Ran some more measurements today from scratch and used both an LFE signal and standard 60hz signal via REW. Interestingly the RCA and XLR outs on this are around the same voltage, maybe that is because there is 1 XLR out for SW1 and then 2 RCA outs for SW2 and SW3 so they wanted to keep them consistent?
Executive summary
The AT-600 produced approximately 10–11 dB higher subwoofer output for dedicated LFE than for redirected right-channel bass in the matched 60 Hz REW checks. RCA and differential XLR subwoofer outputs were nearly equal at those test levels. Earlier higher-level tests showed visible waveform flattening near 4.3 Vrms, with clean-looking waveforms just below that level; this is an observed threshold in the tested setup, not a universal rated maximum.
1. Matched 60 Hz subwoofer tests: LFE vs redirected bass
| Signal path | RCA Vrms | XLR Vrms | RCA Vpp | XLR Vpp |
| Dedicated LFE | 0.46 V | 0.47 V | 1.29 V | 1.32 V |
| Redirected R-channel bass | 0.14 V | 0.13 V | 0.39 V | 0.38 V |
| LFE advantage | +10.33 dB | +11.16 dB | — | — |
Method: 60 Hz REW tone, identical processor settings within each paired comparison; only the oscilloscope vertical scale was changed (1 V/div vs 200 mV/div). The XLR measurement was described as differential across pins 2 and 3 using a battery-powered FNIRSI DSO-TC3. Values are instrument display readings, rounded to two decimals.
Interpretation: Both paths are consistent with the nominal +10 dB LFE playback-gain convention. The 0.83 dB difference between the two calculated advantages is plausibly influenced by rounding and measurement uncertainty; it is not evidence of a meaningful RCA/XLR processing difference.
2. RCA versus XLR at matched levels
| Signal | RCA | XLR | XLR relative to RCA |
| Dedicated LFE | 0.46 Vrms | 0.47 Vrms | +0.19 dB |
| Redirected bass | 0.14 Vrms | 0.13 Vrms | −0.64 dB |
Conclusion: Measured output levels are effectively similar in these tests. This does not establish identical noise performance, output impedance, common-mode rejection, or maximum unclipped level for the two connectors.
3. Higher-output / clipping observations
| Recorded observation | Vrms | Vpp | Assessment |
| Earlier 60 Hz trace | 4.14 V | 11.71 V | Waveform close to upper range |
| Earlier 60 Hz trace | 4.16 V | 11.74 V | Waveform close to upper range |
| AT-600 master 0, trim −6 dB | 4.16 V | 11.74 V | No obvious flat top in supplied image |
| AT-600 master +1, trim −6 dB | 4.27 V | 12.05 V | Visible clipping reported |
| AT-600 master +4, trim −10 dB | 4.13 V | 11.68 V | Upper-range trace |
| AT-600 master +5, trim −10 dB | 4.28 V | 12.10 V | Visible clipping reported |
| RCA example at master 0 | 4.01 V | 11.32 V | Reported clean |
| RCA example at master +1 | 4.01 V | 11.33 V | Flattened waveform visible |
Important: The final two RCA traces demonstrate that RMS voltage can remain nearly unchanged while clipping becomes more pronounced. Consequently, the scope waveform is more informative than Vrms alone near the limit. The table combines tests from different configurations; it must not be interpreted as a single controlled voltage sweep. The source/connector for every historical trace cannot be independently verified from the available record.
4. PC/REW versus Blu-ray source testing
| Source / signal | What was established | Limitation |
| PC running REW | 60 Hz subwoofer tests and clipping checks documented; matched LFE/redirected comparisons completed. | Exact PC output level and signal-chain gain settings not fully captured. |
| Blu-ray test disc | 60 Hz subwoofer track (track 17) and front-channel track (track 5) were used in earlier AT-600 measurements. | A matched numeric PC-versus-Blu-ray voltage comparison cannot be reconstructed reliably from the visible readings. |
No numeric PC-versus-Blu-ray gain conclusion is asserted here because source levels, test tracks, master volume, trims and measured connector must be matched before a defensible comparison can be made.
5. Practical conclusions
LFE gain: confirmed approximately +10–11 dB relative to redirected bass for the matched 60 Hz tests.
Connector level: RCA and differential XLR were approximately equal at the low-level comparison points.
Clipping: waveform flattening was observed in the higher-output tests around 4.0–4.3 Vrms, depending on configuration; do not treat 4.28 Vrms as a guaranteed clean output.
Remaining optional validation: a carefully level-matched PC-versus-Blu-ray comparison, or a separate controlled maximum-clean-voltage sweep for each connector, only if those distinctions matter for system setup.
