plot is audible?
Thanks
Wayne
ernestcarl
Ok, I see. Can you plz repeat these 4 measurements, this time with 50-130Hz sweep and add 4ms delay to the mains.
I presume you still wanted to keep the 'acoustic timing reference' channel output set to 0ms so I did just that.
4ms was added only to the channel actually being measured while the reference channel remained set to 0ms.
e.g.
REW's timing delay calculation all fall under 0ms with the fronts set to 4ms delay.
I suppose you could say the phase restricted between 80-100Hz looks better matched...
Not quite so below that though.
  • 30Hz - 150Hz No xo - 4ms delay fronts - 0ms acoustic timing ref.zip
dasdoing
Salvador-Bahia-Brasil
QMuse
e.g.
Well, this looks much better, so let's do the XO work and we'll fine tune phase later if necessary. :)
Set XO point on your sub at 80Hz, leave phase at 0.
Leave 4ms delay on both mains.
Set XO for mains at 80Hz on the high pass filtr like shown on the pic, except use LR24, not BW.
Bypass the low pass filter as shown on the pic.
Make 0-20kHz sweep of your left channel (that would now mean left+sub) without timing reference. Make the same for right channel.
ernestcarl
All drivers summed and using the original xo AND conventional LR4 at 80Hz using different delays:
neon green and cyan are Left and/or Right only with sub.
I'd say from these plots, the original delay of 13ms looks the flattest and most even i.e. still the best compromise?
Back to where I started, I guess.
QMuse
Let's stick to the standard procedure how this is done and do things step by step. Can you plz post those 2 sweeps I asked in my previous post?
Also, be sure to setup XO on the SW side and on the miniDSP side as I described.
QMuse
You're right with the 13ms, I aligned impulse responses wrongly. :facepalm:
Here's the overlay of the IRs with delay set to 0.
As you can see main highest peak is at 1ms and SW highest peak is at 14ms, hence mains should be delayed by 13ms. So plz set delay to 13ms and measure again both channels with sweeps.
ernestcarl
Here you go.
  • L-R 13ms delay original xo.zip
QMuse
Here you go.
Something is still not right. Are you sure you're using 80Hz XO at SW side and LR24 at 80Hz with HP filter at mains side with miniDSP? Can you also check that all other XO parameters are disabled in miniDSP, especially LP filter on mains channels and all filters on SW channel?
ernestcarl
Oh, you meant using 80Hz LR4 with 13ms delay...
The attached measurements are using the above settings.
  • L-R 13ms delay 80Hz xo.zip
ernestcarl
In case it may be of importance, I used 512k length for these and not 2M setting in REW.
ernestcarl
Something I don't know how to explain though is the ff:
The step for the sub in the drivers summation looks as though it has moved forward in time when all settings are, in fact, the same, only xo has been changed.
QMuse
No, that is not what I meant. Both of those filters on the channel 4 driving sub should be bypassed and XO on sub should be set at 80Hz using XO knob on the rear panel of the sub.
On both channels driving mains you should enable high pass at 80Hz with LR24db/oct and disable low pass (as I showed on the picture I posted few posts earlier).
Also, please always use 2M sweep length.
QMuse
Something is horribly wrong here. I suggest you remove all filters (PEQ and FIR) from miniDSP. Plz leave only high pass LR24 filter at 80Hz with channels 1 & 2 which are driving your mains. Bypass HP and LP filter at channel 4 which is driving your sub. Leave also delay setting for the mains.
80Hz XO point for the sub should be configured at the sub as you can't turn it off.
Do you have the possibility to invert polarity of the mains within miniDSP?
QMuse
This is what I think you should do:
- remove all filters (PEQ and FIR) from miniDSP
- enable high pass LR24 filter at 80Hz with channels 1 & 2 which are driving your mains, bypass low pass filter on these channels
- set delay to 10ms for mains
- bypass HP and LP filters at channel 4 which is driving your sub
- invert polarity of channel 4 driving your sub
- 80Hz XO point for the sub should be configured at the sub
Use 2M sweeps in the 50-110Hz range to measure left and right channel, without timing reference.
ernestcarl
Polarity can be easily changed within miniDSP, yes.
I have not been using FIR filters only ordinary PEQs. Pretty sure the ff. L&R + sub measurements are as you requested.
  • L-R 10ms delay no EQ.zip
ernestcarl
I know what the discrepancy now is, QMuse. The left monitor's internal 60Hz 12dB/oct HP has been enabled all this while!:facepalm:
Must have forgotten to turn it off when doing tests some days before... I'll get back to this. Will just have to confirm other things!
*60Hz
waynel
QMuse
Uh, we don't seem to understand each other. Low pass filter at channel 4 should also be bypassed:
Instead of it you should be using XO point at 80Hz set on the sub here:
Please do that an than run 0-20khz sweep on the left and right channel without timing reference.
