If you're trying REW, instead of a fully automated solution like Dirac, I will also suggest Autoeq + Peace (UI on top of autoeq, 2 separate downloads) since you're on Windows platform.
And obviously every room affects sound differently, but from what I've learnt when trying to eq my own systems:
1. First figure out from published specs / measurements, what is the shape of the sub's bass response, example an upward sloping bass to 40-50hz or a more uniform distribution, and if there's a switch to change it. They may call it 'music' mode or 'home theater' mode. Of course the sub will behave differently in your room but it's good background knowledge.
2. Depending on whether you connect the sub to your aiyima amp or to the computer directly, you might need to set up things differently.
If connecting the sub to the pc, you'll need to configure your soundcard to be in 5.1 / 7.1 as Windows doesn't have a specific 2.1 configuration. Your soundcard software might notify and auto setup for you or it might not when you connect your sub. And you might then find that you can output audio when testing the .1 channel with your soundcard, but nothing gets played through your sub. That's because your specific software (YouTube on chrome browser, Spotify etc) is outputting stereo audio stream with nothing going to the sub.
That's where auto eq / peace comes in (other than the regular eq functions). You'll need to configure it to send the stereo mix to your sub. Only then will there be audio. I'll add a picture of the peace interface later.
3. IMO as more of a hobbyist, I've narrowed down why we need to EQ the sub to 3 interrelated points:
- a. Get as much usable output as possible below 40-50hz
- b. Fix room modes
- c. Integrate sub to speakers smoothly
Personally, after I realised that these are my goals, looking at the measured frequency response made much more sense and I'm not blindly attacking every peak I see.
- 3a. Get as much usable output as possible below 40-50hz
No 50hz is not a magical number. But generally the affordable 8-12" subs roll off beyond that. Depending on your room, you might find that when you increased the sub volume the bass peaks are rattling your furniture excessively / too boomy. It could be that the subwoofer maker designed the sub to peak at 40-50hz and then drops off, so it's especially loud there relative to the other frequencies. Though maybe your Revel will not have this issue. Or that your room geometry is somehow boosting that region.
So my goal here is simple: I want to turn up my sub to the max volume it can withstand, WITHOUT the sub or my other furniture rattling to bits, to get that sweet sub-bass. And the more usable volume I can get means the more headroom I have, since I can EQ down the sub to match the speakers.
And you don't need to always EQ at the max volume, do it at a sufficiently loud but comfortable level to you and your family.
There are tons of content on this subject by real experts so you should check them out. As others have mentioned, it's hard to tackle nulls due to room modes without a second sub. But depending on the severity of the nulls, you also might not detect a difference when actually listening to music, or you might get away with a 3-6db boost in that region without too much added distortion, assuming your sub has the headroom.
- 3c. Integrate sub to speakers smoothly (aka digital crossover between sub / speakers)
This is where you need to read up a bit on high pass and low pass filters for your sub and speakers. Again tons of content by actual experts.
For LPF / HPF adjustments, what I do is focus on the 80hz to 150hz region (in the video below). If you can clearly hear the volume dropping off then becoming louder again (or the reverse), that means you have a null or peak and you might want to tweak the LPF / HPF so that you can get a smoothly transitioning sweep as the playback transitions from your sub to your speakers.
Note also that the sub's orientation / placement can affect how the transition sounds like, and for a lot of subs they have a phase switch. For example, you might find that no matter how you tweaked your LPF / HPF there's always a null in the crossover. Changing the phase on the sub can improve the result.
Finally, another key concern you might have that will affect how you adjust the transition, is if the LPF for your sub is set too high (sub roll-off too gradual), you might hear too much human vocals from your sub. This frequently happens in closely mic'ed, talking head videos in studios where bass in vocals is emphasized, and you end up with 'humming' bassy voices which can be irritating. This is where a null in the transition can be preferable.
With REW, you can easily generate a range of frequencies to test with. But because I almost always have the browser on, I often find it easier to search and use the excellent frequency sweeps on YouTube.
For sub testing, just look for the 20 - 200hz videos. You'll hear the volume changes as the frequencies play. You should be able to identify the general nulls and peaks from hearing them alone. EQ them so that you can get a smoothly transitioning sweep (ideally higher volume as frequencies get lower), and your job is done. No point trying to get every frequency perfect if you cannot hear the difference, at least in my opinion.
