Subwoofer Comparison
sweetchaos
The Curator
BC, Canada
I've created a *slightly large* subwoofer comparison spreadsheet. :D
Info:
Do you wish to purchase a new subwoofer, but unsure of what to buy?
You've come to the right place!
How do you judge a subwoofer's performance?
-Read the 'flowery' words on the manufacturer's website?
-Listen to the personal opinion of owners who sing you songs of their subwoofer's performance, regardless of their actual performance?
-Watch some random YouTuber talk about how "good" a subwoofer is, not realizing that he probably got the subwoofer for free, in order to do the review?
-Read some ad-copy on some random website you found, that just lists the specifications and shows an affiliate link at the end?
None of the above! ;)
Instead, we need a consistent way to compare two subwoofers to each other.
That's why international standards like CEA-2010 exist.
What is CEA-2010?
CEA-2010 is an industry standard first published in 2006 (updated as CEA-2010-A in 2012) that specifies a method for measuring subwoofer's maximum SPL (before subwoofer distorts) at various frequencies.
CEA-2010-B was later published.
CEA-2010 was later changed to CTA-2010. But in this guide I'm referring to the original name (CEA-2010), to make things simple.
What's the difference between CEA-2010-A and CTA-2010-B?
They are completely different tests with different distortion thresholds, and therefore, you cannot compare CEA-2010-A with CTA-2010-B tests.
Who's currently testing subwoofers using CEA-2010-A method, and how frequent?
1. Brent Butterworth => Quarterly to monthly
2. Data-bass.com (site maintained by Josh Ricci, Kyle Keating) => Stopped, no more testing.
3. Audioholics.com (James Larson currently, and Josh Ricci previously) => Quarterly to monthly
4. ErinsAudioCorner.com (Erin) (@hardisj on ASR) => Quarterly to monthly
5. HomeTheaterReview.com (Brian Kahn) => Quarterly to monthly
That's it.
Who's currently testing subwoofers using CTA-2010-B method?
Only Erin from ErinsAudioCorner.
He's the only one testing and showing results with this standard.
Since everyone else is showing CEA-2010-A standard, this is what I'm sticking to as well.
Great, so multiple reviewers are testing using standard methods and are all presenting the data in the same format?
Well, no.
Even though the mythology to test is the same, each reviewer shows the results using his own format, which makes comparison of different CEA-2010-A data difficult and confusing for beginners. I've solved this problem below.
What is CEA-2010-A spec say?
CEA-2010-A is referenced to "... 1 m ground plane level" at Peak levels.
Erin's measurements are Maximum (Peak) SPL, obtained in 2-meter Ground Plane (2 pi) conditions.
I'm going to stick to this format as well.
How do you convert between various CEA-2010-A measurements?
-For every doubling of distance (ex. 1 meter to 2 meter), you subtract 6dB.
-For every halving of distance (ex. 2 meter to 1 meter), you add 6dB.
-To convert Peak SPL to RMS SPL, you subtract 3dB.
-To convert RMS SPL to Peak SPL, you add 3dB.
What did you actually do?
1. I collected all known CEA-2010-A subwoofer measurements
2. I converted all measurements to be on equal footing (2m Peak SPL)
3. I added subwoofers that were never measured using CEA-2010-A standard
4. I added discontinued subwoofers, which can sometimes be bought for bargain prices
5. I put together a spreadsheet that can be sorted and filtered based on your criteria
All this means, is you can make a decision by looking at my spreadsheet, and taking the guesswork out of purchasing a subwoofer.
What is the goal of my spreadsheet?
The goal is to *eventually* (Rome wasn't built in a day!) create the ultimate subwoofer comparison table, to make it easy for anyone to find a subwoofer for their needs.
What are your sources?
Here's the latest CEA-2010-A data from Brent Butterworth:
https://docs.google.com/spreadsheets/d/1KjlXBWMPAHgU_V9DAHSdIZ_ke0MxwH6ekt3vTIlYOJU/edit#gid=0
Data is presented as 1m Peak SPL.
I have to subtract 6dB from "Brent's data" in order for it to be equal to what i'm showing (which is 2m Peak SPL).
Here's the latest CEA-2010-A data from Audioholics.com:
https://www.audioholics.com/subwoofer-reviews/svs-pb-1000-pro-sb-1000-pro/Audioholics Bassaholic spreadsheet-04-18-21.xlsx
NOTE: this will change over time, as AH uploads a new spreadsheet
Data is presented as 2m RMS SPL.
I have to add 3dB to "Audioholics data" in order for it to be equal to what i'm showing (which is 2m Peak SPL).
Here's the latest CEA-2010-A data from Data-Bass.com:
https://data-bass.com/#/systems?_k=x5shhe
I have to add 3dB to "data-bass.com data" in order for it to be equal to what i'm showing (which is 2m Peak SPL).
Here's the latest CEA-2010-A data from ErinsAudioCorner.com:
https://docs.google.com/spreadsheet...k4mHkuwv_uiGAMyEhgrTkjwdXc/edit#gid=407670234
Since Erin's format (2m Peak SPL) matches my table, nothing needs to be done with this data.
Note: Erin also tests CEA-2010-B standard, but since he's the only one, there's no point including this data...yet. Unless others start to test it as well.
How many subwoofers are there?
If you want to see the latest data, either look at:
- The 'Statistics' tab (for real-time data)
- My changelog (for daily data)
Subs that I'm NOT including here?
-DIY subs. I have no interest in DIY subs, nor I want to include them.
-PA (public address) subwoofers. I might make an exception and include a few models that have CEA-2010-A data, just for comparison.
-Subs for outdoor use. I might make an exception and include a few models that have CEA-2010-A data, just for comparison.
Subs that I'm on the fence on...
-In-wall/in-ceiling subwoofers. These were made for home-cinema applications, so it makes sense to include them, I think.
Inside the spreadsheet, can you explain the 'Table Legend'?
- Manufacturer
Sorted by, first
- Model
Sorted by, second
- Discontinued: Yes/blank
I look at the mfg website to see if there's any indication this was discontinued
- Mfg Link
Direct link to website
- Manual
Link to pdf, to save you time having to hunt down the links
- Price
If bold, price was taken from mfg website. If non-bold, price was taken from 3rd party website. If "n/a" it means I couldnt find any reliable sellers that sell that item. I specifically ignored website that sell 2nd-hand, like ebay, etc. For Canadian and US market, I know the market well, so it was easy to find reliable price data. For European website, it was more challenging, but I think it turned out okay. Let me know if there's any major mistakes there.
- Currency
Added currency that I saw for each item, from the same website. I tried to match currency with company's headquarters (example: for US company, currency in USD).
- Frequent Sale Price
Any sale price (in original currency)
- Converted to USD
This is an automatic conversion (that runs hourly?) from original currency to USD
- Converted to CAD
This is an automatic conversion (that runs hourly?) from original currency to CAD
- Converted to EUR
This is an automatic conversion (that runs hourly?) from original currency to EUR
- Converted to GBP
This is an automatic conversion (that runs hourly?) from original currency to GBP
- # of woofers
# of active woofers, not passive woofers (like those in passive radiator)
- Woofer Size
In Inches
- Type
Sealed, ported (front, rear, side, bottom), passive radiator, in-wall, horn
- Passive: Yes/blank
If the subwoofer has speaker terminals, and requires an external amplifier to work. If passive, you'll see "Yes". If left others blank, for easier identification.
- Source of CEA-2010-A data
Showing the source, 'Colour coded' by source, see colour guide below.
- Version Tested
Showing the exact configuration tested (ex. 1 port open, 2 ports open, etc) 'Colour coded' by source, see colour guide below.
- 10hz to 125hz
CEA-2010-A data, shown as '2m Peak SPL'. 'Colour coded' by source, see colour guide below.
- Actual Audioholics' Bassaholic Rank
Given by Audioholics.com
- My Calculated Audioholics' Bassaholic Rank
See tab "Bassaholic" to understand how I calculated this.
- My Notes
I classified subwoofers with extra classifications, like "sphere" or "cylinder" or "PA sub" or "low profile (<8in) (aka pancake subs)". For some, I added alternate name or product #s for subs.
- Warranty
Most mfg websites just listed the one warranty (usually for all countries). But some listed "USA-only" warranties, so I used those links where possible. (See below for explanation).
- High Pass Filter
Also known as 'low-cut filter'. There are 3 methods of implementing a "High Pass Filter" (aka HPF). A) Where the subwoofer manufacturer implemented a fixed HPF for RCA/XLR inputs/outputs at the typical crossover point of 80hz (sometimes close to it). Essentially, you send the signal to sub, the sub applies the HPF and sends the rest of the signal to the speakers. Often times, subs that were made for "studio monitors" have this option. B) Where the subwoofer manufacturer implemented it's own fixed HPF below very low frequencies (say, between 12hz and 30hz). Modern non-DIY active subwoofers have it's own HPF filter for very low frequencies (say 10-30hz). You won't know about these, because manufacturers implement these in the crossover/DSP, but won't advertise that they did this. C) Where the subwoofer manufacturer implemented a *variable* HPF, but only for very low frequencies (say, between 12hz and 30hz). The user can *selectively* apply their chosen HPF to cut some very low frequencies using the subwoofer's dip-switches/user-interface. Example: Arendal's subsonic filters can filter "Hz: 12,16,21,25,31 with dB/octave: 6,12 using on-screen-display."
- Analog XLR Input: Yes/No/N/a
If "Yes", this subwoofer has balanced XLR inputs. Useful when you have studio monitors and want to connect to a subwoofer. Or simply want to have a fully balanced solution (cables, DAC, amp, etc).
- Height (in) x Width (in) x Depth (in)
In Inches
- Volume (ft^3)
Showing volume in in^3 will be a large number, so I converted to ft^3 to make it easier to view
- Height (cm) x Width (cm) x Depth (cm)
Simple math conversion where 1 in = 2.54 cm. This was not taken from mfg website.
- Volume (m^3)
Showing volume in cm^3 will be a large number, so I converted to m^3 to make it easier to view
- Company's Headquarters (Country)
Location of Company
Inside the spreadsheet, can you explain the colour code for CEA-2010-A data?
I've colour-coded each CEA-2010-A source, so you can tell it apart easier.
There's no meaning in the colour choices.
Simple colours were chosen to separate different sources.
Audioholics = Yellow
ErinsAudioCorner => Green
Data-bass => Blue
Brent Butterworth => Red
See tab "Others" => Grey
Inside the spreadsheet, can you explain the 'Warranty' column?
Deciphering my 'da vinci code':
- If you see "5" that means it's a normal warranty.
- If you see "5/3", that means the enclosure/unit was 5 years warranty, and amplifier inside is 3 year warranty.
- If you see "1(+3)", it means a regular warranty of 1 year, but with 3 years additional available (either through purchasing it from mfg, or by registering the model # with the mfg, in which case they give you the extra warranty for free).
- If you see "1-3" it means warranty wasn't clear, and just said "1 to 3 years".
- If you see "1(or3)" it means warranty is either 1 year, or 3 years, depending on how you purchase the unit.
- If you see "5/2/3", it means there are 3 sepate warranties, as an example: first for unit, second for amplifier, and third for accessory.
- If you see "5?" it means I extrapolated warranty from other models to this one, since I couldn't find information on this model.
- If you see "5/1(+5/+3)" you've found the easter egg. It means the unit has a 5 year warranty on unit and 1 year on amplifier. But if you upgrade the warranty, you get an additional 5 years warranty on the unit (for a total of 10 years) and an additional 3 years warranty on the amplifier (for a total of 4 years).
- If you see "n/a", it means I couldnt find any information about the warranty. If you find it, please let me know.
Can you classify subwoofers based on Audioholics' Bassaholic Rank?
You're in luck. I did. Explained in Post #39.
Do you have a subwoofer that's missing CEA-2010-A measurements, and you would like it tested, and you live in USA?
Contact Erin @hardisj and send him your subwoofer (or ship directly to him when purchasing).
He's in Alabama, USA.
Once he's done, he'll provide everyone with his CEA-2020-A (and B) measurements.
We can create another thread where members chip in $$ to help owners offset the costs of shipping, so people don't have to worry about that.
We need everyone to send their subwoofers to Erin, so we can find the true *gems* of subwoofers and *weed out* the rest.
See thread 'Which subwoofers would you like to see tested with CEA-2010 protocol?'
Here's a sneak peak of my spreadsheet:
2021-04-01 13_27_15-Subwoofer Comparison (by @sweetchaos) - Google Sheets.png
How can I easily sort this spreadsheet?
2021-03-10 16_59_40-Subwoofer Comparison (by @sweetchaos) - Google Sheets.png
-==Link to my Subwoofer Comparison spreadsheet ==-
sweetchaos
sweetchaos
The Curator
BC, Canada
Reserved
To make things easy for web-crawlers and other members searching here on ASR, I'm going to list both the subwoofer manufacturers and subwoofer models below:
List of subwoofer manufacturers (unique)(taken from spreadsheet):
Apart Audio
Audio Concepts Inc (ACI)
BG Radia
Chase Home Theater
Chorus Speakers
Elemental Designs
EMPtek
Epik Subwoofers
Epos Acoustics
Fame Audio
Funkywaves
Lava
NXG
Pinnacle Speakers
Premier Acoustics
Reaction Audio
Sinclair Audio
Sumiko
VBT (Virtual Bass Technologies)
WW Speaker Cabinets
Adelaide Speakers
Krix
Kyron Audio
Richter
Sherwood
VAF
Voll
Red Space Audio
Legend Speakers
Alderwood Speakers
Audiodata
Pro-Ject
System Fidelity
Wiener Lautsprecher Manufaktur
AAT (Advanced Audio Technologies)
Frahm
Angstrom Loudspeakers
Axiom Audio
BlueSound
Bryston
Fluance
Funk Audio
Kanto Audio
Omage
Paradigm
PSB Speakers
Soundstage
Totem
Edifier
Nobsound
Dexon
Arcitec
Argon Audio
Artcoustic
Audiovector
Bang & Olufsen (B&O)
Dali
Dynaudio
Jamo
M&K Sound (Miller & Kreisel)
Scansonic
Steinway Lyngdorf
System Audio
Tangent
Amphion Loudspeakers
Existence Loudspeakers
Genelec
OR Loudspeakers
Advance Acoustic
Atohm
Cabasse
Davis Acoustics
Elipson
Eltax
Focal
Highland Audio
Jo Sound
Mosscade
Prodipe
Triangle
Waterfall Audio
Abacus Electronics
Adam Audio
AER (Acoustic Electronic Research)
Ascendo Immersive Audio
Audio Physic
Audium
Auna Multimedia
Behringer
Beton Art Audio
Canton
ELAC
Emes
ESI Audio
Eve Audio
Heco Audio
HEDD (Heinz Electodynamic Designs)
Inklang
KS Digital
lb Lautsprecher und Beschallungstechnik
LD Systems
Magnat
Mivoc
ModalAkustik
Monkey Banana
MusikElectronic Geithain
Neumann
Nubert
Numan Audio
Phonar
Quadral
Reckhorn
Saxx
Swissonic
TechniSat
Teufel
Wavemaster
Crystal Audio
Fidek
Micca Electronics
Sonodyne
Care Orchestra
Cocaine Speakers
Indiana Line
RCF
Sonus Faber
Denon
Eclipse
Fostex
Onkyo
Pioneer
Sony
Yamaha
Radiotehnika
JK Acoustics
Kharma
Tronios
Arendal
Sigberg Audio
APS
Cube Audio
ESA
Kruger & Matz
Pylon Audio
STX
Sveda Audio
Taga Harmony
Tonsil
Wilson Hifi
Arslab
Reezoldini
Gallo Acoustics
Tannoy
Audio Alto
Samsung
Audio Pro
DLS
Dynavoice
Procella Audio
XTZ Sound
Piega
PSI Audio
TMA Audio
Acoustic Energy
Arcam
ATC (Acoustic Transducer Company)
Audica Professional
AVID Hifi
AVSL Group
BK Electronics
Blue Aura
Bowers & Wilkins (B&W)
Cambridge Audio
Cloud Electronics
Ferguson Hill
Fyne Audio
Graham Audio
Hama
Kef
Living Voice
Meridian Audio
Mission
MJ Acoustics
Monitor Audio
PMC Speakers
Q Acoustics
Quested
REL Acoustics
Rogers
Roth Audio
Wharfedale
AAD Sound
Amazon
Aperion Audio
Ascend Acoustics
Atlantic Technology
AudioEngine
Augspurger
Bagend
Barefoot Sound
Biamp
BIC America
Blue Sky
Blumenstein Audio
Bose
Boston Acoustics
Cadence Sound
Cerwin Vega
Chane Music Cinema
CP Sound
Danley Sound Labs
Dayton Audio
Deep Sea Sound
Definitive Technology
Earthquake Sound
Emotiva
Energy
Episode Speakers
Fluid Audio
Genesis Advanced Technologies
Glow Audio
GoldenEar
Goldwood
Harbinger
Harman Kardon
HSU Research
HTD (Home Theater Direct)
Induction Dynamics
Infinity Speakers
James Loudspeaker
JBL
JL Audio
JTR Speakers
Kali Audio
KLH
Klipsch
Kreisel Sound
KRK Systems
Legacy Audio
Leon Speakers
Lucid Acoustics
Mackie
Magico Audio
Mark & Daniel
MartinLogan
Monoprice
MTX Audio
NHT
Nuforce
Ocean Way Audio
Ohm Speaker
OSD (Optimal Speaker Design)
Outlaw Audio
Perlisten Audio
Phase Technology
Polk Audio
Power Sound Audio (PSA)
PreSonus
Pro Audio Technology
Pure Acoustics
Pyle Audio
RBH Sound
Revel
Rockville Audio
Roku
Role Audio
RSL (Rogersound Labs)
RTJ Audio
Rythmik
Salk Sound
Samson
Savant
Seaton Sound
Sonance
Sonos
Source Loudspeaker Technologies
SpeakerCraft
Specimen Audio
Starke Sound
Streem Speakers
Sunfire
Sunny Cable
SVS
TBI Sound
Tekton Design
Teledata Express
THIEL Audio
Tivoli Audio
Triad Speakers
TruAudio
Vandersteen
Velodyne Acoustics
Von Schweikert Audio
Wilson Audio
Wisdom Audio
Zu Audio
List of subwoofer models (unique)(taken from spreadsheet):
*See My Notes*
1025STL
1091A
1092A
1094A
10D
10S
10in Powered Studio Multimedia
12" Brisance
1225STL
12S
12in 150-Watt Powered
12sHO
14" Subwoofer
15.H Horn subwoofer Custom order
1550ATL
15S
15V
16-46 CS
16-46 CS-Plus
16-46 PC-Plus
16-46 PCi
1723 Subwoofer 1
1723 Subwoofer 1.5
1723 Subwoofer 1S
1723 Subwoofer 1V
1723 Subwoofer 2
1723 Subwoofer 2S
1723 Subwoofer 2V
1723 Subwoofer 3
18.0
18.0E
18.0LX
18.2 Custom Order
18.3 Custom Order
18S
1961 Subwoofer 1S
1961 Subwoofer 1V
2-10 Sub
20-39 CS
20-39 CS-Plus
20-39 PC-Plus
20-39 PCi
21" Sub
21.0
21.0L
21.0LX
21030PTL
212/SE
212/SX
224SB
24.0
24.0E
25-31 CS
25-31 CS-Plus
25-31 PC-Plus
25-31 PCi
3000 Micro
3060S
3070S
4-10 Sub
444 SB
4641
4642A
4645c
5 1/4" Benthic Passive
5040A
5040B
5051A
5628
642eSB
7040A
7050A
7050B
7050C
7060A
7060B
7060s
7070A
7071A
7073A
7260A SAM
7270A SAM
7271A SAM
7350A SAM
7360A SAM
7370A SAM
7380A SAM
7382A SAM
8-Inch 60-Watt Powered
800 Active
800ASW
8S
99 W12S
9S
A-10S
A-bass 10
A-bass 12
A10-UT Ultra-Thin
A7S-450
A8-200
AB3a
ABS210
AE108
AE108 (MK II)
AE308
ALFT 8
ALFT 8S
ALFT-10S
ALFT-12S
ALFT10-S150
APM10
AS 100 SC
AS 105 SC
AS 105.2 SC
AS 120 SC
AS 125 SC
AS 125.2 SC
AS 2015 SC
AS 2020 SC
AS 215 SC
AS 225 SC
AS 40 SC
AS 50 SC
AS 60 SC
AS 65 SC
AS 65.2 SC
AS 80 SC
AS 84.2 SC
AS 85.2 SC
AS 85.3
AS1
AS180
AS2
AS6
ASB6125
ASB6128
ASD 110 SC
ASF 75 SC
ASUB
ASW 10CM
ASW 250
ASW CDM
ASW CM
ASW1000
ASW1201M
ASW1202M
ASW2000
ASW2500
ASW300
ASW4000
ASW500
ASW608
ASW610
ASW610XP
ASW650
ASW675
ASW700
ASW800
ASW825
ASW855
AUDIOMASTER SW 150
AYERS SUB
AYRA PRO10
Abyss
Acoustic10
Acoustic12
Active Subwoofer US 5305/6 SW
Addon C-Sub
Addon Sub
Aero 9
Aktiv 200
Aktiv 250
Aleva GT Sub 322A
Alpha 1200s
Alpha D
Alpha RS 12
Alpha RS 8
Alpha S10
Alpha S8
Amber
Amber HR
Ambient 88 F
Apex AW12
Arslab STORM
Artist Sub
Atmos
Aurora Sub 30A
Aurum Orkus 9
B-12d
B1
B10
B110
B110v2
B112
B112v2
B12
B120
B15a
B8
B88-REFERENCE
BASIS 11K
BASIS 13K
BASIS 14K
BASS 08
BASS 12
BASS10 MK2
BASS12
BASS15
BASS8 MK2
BBD-10
BBF-310
BGX-S6B
BRW10
BW-2
BW-3
BXW10
Baby Boomer
Baby Boomer Plus
BalancedForce 210
BalancedForce 212
BaseTwo25
Bass Module 500
Bass Module 700
Bassoon 77
Bassoon 88
Beolab 19
Bravus 10D
Bravus II 10D
Bravus II 12D
Bravus II 8D
Brighton 8S
Brisance
Bronze W10
C 910 SUB
C 912 SUB
C-11
C-308ASWI
C-310ASWI
C-8 D
C1 Sub
C1 Sub Mk2
C4 Sub
C6 Sub
CB-120
CB-150
CHUPACABRA
CLS-10
CLS-12
CORAL SW-10
CP-8
CPH-10
CPH-200S
CR8S-XBT
CS 10
CS 12
CS 2201
CS 2202
CS-218
CS-SUB8
CS-Ultra
CSIR SUB In-Room
CSUB-10
CSUB-12
CSUB-8
CSX-12 Mark II
CSX-15 MKII
CT SW10
CT SW12
CT SW15
CT-150
CT8 SW
CTD_SUB8
CW10
CW8
CYCLONIX 11
CYCLONIX 12
CYCLONIX ACTIVE
CYCLONIX PASSIVE
Captivator 118HT
Captivator 118PRO
Captivator 1400
Captivator 212PRO
Captivator 215PRO
Captivator 218PRO
Captivator 2400
Captivator 2400ULF
Captivator 4000ULF
Captivator 4000ULF-LP
Captivator 4000ULF-ST
Captivator 4000ULF-TL
Captivator RS1
Captivator RS2
Captivator S1
Captivator S2
Carbon Special
Celan GT Sub 322A
Celan Revolution Sub 32A
Ceramique Subwoofer
Challenger CSB-V12
Challenger CSB-V15
Challenger SUB-10
Challenger SUB-12
Challenger SUB-8
Chrono AS 525 SC
Cinema Sub
Cinema Sub (passive)
Cinema Ultra SUB 300-THX
Citation Sub
Classic Bass 1
Classic SW260 Mk3
Compact Cube 10
Compact Cube 8
Compact Sub
Control 50S/T
Control SB-2
Core Sub
Cub 3
Cub Evo
Cube New Gen Premium 10
Cube New Gen Premium 12
Cube New Gen Premium 8
Cube Rakt 10
Cube Rakt 12
Cube Rakt 8
D 600 SUB
D12s
D15SE
D15s
D212s
D215s
D8
DB-10
DB-12
DB-15
DB-8
DB1
DB10
DB12
DB1D
DB2D
DB3D
DB4S
DD-10+
DD-12
DD-12+
DD-15
DD-15+
DD-18
DD-18+
DF10
DN10
DN12
DN15
DN8
DORD 165
DORD 265
DOUBLE HELIX
DSP-3100
DSP-3200
DSP-3400
DSW PRO 440
DSW PRO 550
DSW PRO 660
DSW-1H
DSW.2
DTS10
DX-1
DXD-12012
DXD-12012 DUO
DXD-12012 QUATTRO-DUO
DXD-12012 QUATTRO-QUATTRO
DXD-12012 QUATTROO
DXD-808
DXD-808 DUO
DXD-808 QUATTRO-DUO
DXD-808 QUATTRO-QUATTRO
DXD-808 QUATTROO
Debut S10EQ
Debut S12EQ
Defiance V10
Defiance V12
Defiance V8
Defiance X10
Defiance X12
Defiance X15
Depth
Depth i
Descent
Descent i
Diamond
Diamond 10.GX
Diamond 10.MX
Digital Sub 600
Dolibass 10 HT
Dolibass 12 HT
Dome Sub
Dominion d108
Dominion d110
Double Gem
Dream Sub
Dynamo
Dynamo 1000
Dynamo 1000w
Dynamo 1100X
Dynamo 1500X
Dynamo 1600X
Dynamo 300
Dynamo 400
Dynamo 500
Dynamo 600X
Dynamo 700
Dynamo 700w
Dynamo 800X
E-12 F
E-9 F
E110
E112
E15
E15HP2
ELECTRA SW 1000 BE
ELS Sub
EMB10
EMB10BP
EMB10DF
EMB10DFM4
EMB10DFM70
EMB12
EMB12BP
EMB12DF
EMB12DFM4
EMB12DFM70
EMB15DF
EMB15DFM4
EMB15DFM70
EMB8
EMB8DF
EMB8DFM
EMB8DFM70
EP125 v4
EP175 v4
EP350 v4
EP400 v3
EP500 Wireless v4
EP500 v1
EP500 v4
EP600 Wireless v4
EP600 v1
EP600 v4
EP800 Wireless v4
EP800 v4
EQ-Max10
EQ-Max12
EQ-Max15
EQ-Max8
ES1010i
ESW-C10
ESW-C8
ESW-M6
ESW-M8
EVO E8 Sub
EW-100
Earthquake 2.0
Earthquake 3.0
Earthquake 3.0 Slim
Earthquake 4.0
Echo Sub
Elegance Subwoofer
Element 10"
Element 12"
Element 8"
Elementa Sub 3830A
Empire
Enchant Subwoofer
Energy Power 10 Sub
Energy Power 12 Sub
Enigma Veyron Subwoofer
Enzo Sub
Ergo AS 650 SC
Ergo AS 650.2 SC
Eris Sub8
Evolution 10"
Evolution 12"
Evolution 6"
Evolution 8"
Exquisite Midi Subwoofer
Extreme
F One (A) Active
F One (B) Active
F Two (A) Active
F Two (B) Active
F-12
F12
F12-400
F12G
F15HP
F18
F18+
F25
F3-10
F3-12
F3-8
F8
F8S
FC10S
FF-10
FF-12
FF6.5
FHOO8
FLSUB8
FM8
FOUNDATION
FV12
FV15
FV15HP
FV18
FV25HP
FVX12
FVX15
FW 12.X
FYB-08SUB
FYB-10ASUB
FYB-10SUB
FYB-12SUB
Fathom f110
Fathom f110v2
Fathom f112
Fathom f112v2
Fathom f113
Fathom f113v2
Fathom f212v2
Five K
Flatsub 8.2
Flatsub Midi
FlexBase25
Force
Force XL
ForceField 3
ForceField 4
ForceField 5
Formation Bass
Forza
Fusion
G-1
G-2
G1 Mark II
G22
G25HP
G928
GOLIATH XD
GSW12
GXW15
Gemini II
Gibbon 10
Gold W12
Gold W15
Gravis I
Gravis II
Gravis III
Gravis V
Gravis VI
Gravitas
Gravitas 12
Grotto
Grotto i
Growler (2015)
H-100
H-100II
HD Theater 600
HDI-1200P
HDSUB10
HDSUB12
HDSUB15
HF2-250S
HF3-500S
HFM-200
HKTS 200 SUB
HKTS 210 SUB
HRS10
HRS12
HRS8
HS8S
HT/1003
HT/1205
HT/1508
HTS 10
HTS 12
HTS3A
HTS3B
HTS4A
HTS4B
HTS6
HV / S-10/500
HV / S-12/500
HV / S-8/300
HV101
HV101-II
HV101-LP
HV121
HV121-II
HV81
Hype 10 G2 10
I-12
I-12e
IMPACT
INKOGNITO 10
INKOGNITO 12
INROOM BRONZE SLIMSUB
INROOM BRONZE SUB
INROOM GOLD SUB
INROOM MINI SUB
INROOM OMNISUB 10
INROOM OMNISUB 12
INROOM OMNISUB 8
INROOM PLATINUM SUB
INROOM SILVER SUB
ISUB2-12
ISUB2-18
IW-S10EQ in-wall
Impact 1
Impact 10
Impact 12
Impact 2
Impact 3
Impact 400
Impact 500
Impact mk 2 10
Impact mk 2 12
J 10 SUB
J 110 SUB
J 112 SUB
J 12 SUB
JK Optima
JK Reference
JO 20
JS-12
K-100SW
K-14 F
K-RSW
K-sub
KC62
KF92
KH 750 DSP D G
KH 805 AG
KH 810 G
KH 870 G
KI-115
KIN Mini
KIN SSUB 10
KIN Sub
KIT RAFALE SL1-X
KIT RAFALE SL3M-X
KIT RAFALE VR1-X
KIT RAFALE VR2-X
KIT RAFALE VR3-X
KM0501s
KM0513
KM0514
KPT-1802-HLS
KPT-418-SW
KPT-484
KPT-684-SW
KPT-684-SW-SMA
KPT-884-SW
KS-SW100
KSW-10
KSW-100
KSW-12
KSW-15
KSW-150
KSW-200
KSW-300
KSW-50
KT-SW
KW-100
KX-4010
KX-4010S
KX-4205
KX-4210
KX-4240
KX-4290
KX-4610
KX-4610S
Karat AS 725 SC
Karat AS 750 SC
Kensington
Kube 10B
Kube 12B
Kube 8B
Kube-1
Kube-2
L12
L22
LF200
LF300
LF500
LFC-10sm
LFC-12v
LFC-14sm
LFC-15sm
LFC-18sm
LFC-210sm
LFC-212ai
LFC-21sm
LFC-24sm
LFE Classic 18
LFE Classic 21
LFE Classic 24
LFE Ultra 18
LFE Ultra 21
LFE Ultra 24
LFM-1 EX
LOW 840
LOW 880
LS Bw
LSP12
LSR-210
LSR-212
LSR310S
LSR6312SP
LU-12
LU-15
LV12F
LV12R
LVX12
LX-10
Level 110
Level THREE
Level TWO
Linie 501 SW
Linie-300-SW
Lipari 21
Ludwig
Luna
M Sub
M-10 D
M8
M8S
MAGELLAN VI PASSIVE
MAGELLAN VIII su PASSIVE
MAGELLAN VIII xu PASSIVE
MARIANA 18S
MARIANA 18SD
MARIANA 24SC
MARIANA 24SR
MASS Subwoofer
MASS W200
MASTER SUB 700B
MB10
MBM-12
MBM-12 MK2
MEGA 10"
MEGA 10" Dual
MEGA 12"
MEGA 12" Dual
MEGA 15"
MEGA 8"
MEGA 8" Dual
MEGACYCLONIX
METRO XD
MINX X201
MINX X301
MKIV-10
MKIV-12
MKSX4
MKVII-12P
MKVII-12Sealed
MKVII-15P
MKVII-15Sealed
MPB SW2
MPB SW4MKll
MRS10
MRW-10
MS-10
MS-10.1
MS-150
MS-200
MS-400
MS-450
MS-8
MS-8.1
MS10
MS10SUB
MS12
MS2-S8
MSUB-A082
MSUB-A122
MSubwoofer
MX300
MY SUB
Maestro
Maestro XL
Magellan VI
Magellan VIII
Magellan VIP
Magic MW-10
Magic MW-12
Matrix 800
Mercury
MicroSub45
MicroVee
Millenia CT
Millenia CT 2
MilleniaSub
Mini T Subwoofer
MiniMe DSP P-10
MiniMe DSP P-12
MiniMe FF8 (Ver. 2)
MiniMe P10 (Ver. 2)
MiniMe P12 (Ver. 2)
MiniMe P63
MiniMe P8 (Ver. 2)
MiniMe P8W (Ver. 2)
Model S-210
Model SUB
Moden M Bw
Modern Cube 10
Modern Cube 12
Modern Cube 8
Monitor MRW-10
Monitor SUB 10
Monitor SUB 12
Monitor SUB 8
Monitor Supreme Sub 202A
Monitor Supreme Sub 302A
Mono-Subwoofer US 2106/1 SW
Monolith 10" THX Select
Monolith 12" THX Ultra
Monolith 13" THX Ultra
Monolith 15" THX Ultra
Monolith 16" THX Ultra
Monolith M-215 Dual 15" THX Ultra
Monolith M10-S
Monolith M12-S
Monolith M15-S
Monolith Plus -DF
Monolith Plus -FF
Monolith-DF
Music Style Sub 25 A
MusicCast SUB 100
MusikBass
NANO-1
NEKKST K10S
NERO DUAL X8
NERO TUBEBASS10
NL151
NS-SW050
NS-SW100
NS-SW1000
NS-SW200
NS-SW210
NS-SW300
NS-SW310
NS-SW500
NS-SW700
NS-SW901
NS-WSW121
NX-BAS-500
NX-PROSUB125
NX-PROSUB300
NX-PROSUB8
New Phalanx 202A
New Phalanx 203 F
New Phalanx 302A
No 25
Noble Sub
OLi KH30
ONWALL BRONZE SLIMSUB
ONWALL SILVER SUB
OR-DSW8
OR-ESW1
OR-GSW20
OR-QSW1
OR-XSW1
ORION
Omega CS 12
Omni 10.3
Optimum-10
Optimum-12
Optimum-8
Orbit Shifter LFU
Orbit Shifter PRO
Oxford
P-10 DSS
P-312W
P10SI
P12-300SB-DF
P12-300SB-FF
P12-300SB-PR
P15A
P15AMP
P15FP
P15SI
P18
PA-150
PB-1000
PB-1000 PRO
PB-2000
PB-2000 PRO
PB-3000
PB-4000
PB-Ultra/2
PB10-ISD
PB10-NSD
PB12-ISD
PB12-ISD/2
PB12-ISD/V
PB12-NSD
PB12-NSD/2
PB12-Plus
PB12-Plus/2
PB12-Ultra
PB12-Ultra/2
PB13-Ultra
PB16-Ultra
PBM2
PC-10
PC-2000
PC-2000 Pro
PC-4000
PC-SUB WL 10
PC-SUB WL 12
PC-Ultra
PC12-NSD
PC12-Plus
PC13-Ultra
PDF12V
PDR 100
PDR 80
PDR W100
PDSUB8A
PL-200II
PL-300
PLANET SUB
PLATINUM SW-10 V.3
PLW-15
PM-SUBmini2
PRESTIGE FACET SUB 8
PRESTIGE FACET SUB10
PRO 100 Mk2
PRO 10S V3
PRO 12
PRO 50 Mk3
PS 1
PS 101
PS 2
PS-15X
PS10
PS12
PSW 108
PSW 110
PSW 111
PSW 125
PSW 303
PSW 404
PSW 505
PSW-10
PSW-12
PSW-15
PSW-6
PSW-8
PSW10
PSW12
PSW250-6
PSW300-8
PSW400-10
PSW500-12
PSW600-15
PULSE SUB
PULSE SUB+
PV-1
PV-15X
PV1D
Pearl Sub
Persona SUB
Platform
Platinum PLW215 II
Plus Media 2.1
Poseidon
Power-FL10
Power-FL12-II
Power-FL8
Premium Select 8in 200-Watt
Prestige 1000SW
Prestige 2000SW
Pro 80Mk1
ProSub 1000
ProSub 800
ProfileSub
Profondo 4
Q B12
Q-Sub 15
Q-Sub 18
QR Sub
QUBE 10
QUBE 12
QUBE 8
QX-12
R Sub
R-100SW
R-10SW
R-10SWI
R-110SW
R-112SW
R-115SW
R-120SW
R-12SW
R-12SWI
R-205
R-218
R-305
R-328
R-505
R-528
R-528SE
R-80SWi
R-8SW
R360
R360HD
R370HD
R400
R720
RAFALE VR1-X
RD SW10
RD SW12
RD SW8
REF 1 Mk4
REF 100Mk4
REF 200
REF 210
REF 400
REF 800Mk-SR-FF
REF 800Mk2
REF I Mk3
REF802-SR-FF
REF805-SR-FF
REFERENCE 8B
REFERENCE SUB R10
REFERENCE SUB R12
RIGONDA S ASW-1.8
RM-12 SUB
ROARR 1108
ROARR 1210
ROARR 1312
RPM10S
RPW-10
RS1010i
RS10i
RS11
RS13
RSW-10
RSW-10D
RSW-12
RSW-15
RT-10D
RT-12D
RW-100SW
RW-10D
RW-12
RW-12D
RW-8
RWSUB-8
RXW12
Radius 380
Radius 390
React Sub
Reference SUB 50 K
Reference Subwoofer
RetroSub
Rhythm2
Rock Shaker 10
Rock Shaker 12
Rock Shaker 8
S 808 SUB
S 810 SUB
S-10
S-10 w Active
S-10 w Passive
S-12
S-1212N
S-1212P
S-21W
S-52W
S-8
S-Sub
S.0
S.10
S.5
S.9
S/3 SHO
S/5 SHO
S/510
S/812
S10
S10.2
S10.4
S10A
S12
S12.4
S12A Mk II
S15
S1500
S1510
S1510DF
S1512
S1512DF
S18 IPAL
S1800
S1801
S1811
S1812
S2/12t
S3000i
S3010
S3012
S36 IPAL
S3600I
S3601
S3611
S3612
S4/8
S42 IPAL
S7201
S8
S8.2
S8.4
SA legend sub 12
SA saxo sub 10
SA-NA9ES
SACS9
SANTORIN 25 M2
SANTORIN 30-200
SANTORIN 30-500
SANTORIN 38
SB-1000
SB-1000 PRO
SB-2000
SB-2000 PRO
SB-212
SB-3000
SB-4000
SB-900
SB10R
SB12-NSD
SB12-Plus
SB13-Plus
SB13-Ultra
SB16-Ultra
SB8
SBT1000
SBT500
SCM0.1/12SL Pro
SCM0.1/15SL Pro
SCS
SDS10
SDS12
SDS8
SE Sub
SE12
SE7261A
SE8
SEISMIX 1 MK6
SEISMIX 3 MK7
SHFS08B
SKW-204
SKW-770
SLF 106
SLF 108
SLF 210
SLF 312
SLIM BASS 8
SLW 10
SLW 12
SLW 8
SMS12-P
SMS15
SMS18
SMS21
SMSG10
SMSG10-P
SMSG12
SMSG15
SMSG15 CH
SMSG15 WL
SMSG24
SMSG32
SMSG50
SN 10
SPL-100
SPL-120
SPL-1200 Series II
SPL-150
SPL250
SPL500
SS 10
SS-10
SS-12
SS-8
SS1
SS18.1
SS2
SS2.2
SS3
SS4
SS8
SSW-10
SSW-12
SSW-8
STAGE-100
STENTOR III
STF-1
STF-2
STF-3
STUDIO III
STX Electrino 150 S Active
STX Graviton 500 S Active
STX Quant 300 S
STX S-1200 Passive
STX S-200n Active
STX S-250n
SUB 10
SUB 10.17
SUB 10.17 Edge
SUB 10.2
SUB 10.4
SUB 1006
SUB 1008
SUB 1010
SUB 1012
SUB 12
SUB 12.17
SUB 12.17 Edge
SUB 12.2
SUB 12.4
SUB 1200 R
SUB 1201A
SUB 12D
SUB 15 Universal
SUB 1500 R
SUB 1810
SUB 1X12
SUB 20
SUB 20 A
SUB 200
SUB 210
SUB 212
SUB 3X12
SUB 40
SUB 40 A
SUB 550P
SUB 6
SUB 6.2
SUB 600
SUB 601
SUB 650
SUB 8
SUB 8 MKIII
SUB 8.17
SUB 8.2
SUB 8.4
SUB 80
SUB 80 A
SUB 80.2
SUB 800
SUB 800 R
SUB 810A
SUB 85
SUB 850 R
SUB 88
SUB 88 A
SUB 900
SUB A165
SUB NINE
SUB THREE
SUB UTOPIA EM
SUB-1000
SUB-1000L
SUB-12 HGL
SUB-1200
SUB-1500
SUB-80
SUB-800
SUB-9
SUB1-S / Sub1-S SE
SUB1-S /  SUB1-S.SE ACTIVE
SUB10 MK2
SUB1010
SUB12
SUB15
SUB15D
SUB18
SUB2010
SUB2020
SUB2030
SUB2050
SUB2070
SUB2100
SUB2201
SUB24
SUB2400
SUB3
SUB3010
SUB3030
SUB3070
SUB35
SUB45
SUB7
SUB8
SUB8S
SUB8SM
SUBMISSION VI
SUPERSUB X
SUPERSUB XXL
SV-12
SV-1212N
SV-1212NR
SV-1212P
SV-1212PR
SV-12N
SV-12NR
SV-12P
SV-12PR
SW 10 PC
SW 10 ULT
SW 1000 BE
SW 12 D Series
SW 12 DF ULT
SW 12 ULT
SW 800 Subwoofer
SW-10
SW-10 II
SW-100
SW-110
SW-112
SW-115
SW-12
SW-12 II
SW-15
SW-15 II
SW-150
SW-180
SW-308
SW-310
SW-311
SW-33
SW-350
SW-450
SW-5
SW-500
SW-55
SW-65
SW-8
SW-8 II
SW-8MK2
SW-E10
SW01M
SW1 Black Gloss
SW10
SW1100A
SW12
SW15
SW15(AP)
SW18
SW2
SW2 Black Gloss
SW3 Black Gloss
SW4 Black Gloss
SW4.IW Black Gloss
SW4.W Black Gloss
SW5.W Black Gloss
SWA-W500
SWA-W700
SWF-BR100
SWV
SX-1010N
SX-1010N/R
SX-1010P
SX-1010P/R
SX-10R
SX-12
SX-120
SX-1212N
SX-1212NR
SX-1212PR
SX-12R
SX-88
Satellite Subwoofer
Seismic 10
Seismic 110
Seismic 12
Signature Sub 1
Signature Sub 2
Signature Sub 25
Signature Sub 530A
Signature Sub 730A
Signature Sub 930A
Silver W-12
Silver W12
Slimpact-10
Smart SUB 12
Smart SUB 8
SmartSub 1.12
Solo Sub
Soutien 2
Soutien 4
Spectrum XSW-8
Speedwoofer 10
Speedwoofer 10S
Spirit Sub 12
Stage A100P
Stage A120P
Storm Sub
Stratton 10
Stratton 12
Studio 650P
Studio 660P
Studio SUB 15
Sub
Sub (Gen 3)
Sub 1
Sub 1000 F
Sub 12 Active
Sub 12 Air
Sub 12 Passive
Sub 12-D8 Passive
Sub 18 Passive
Sub 2
Sub 218 Passive
Sub 250
Sub 250 II
Sub 250 SAT
Sub 250MC
Sub 3
Sub 300
Sub 300 P
Sub 500
Sub 600p
Sub 8.3
Sub 80-LP
Sub 8w
Sub A125-M
Sub A225-M
Sub Air
Sub Box 50
Sub One
Sub Utopia EM Colour Evo
Sub-10
Sub-100
Sub-12
Sub-120
Sub1
Sub10
Sub30
Sub6
SubMersive F2+
SubMersive HP+
SubOne
SubSeries 1
SubSeries 100
SubSeries 125
SubSeries 150
SubSeries 200
SubSeries 250
SubSeries 300
SubSeries 350
SubSeries 450
SubSeries 5
SubSeries 500
SubSeries 5i
SubSeries HD10
SubSeries HD8
Sublime
Subsonic
Subway
Subwoofer 9201X
Subwoofer S 4000 SW
Subwoofer S 6000 SW
SuperCube 2000
SuperCube 4000
SuperCube 6000
SuperCube 8000
T 10 Subwoofer
T 6 Subwoofer
T 8 Subwoofer
T-10BK-PAK
T-12 Sub Wireless
T-2
T-5
T-7
T-8 Sub Wireless
T-9
T/5i
T/5x
T/7i
T/7x
T/9i
T/9x
T1
T10S
T18
T18HT
T2
T3
T5
TAI-10
TD316SWMK2
TD520SW
TD725SWMK2
TDX-SUB10
TDX-SUB12
TDX-SUB8
TEATRO BLACK 10-SW
TEKTONIX
THUNDER SW-12
THX 121456
THX-10SUBT-BL
THX-1200-SW
TITAN 11.6 MK2 (2013)
TITAN 15.6 MK2 (2013)
TITAN 5.6
TITAN 7.6 MK2 (2013)
TMICRO
TN1220HO
TN1225HO
TN825
TR-1
TR-3D
TRIAX
TS-10AN
TS-10AP
TS-12AN
TS-12AP
TS-EQ10 - True Subwoofer EQ 10 Signature
TS-EQ12 - True Subwoofer EQ 12 Signature
TS-EQS10 - True Subwoofer EQ Solitaire 10
TS-EQS12 - True Subwoofer EQ Solitaire 12
TS-SJ8 - True Sub Super Junior
TS107
TS108
TS110
TS112
TS2.10
TS2.8
TSW-210
TSW-212
TSW-212 SE
TSW-90 V.4
TSW10
TSW12
TV1512
TV18 IPAL
TV1812
TV21 IPAL
TV2112
TV36 IPAL
TV3612
TV42 IPAL
TX-12SUB-BLA
TX-8SUB-BG
TYRON 21
Tales 340
Tales 400
Temblor T10
Temblor T8
Tempus Sub 300A
Ten Sub
The Cube
Thetis 280
Thetis 320
Thetis 380
Thor 10.6
Thor's Hammer
Thunder II Sub
Thunder T-10
Thunder T-12
Titan
Titan II
Titan XL
TreVoce 10
TreVoce 10 DSP
TreVoce 12
TreVoce 12 DSP
TreVoce 8
TreVoce 8 DSP
Tribe Solution
Triple 10"
Triple 8"
True Subwoofer Architectural
True Subwoofer Architectural Signature
True Subwoofer Mark IV
True Subwoofer Signature
Turbo 10s
Tzero
Tzero MKIII
UFS 10 P
UFS 12 P
UFS 9 P
ULS-15
ULS-15 MK2
UNDERTONE MK.II
UPC-10
UPC-8
USS
Ultima Sub15
Ultima Sub30
Ultra 12
Ultra-X12
Ultra-X13
UltraCube 10
UltraCube 12
Ultrumax-Sub-IIa
Ultrumax-Sub-Ia
UniSUB
V-12XS Shockwave
V-20W
V-SW10
V10
V10 Compact
V1020
V12
V12 Compact
V1220
V12S
V1500
V1510
V1510DF
V1512
V1512DF
V18
V18 IPAL
V1800
V1801
V1811
V1812
V21
V2218S
V2W
V36 IPAL
V3600I
V3601
V3611
V3612
V6
V8
V8 Compact
V80
V8S
VIGOR SW-8
VOLCANIX
VOLCANIX SLIM
VS18.1
VTF-1
VTF-1 MK2
VTF-1 MK3
VTF-15H
VTF-15H MK2
VTF-2
VTF-2 MK2
VTF-2 MK3
VTF-2 MK4
VTF-2 MK5
VTF-3
VTF-3 HO
VTF-3 HO with Turbocharger
VTF-3 MK2
VTF-3 MK3
VTF-3 MK3 with Turbocharger
VTF-3 MK4
VTF-3 MK5 HP
VW8
Vento AS 850 SC
Veritas s8 NEXT
Vertigo SLS
Vertigo Triton 10
Vertigo XLS
Vertigo XLS 07
Vertigo XP12
Vertigo XXL
Victa Prime Sub 252A
Vox Basso
Vox Elysian
W-1
W371A SAM
WH-D10
WH-D8
WH-S10E
WH-S8E
WOMBAT
WS-10
WS-12
Watch Dog
Wi-Q 10
Wi-Q 12
Windsor
Windsor 10
Windsor 12
X-Ref 12
X10
X12
X21 - B&C 21DS115-4
X21AD
X21AI
X21PD
X21PI
X8
XL-110
XLS 12S
XLS 15S
XLS200 MK2
XLS200-DF MK2
XLS300/PR
XS15
XS15-BASE
XS15SE
XS30
XS30SE
XTATM265
XTEQ10
XTEQ12
XTEQ8
XTREME XD
XV15
XV15-BASE
XV15SE
XV15SEICE-BASE
XV30
XV30F
XV30FSE
XW-300D
XW-500D
XXLS400-DF
XXLS400-FF
Xref-10
YST-SW005
YST-SW010
YST-SW012
YST-SW020
YST-SW030
YST-SW040
YST-SW045
YST-SW060
YST-SW080
YST-SW090
YST-SW100
YST-SW105
YST-SW120
YST-SW150
YST-SW1500
YST-SW160
YST-SW200
YST-SW205
YST-SW215
YST-SW216
YST-SW225
YST-SW300
YST-SW305
YST-SW315
YST-SW320
YST-SW325
YST-SW500
YST-SW515
ZX-12
aktiv 10s
basso
deepSOUND DS 10
deepSOUND DS 12 EVO
deepSOUND DS 12 cineSUB
deepSOUND DS 120 DSP
deepSOUND DS 150 DSP
g213v2
i10
i12
i8
microsub 3
nuSub XW-1200
nuSub XW-700
nuSub XW-900
twenty5 sub
twotwo sub1
twotwo sub2
xSub
your_SUB
your_SUB 600 wireless
I scraped 1816 subwoofer models from website AudioReview.com, and will try to include these into my spreadsheet:
UPDATE: This task is on hold. I have other things to do.
AAD 2002 Audiophile
AAD 300SW
AAD C-10
AAD C-11
AAD E- 55
AAD E-6
AAD E-8
AAD Q-1000
AAD S160
AAD S2000
AAD SD-10
Accurate Sound Wave Cantius AS 404
Accurate Sound Wave Cantius AS 412
Accurate Sound Wave Genius AS 1
Accurate Sound Wave Genius AS 10
Accurate Sound Wave Opus SW 200
ACI Force
ACI Maestro
ACI Quake
ACI SV10
ACI SV12
ACI SV18
ACI Titan
ACI Titan II
Acoustic Energy Aegis Evo Sub
Acoustic Energy Aegis Neo
Acoustic Energy Aegis Sub
Acoustic Energy AEGO 2
Acoustic Energy Aelite Subwoofer
Acoustic Energy AESPRIT 308S
Acoustic Energy NeoV2
Acoustic Energy Radiance Sub
Acoustic Research ARPR1212
Acoustic Research ARS115PS
Acoustic Research ARS300
Acoustic Research ARS500
Acoustic Research FPS10
Acoustic Research PR1010
Acoustic Research PR1011
Acoustic Research PR1012
Acoustic Research PR1014
Acoustic Research PR1015
Acoustic Research PR808
Acoustic Research S108PS
Acoustic Research S112PS
Acoustic Research S115PS
Acoustic Research S12HO
Acoustic Research S8HO
Acoustic Research SW30
Acoustic Zen Allegro
AcoustTech H100
Adam SUB-24 Subwoofer Speaker
Adire Audio Daeva
Adire Audio Dharman
Adire Audio Rava
Adire Audio Rava SE
Adire Audio Sadhara
Adire Audio Shiva
Adire Audio Shiva MKII
Adire Audio Tempest
Adire Audio Tumult
ads C12ps
ads HT10ps
ads HT12ps
ads MS2/u
ads MS3/u
ads SW500
Advent ASW1200
Aerial Acoustics Model SW12
Aiwa 10 Powered Subwoofer TS W150
Aiwa TS-W150
Aiwa TS-W50
Aiwa TS-W60
Aiwa TS-WM5
Allison Acoustics AL 12
Allison Acoustics PB 10
ALR Jordan Classic
ALR Jordan Entry
Altec Lansing XA3001
AmbienceSpeakerSystems Bandpass
AMC B1-20
AMC B1-30
AMC B1-50
AMC SW110
American Audio PXW 15P Subwoofer Speaker
Amphion Impact 400
Amphion Impact 500
Amphion Impact 550
Angstrom Forza
Aperion Audio Bravus 10D
Aperion Audio Bravus 8D
Aperion Audio Bravus II 10D Powered Subwoofer
Aperion Audio Bravus II 12D
Aperion Audio Bravus IIa 8D
Aperion Audio Intimus S-8
Aperion Audio S-10
Aperion Audio S-12
Aperion Audio S-8APR
Artcoustic Panel Sub Duo
Artcoustic Panel Sub Micro
Ascend Acoustics D15 SE
Ascend Acoustics E15
Ascend Acoustics F12
Ascend Acoustics F15
Ascend Acoustics F15HP
Ascend Acoustics FV15
Ascend Acoustics LV12R
Ascend Acoustics STF-1
Ascend Acoustics STF-2
Ascend Acoustics STF-3
Ascend Acoustics VTF-2 MK 2
Ascend Acoustics VTF-3 MK 2
Aspire Digital AD-130PSC
Aspire Digital AD-1501PSC
Aspire Digital AD-150PSC
Aspire Digital AD-225PSC
Aspire Digital AD-331PSC
Aspire Digital AD-33PSC
Athena Technologies AS-P300
Athena Technologies AS-P400
Athena Technologies AS-P4000
Athena Technologies AS-P6000
Athena Technologies M225
Athena Technologies P1
Athena Technologies P2
Athena Technologies P3
Atlantic Technology 102SB
Atlantic Technology 1200-SUB
Atlantic Technology 162
Atlantic Technology 2200-SUB
Atlantic Technology 224 SB
Atlantic Technology 272-SUB
Atlantic Technology 334 SB
Atlantic Technology 350 PBM
Atlantic Technology 352 PBM
Atlantic Technology 4200-SUB
Atlantic Technology 422 SB
Atlantic Technology 444 SB
Atlantic Technology 642e
Atlantic Technology IWTS-28
Atlantic Technology IWTS-8e
Atlantic Technology SB-900
Atlantic Technology T90 PBM Powered Subwoofer
Atlantic Technology Technology 162 PBM
Atlas SM12SUB70
Atomic HPW1294
AUDES SW 110A
AUDES SW U2
AUDES SW U4
Audio Concepts 12 Powered Subwoofer ACI Titan
Audio Concepts Powered Subwoofer ACI Quake
Audio Physic Luna subwoofer
Audio Physic Minos
Audio Physic Rhea subwoofer
Audio Physic Yara
Audio Pro B1.19
Audio Pro B2.27
Audio Pro Mondial Sub 1
Audio Pro Mondial Sub.3
Audio Pro Sub Allroom
Audio Pro Sub B1.28
Audio Pro Sub B1.36
Audio Pro Sub Basiq
Audio Pro Sub Bravo
Audio Pro Sub Cinema
Audio Pro Sub Evidence MkII
Audio Pro Sub Focus
Audio Pro Sub Level 108
Audio Pro Sub Level 110
Audio Pro Sub PS-125
Audio Pro Sub PS-175
Audio Pro Sub Soniq
Audio Pro Sub Supreme
Audio Pro Wigo
Audioengine S-8
Audioengine S8B
Audioengine S8W (White)
Audioplex AT-880S Subwoofer Speaker
AudioSource AS8SW Subwoofer Speaker
AudioSource AST-SUB10
AudioSource AST-SUB10 Subwoofer Speaker
AudioSource MCSW1
AudioSource PSW-100
AudioSource PSW-110
AudioSource PSW100 Subwoofer Speaker
AudioSource PSW112 Subwoofer Speaker
AudioSource SW 12 Subwoofer Speaker
AudioSource SW EIGHT
AudioSource SW FIFTEEN
AudioSource SW Ten Subwoofer Speaker
AudioSource SW TWO
AudioSource SW-1
AudioSource SW-10
AudioSource SW-12
AudioSource SW-15
AudioSource SW-2
AudioSource SW-300
AudioSource SW-300 Subwoofer Speaker
AudioSource SW-5
AudioSource SW-8
AudioSource SW50
Aurum Cantus SW-10
Axiom Speaker Company EP125
Axiom Speaker Company EP175
Axiom Speaker Company EP350
Axiom Speaker Company EP400
Axiom Speaker Company EP400 v3
Axiom Speaker Company EP500
Axiom Speaker Company EP600
Axiom Speaker Company EP800 v3
Axiom Speaker Company Epicenter EP-125
Axiom Speaker Company Epicenter EP-175
Axiom Speaker Company Epicenter EP-350
Axiom Speaker Company Epicenter EP500
Axiom Speaker Company Epicenter EP600
B&W AS1
B&W AS2
B&W ASW 1000
B&W ASW 10CM
B&W ASW 2000
B&W ASW 2500
B&W ASW 300
B&W ASW 3000
B&W ASW 4000
B&W ASW 500
B&W ASW 600
B&W ASW 650
B&W ASW 675
B&W ASW 700
B&W ASW 750
B&W ASW 800
B&W ASW CDM
B&W ASW CM
B&W ASW608
B&W ASW610
B&W ASW610XP
B&W ASW825
B&W ASW855
B&W ASW865
B&W ASW875
B&W PV1
B.I.C. America Acoustech H100
B.I.C. America BIC Venturi DV5312 Powered Towers
B.I.C. America RTR D-120
B.I.C. America RTR V69
B.I.C. America RTR120
B.I.C. America V-1015
B.I.C. America V-1020
B.I.C. America V-1215
B.I.C. America V-1220
B.I.C. America V-80
B.I.C. America V-8A
B.I.C. America V815
B.I.C. America Venturi V-80
Bag End BASSAULT-R
Bag End D10E-I
Bag End D12E-C
Bag End D12E-I
Bag End D18E-I
Bag End Infra Sub-18
Bag End INFRASUB-12 Compact Powered Subwoofer
Bag End S12E-I
Bag End S18E-I
Bamberg Engineering Sound Lab (BESL) CSX-10
Bamberg Engineering Sound Lab (BESL) XLS
Barint Module - Standing Mod 30 Subwoofer
Barint Module - Subwoofer
Barint NHB 45 Module Subwoofer
Barint R4455 Subwoofer Module
Behringer B1800D-Pro
Behringer B1800X Pro
Behringer Eurolive B215a Loudspeaker B215 A Subwoofer
Behringer VP1800S
BGW M1100
BGW M2200
BGW M850i
Blueroom Bass Station
Bohlender-Graebener Radia Z Sub
Bose B1 Subwoofer Speaker
Boston Acoustics ASW 250
Boston Acoustics ASW 650
Boston Acoustics CPS 10Wi
Boston Acoustics CPS 12Wi
Boston Acoustics CPS 8Wi
Boston Acoustics CS Sub10
Boston Acoustics PV1000
Boston Acoustics PV350
Boston Acoustics PV400
Boston Acoustics PV500
Boston Acoustics PV600
Boston Acoustics PV700
Boston Acoustics PV800
Boston Acoustics PV900
Boston Acoustics RPS 1000
Boston Acoustics RS 12
Boston Acoustics Sub10F
Boston Acoustics Voyager Sub 12
Boston Acoustics VPS 210
Boston Acoustics XB4
Boston Acoustics XB6
Cabasse Jupiter MT420R
Cabasse Pluton MT360R
Cabasse Saturn 55
Cabasse Thor II Artis
Cadence XSUB-12
Cambridge Audio Minx X200-BK Powered
Cambridge Audio MinxX200 Powered (White)
Cambridge Audio MinxX300 Powered (Black)
Cambridge Audio MinxX300 Powered (White)
Cambridge Audio MinxX500 Powered (Black)
Cambridge Audio MinxX500 Powered (White)
Cambridge Audio S90 Graphite
Cambridge Audio S90-BK
Cambridge Soundworks BaseCube 15
Cambridge Soundworks Bass Cube 10
Cambridge Soundworks Bass Cube 12
Cambridge Soundworks BassCube 8
Cambridge Soundworks Newton Series P500
Cambridge Soundworks P1000
Cambridge Soundworks P200
Cambridge Soundworks Powered Subwoofer
Cambridge Soundworks Slave Subwoofer
Canton AS 120 SC Subwoofer Speaker
Canton AS 125 SC Subwoofer Speaker
Canton AS 15 SC Subwoofer Speaker
Canton AS 20
Canton AS 225 SC
Canton AS 85 Active Front-Firing Subwoofer (Single, Silver) Subwoofer Speaker
Canton AS105BK Subwoofer Speaker
Canton AS22
Canton AS25SC
Canton AS80
Canton Chrono AS 525SC Subwoofer Speaker
Canton Ergo AS 650 SC Subwoofer Speaker
Canton ERGO AS 650.2 SC Subwoofer Speaker
Canton INCEILING650 Subwoofer Speaker
Canton Karat AS 725 SC Subwoofer Speaker
Canton Karat AS 750 SC Subwoofer Speaker
Canton Movie CD 206 Subwoofer Speaker
Canton Vento AS 850 SC Subwoofer Speaker
Carver Audio Knight Shadow
Castle Acoustics Classic
Castle Acoustics Inversion 80S
Celestion F1540
Celestion F1840
Celestion S10
Celestion S80
Celestion S80 Subwoofer Speaker
Ceratec Subwoofer Active (AM26PW)
Ceratec Subwoofer large (AM25W)
Ceratec Subwoofer small (AM15W)
Ceratec Vita active subwoofer (black) (AM30PW-B)
Ceratec Vita active subwoofer (veneer) (AM30PW-V)
Cerwin Vega CLS-12S
Cerwin Vega CLS-15S
Cerwin Vega CLSC-12S
Cerwin Vega CLSC-15S
Cerwin Vega EL36
Cerwin Vega HT-12D
Cerwin Vega HT-S10
Cerwin Vega HT-S12
Cerwin Vega HT-S15
Cerwin Vega LW-12
Cerwin Vega LW-15
Cerwin Vega PSX-36
Cerwin Vega RL 28W
Cerwin Vega SUB-150
Cerwin Vega SUB-15MKII
Cerwin Vega SUB-218
Cerwin Vega T-36/750
Cerwin Vega V-10S
Cerwin Vega V-12S
Cerwin Vega VE-28S
Cerwin Vega VIS-218
Cerwin Vega XLS-15S
Chario Hercules
Chario Hiper SW2
Chario Premium SW2
Chario SW1
Citation 5.4 Subwoofer
Clements Richter
Clements Richter II
Crystal Audio THX-10SUB Subwoofer Speaker
CSI/Speco SP-800SW Subwoofer Speaker
CSI/Speco SP-8CLSW Subwoofer Speaker
CSI/Speco SPW-1000
CSI/Speco SPW-1000 Subwoofer Speaker
CSI/Speco SW-12A Subwoofer Speaker
CSI/Speco SW-850 Subwoofer Speaker
Dahlquist QX-100SA
Dahlquist QX-200SA
Dahlquist QX-25RA
Dahlquist QX-300SA
Dali AW 10
Dali AW 8
Dali Basis 100
Dali Concept Sub
Dali Euphonia AS 2
Dali Fazon Sub 1
Dali Fazon Sub 2
Dali IKON Sub
Dali Lektor Sub
Dali Mentor Sub
Dali Piano Forte
Dali S1.5
Dali S600
Dali SUB E-12F
Dali Suite S 1.2
Dali SWA 12
Dali SWA 15
Dali SWA 8
Dali Trio
Dantax Sub A 100 R
Dantax Sub A 200 R
Dayton 10" Titanic MkIII
Dayton 12" Titanic MkIII
Dayton 15" Titanic MkIII
Dayton 300-632
Dayton Audio A532 Subwoofer Speaker
Dayton Audio RS1200A Subwoofer Speaker
Dayton Audio RS225S-8 Subwoofer Speaker
Dayton Audio SUB-100 Subwoofer Speaker
Dayton Audio SUB-120 Subwoofer Speaker
Dayton HSU10
Dayton HSU12
Dayton HSU8
Dayton SUB-80
Dayton SWC-1CO 1.0 ft³ Subwoofer Cabinet w/Cutouts Subwoofer Speaker
Dayton titanic
DCM 1212 130-Watt Powered Subwoofer
DCM 1515 250-Watt Powered Subwoofer
DCM KX-SUB2
DCM SW10 Compact Powered Subwoofer
DCM TB1010
DCM TB1212
DCM TB1515
Decware ZRSUB
Definitive Technology PF1500TL
Definitive Technology PF15TL+
Definitive Technology PF18
Definitive Technology PowerField 12TL
Definitive Technology PowerField 1800
Definitive Technology ProSub 1000
Definitive Technology ProSub 100TL
Definitive Technology ProSub 200TL
Definitive Technology ProSub 60
Definitive Technology ProSub 80
Definitive Technology ProSub 800
Definitive Technology SC4000 SuperCube
Definitive Technology SC6000 SuperCube powered
Definitive Technology SuperCube® Reference
Definitive Technology SuperCube® Trinity Signature
Definitive Technology SuperCube 2000
Definitive Technology SuperCube 8000
Definitive Technology SuperCube I
Definitive Technology SuperCube II
Definitive Technology SuperCube III
DUAL Electronics L10SW Subwoofer Speaker
DUAL Electronics L12SW Subwoofer Speaker
DUAL Electronics L8SW Subwoofer Speaker
DUAL L10SW
DUAL L12SW
DUAL L6SW
DUAL L8SW
Dynaquest DQ-12
Dynaudio Audience Sub-20A
Dynaudio Audience Sub-30A
Dynaudio Contour Sub
Dynaudio SUB 250
Dynaudio SUB 300
Dynaudio SUB 500
Dynaudio Sub 600
Earthquake MKIV-10
Earthquake MKIV-12
Earthquake MKV-10
Earthquake MKV-12
Earthquake MKV-15
Earthquake S-12 Kompressor
Earthquake Sound MKIV-10 Subwoofer Speaker
Earthquake Sound MKIV-12 Subwoofer Speaker
Earthquake Sound MKV-10 Piano Subwoofer Speaker
Earthquake Sound MKV-10 Subwoofer Speaker
Earthquake Sound MKV-12 Subwoofer Speaker
Earthquake Sound MKV-15 Piano Subwoofer Speaker
Earthquake Sound MKV-15 Subwoofer Speaker
Earthquake Sound MKV12PG Subwoofer Speaker
Earthquake Sound S-12 Subwoofer Speaker
Earthquake Sound SUB-80 Subwoofer Speaker
Earthquake Sound SWS-8 Subwoofer Speaker
Earthquake Sub-80
Earthquake Super Nova MKIV 580-Watt Subwoofer
Earthquake Supernova
EAW FR250z
EAW LA118z
EAW NTS250
EAW QX118
EAW SB1000z
EAW SB1002
EAW SB120z
EAW SB150z
EAW SB180z
EAW SB2001
EAW SB250z
EAW SB330z
EAW SB48zP
EAW SB528z
EAW SB625zP
EAW SB730
EAW SB750z
EAW SB850z
EAW SBK150
EAW SBK180
EAW SBK250
EAW SBX220
EAW VRS12
EAW VRS18
Edge SW12
Elac SUB 211 D
Elac SUB 50 ESP
Elan THP1200SW Subwoofer Speaker
Electro Voice Eliminator I
Electro Voice ELX118
Electro Voice EVID 12.1
Electro Voice EVID C10.1
Electro Voice Force I
Electro Voice FORCE-IE
Electro Voice G118
Electro Voice QRx-218S
Electro Voice SB122
Electro Voice SB180
Electro Voice SB2A
Electro Voice SbA760
Electro Voice SXA180
Electro Voice XCS312
Electro Voice Xlc118
Electro Voice Xlc127+
Electro Voice XS212
Electrovoice EVID C10.1 Subwoofer Speaker
Electrovoice EVID12.1
Electrovoice EVM10
Electrovoice EVM12
Electrovoice EVM15
Electrovoice FORCE-I-SUB-E Subwoofer Speaker
Elemental Designs A5 - 300
Elemental Designs A7 - 600
Elemental Designs A7-700
Eltax 8 Active Subwoofer Linear Response .6
Eltax Atomic A 10
Eltax Atomic A 15
Eltax Atomic A 8
Eltax c205
Eltax Impact 10 Subwoofer Speaker
Eltax Power Subwoofer Cubic
Emotiva Ultra Sub 10
Emotiva Ultra Sub 12
EMP Tek E10s
EMP Tek ES1010i
EMP Tek ES10i
Energy Speaker Systems ACT
Energy Speaker Systems AS-180
Energy Speaker Systems EPS 150
Energy Speaker Systems EPS-12
Energy Speaker Systems ES-10
Energy Speaker Systems ES-12
Energy Speaker Systems ES-12XL
Energy Speaker Systems ES-18XL
Energy Speaker Systems ESW-10
Energy Speaker Systems ESW-8
Energy Speaker Systems ESW-C8
Energy Speaker Systems ESW-M6
Energy Speaker Systems ESW-V10
Energy Speaker Systems ESW-V8
Energy Speaker Systems ESWC-10
Energy Speaker Systems EW-100
Energy Speaker Systems EXL-S10
Energy Speaker Systems Microstar 10.1
Energy Speaker Systems MicroStar 12.1
Energy Speaker Systems S10.2
Energy Speaker Systems S10.3
Energy Speaker Systems S12.3
Energy Speaker Systems S8.2
Energy Speaker Systems S8.3
Energy Speaker Systems V-SW10
Eosone RSP 910
Epiphany Audio Sublime
Epos Acoustics ELS SUB
Epos Acoustics EPOS ELS SUB
Esuntech 15" woofer
Esuntech 18" woofer
Fender (PDPS500695021000) Subwoofer Speaker
Fender SQ-Sub
Fender SQ-SUB Subwoofer Speaker
Fluance DB-150
Fluance DB-200
Focal Chorus SW 700 S
Focal CHORUS SW800V Subwoofer Speaker
Focal Cobalt SW 800 S
Focal Cub
Focal Cub 2
Focal Electra SW 900
Focal iCub
Focal Profile SW 908
Focal Sub Utopia Be
Focal SW27A
Focal SW700
Fosgate Audionics FA10.0
Fosgate Audionics FA12.0
Fosgate Audionics FA15.0
Funk Audio FW 10.1
Funk Audio FW 12.1
Funk Audio FW 12.X
Funk Audio FW 15.1
Funk Audio FW 15.2
Funk Audio FW 15.3
Funk Audio FW 18.0
Funk Audio FW 18.0M
Funk Audio FW 18.3
Gallo Acoustics MPS 150
Gallo Acoustics TR–3
Gallo Acoustics TR-1
Gallo Acoustics TR-2
Gemini-Sound GSS-18
Genelec 5040A
Genelec 7050A
Genelec 7060A
Genelec 7070A
Genelec 7071A
Genelec 7073A
Genelec HTS3B
Genelec HTS4B
Genelec HTS6
Genesis Technologies G-928
Genesis Technologies Servo-Sub 2/12T
Genesis Technologies ServoSub 4/8
Gershman Acoustics SW-1
Goldmund Metis Sub
Green Mountain Audio Hammer Lite
Hafler VRM10S
Hafler VRM15S
Hafler VRM5
Hafler VRM6
Harman Kardon HKSUB 12
Heybrook HBS200 Subwoofer
Heybrook HBS200 Subwoofer Speaker
Home Theater Direct Level Three
Home Theater Direct Level Two
Hoodman asdf
HSU Research HRSW10V
HSU Research HRSW12V
HSU Research HRSW210
HSU Research MBM-12 MK2
HSU Research STF-1
HSU Research STF-2
HSU Research STF-3
HSU Research TN-1220HO
HSU Research TN-1225HO
HSU Research TN825
HSU Research ULS-15
HSU Research VF2 MK3
HSU Research VFT -2 MK3
HSU Research VTF-1
HSU Research VTF-15H
HSU Research VTF-2
HSU Research VTF-2 Mk2
HSU Research VTF-3
HSU Research VTF-3 HO Turbo
HSU Research VTF-3 Mk2
HSU Research VTF-3 MK3
Infinity Systems Alpha 1200s
Infinity Systems BU-120
Infinity Systems BU-150
Infinity Systems BU-2
Infinity Systems BU-80
Infinity Systems BU1
Infinity Systems BU2
Infinity Systems Cascade Model Fiftee Subwoofer Speaker
Infinity Systems Cascade Model Fifteen
Infinity Systems Cascade Model Twelve Black 10-inch 300-watt Powered Subwoofer Subwoofer Speaker
Infinity Systems Cascade Model Twelve Subwoofer Speaker
Infinity Systems CSW-10
Infinity Systems CSW-10 Subwoofer Speaker
Infinity Systems Entra Sub
Infinity Systems Entra Sub Two
Infinity Systems HPS 1000
Infinity Systems HPS-250
Infinity Systems HPS-500
Infinity Systems IL100s
Infinity Systems IL120s
Infinity Systems P252 Subwoofer Speaker
Infinity Systems Prelude MTS Sub
Infinity Systems PS-10
Infinity Systems PS-12
Infinity Systems PS-8
Infinity Systems PS-8 Subwoofer Speaker
Infinity Systems PS210
Infinity Systems PS210 Subwoofer Speaker
Infinity Systems PS212
Infinity Systems PS212 Subwoofer Speaker
Infinity Systems PS28
Infinity Systems PS28 Subwoofer Speaker
Infinity Systems PS312
Infinity Systems PS38
Infinity Systems PS410BK
Infinity Systems PSW310W
Infinity Systems SW-12
Infinity Systems TSS-SUB4000
Infinity Systems TSS-SUB450 Subwoofer Speaker
Infinity Systems TSS-SUB750
JA Audio JA-850S
JA Audio JA-SS10
JA Audio JA-SS12
JA Audio JA-SS7
James 10SX
James 110SDXP
James 210SDXP
James 62SDX
James 63SDX
James 82SDX
James 8SDX
James CINEMA 10
James CINEMA 12
James CINEMA 15
James EMB-1000
James EMB-1200
James EMB-1500
James EMB10
James EMB12
James EMB21
Jamo A 3SUB.1
Jamo A 3SUB.3
Jamo A 3SUB.5
Jamo A 3SUB.5 Subwoofer Speaker
Jamo A 7SUB
Jamo A-70
Jamo C 80 SUB
Jamo D 4SUB
Jamo D 600 SUB
Jamo D 6SUB
Jamo D 7SUB
Jamo D 7SUB Subwoofer Speaker
Jamo D 8SUB
Jamo E 7SUB
Jamo E 8SUB.2
Jamo E 8SUB.5
Jamo E6Sub
Jamo IW1060SW Subwoofer Speaker
Jamo IW860SW Subwoofer Speaker
Jamo Sub 1810
Jamo SUB 210
Jamo Sub 250 Subwoofer (Single, Black) Subwoofer Speaker
Jamo SUB 260
Jamo SUB 300
Jamo SUB 360
Jamo SUB 550
Jamo SUB 550 Subwoofer Speaker
Jamo SUB 650
Jamo SUB 6510
Jamo SUB 6510 Subwoofer Speaker
Jamo SUB 660
Jamo SUB 800
Jamo SUB-650 Subwoofer Speaker
Jamo SW-505E
Janis W1 Subwoofer
JATON MP600
JBL 050036922142 Subwoofer Speaker
JBL 1500 Array BG
JBL AS Sub
JBL ASB-6128V
JBL ASB6112
JBL ASB6115
JBL ASB6125
JBL ASB7118
JBL ASB7128
JBL B-380
JBL Cinema Soundâ„¢ CSS10 Subwoofer Speaker
JBL Control SB210 Subwoofer Speaker
JBL Control-19CS Subwoofer Speaker
JBL CSS11
JBL Digital D10
JBL DPS-10
JBL DPS-D115
JBL DPS12
JBL E150P
JBL E250P
JBL EON 518S
JBL ES150PW
JBL ES250P
JBL ES250P Subwoofer Speaker
JBL ES250PW
JBL GSUB 10
JBL HTI88 Subwoofer Speaker
JBL HTPS 400
JBL JRX-118SP Subwoofer Speaker
JBL MPS1000 Boat Subwoofers
JBL MRX518S
JBL MRX528S Subwoofer Speaker
JBL P10SW
JBL P12SW
JBL PB10
JBL PB12
JBL PRX518S Subwoofer Speaker
JBL PRX618S
JBL PS120
JBL PS1400
JBL PSW-D110
JBL PSW-D112
JBL PSW-D115
JBL PSW1000
JBL S120PII
JBL S1S-EX
JBL S2S
JBL Sub 550P
JBL Venue SUB10 Subwoofer Speaker
JBL VRX918S
Jensen JPS10W
Jensen JPS12
Jensen JPS8
Jensen JS-800
Jensen MS500 Sub
Jensen SW100
jl-audio f-113
jl-audio Gotham 213
JVC Csda1 170 Watt Max Compact 6.5-inch Powered Subwoofer Unit Subwoofer Speaker
KEF Audio HTB2 Subwoofer Speaker
KEF Audio PSW 1000 Subwoofer Speaker
KEF Audio PSW 2150 Subwoofer Speaker
KEF Audio PSW1150 Subwoofer Speaker
KEF Audio PSW3500 Subwoofer Speaker
KEF Coda S
KEF KC4BL C4 Subwoofer (Black) Subwoofer Speaker
KEF KUBE 2
KEF Kube-1
KEF Model 20B
KEF Model 30B
KEF Model TDM45B
KEF PSW 1000
KEF PSW 2000
KEF PSW 2500
KEF PSW 3000
KEF PSW 4000
KEF PSW 5000
KEF PSW3500
KEF Q-400 (Black Oak)
KEF Q400 (Cherry)
KEF Q400 (Walnut)
KEF R400b
KEF Reference 208
KEF Reference 209
KEF XQ60b
Kenwood 103SW
Kenwood 1050SW
Kenwood SW-15HT
Kenwood SW-306
Kenwood SW-36HT
Kenwood SW-39HT
Kenwood SW-508-ML
Kenwood SW103
KLH ASW-80
KLH ASW10-100
KLH ASW10120
KLH ASW12120
KLH AWS-110
KLH E-10DS
KLH E-10FB
KLH E-8DB
KLH E-8FS
KLH E-8FS Subwoofer Speaker
KLH PSW8100
KLH Rave-S12
KLH SW-12
KLH SW-910
Klipsch AW-800-SW Subwoofer Speaker
Klipsch CA-800-TSW
Klipsch IC-8T-SW2
Klipsch KSW 150
Klipsch KSW-10
Klipsch KSW-10 Subwoofer Speaker
Klipsch KSW-12
Klipsch KSW-15
Klipsch KSW-300
Klipsch KSW-50
Klipsch KSW100
Klipsch KSW200
Klipsch KW-100
Klipsch KW-120-THX
Klipsch LF-10
Klipsch LF-12
Klipsch P-312W
Klipsch RPW-10 Subwoofer
Klipsch RPW-10 Subwoofer Speaker
Klipsch RSW-10
Klipsch RSW-10 Subwoofer Speaker
Klipsch RSW-10d Subwoofer Speaker
Klipsch RSW-12
Klipsch RSW-15
Klipsch RSX-4
Klipsch RT-10d
Klipsch RT-10d Subwoofer
Klipsch RT-12d Subwoofer
Klipsch RT12D
Klipsch RW-10
Klipsch RW-10 Subwoofer Speaker
Klipsch RW-10d Subwoofer
Klipsch RW-10d Subwoofer Speaker
Klipsch RW-12
Klipsch RW-12 Subwoofer Speaker
Klipsch RW-12d
Klipsch RW-5802 Subwoofer Speaker
Klipsch RW-8
Klipsch SW-10 II
Klipsch SW-110
Klipsch SW-112
Klipsch SW-115
Klipsch SW-15 II
Klipsch SW-308
Klipsch SW-310
Klipsch SW-311
Klipsch SW-8
Klipsch SW-V
Klipsch SW112
Klipsch SW12II
Klipsch SWS
Klipsch XW-500d
Klipsch XW-500d Subwoofer Speaker
Krell Master Reference Subwoofer
Krell Resolution
Krix Seismik 5
Krix Seismix 1
Krix Seismix 3
Krix Seismix 3 Mk2
Krix Seismix 7
Krix Tektonix
Krix Volcanix
Lava LSP12
Legacy Audio Deep Impact
Legacy Audio LF Extreme
Legacy Audio Metro
Legacy Audio Pace Maker
Legacy Audio Point One
Legacy Audio Point One HD
Legacy Audio Powered Impact
Legacy Audio Thumper
Legacy Audio Xtreme HD
Leon Speakers A10-SUB
Leon Speakers Aaros A3
LINN Akurate 221
LINN Akurate 226
LINN Klimax 345
LINN Sizmik 10.25
Lyngdorf BW -1
M&K 350THX
M&K MX-105
M&K MX-125 Mark II
M&K MX-150THX
M&K MX-200
M&K MX-300
M&K MX-5000THX Mk II
M&K MX-700
M&K V-125
M&K V-1250THX
M&K V-75 Mark II
M&K VX-7 MK II
M-Audio BX10s Subwoofer Speaker
M-Audio GSR18
Mackie HD1501
Mackie HD1801
Mackie HRS120
Mackie HRS150
Mackie SRM1801
Mackie SRS1500
Mackie SWA1501 Subwoofer Speaker
Mackie SWA1801 Subwoofer Speaker
Magnat Betasub 20 A
Magnat Betasub 25 A
Magnat Betasub 30 A
Magnat Gamma Sub 120 A
Magnat Gamma Sub 220 A
Magnat Omega 250
Magnat Omega 300
Magnat Omega 530
Magnat THX Select S 300
Magnat Vector Needle Sub25A
Martin Logan Depth
Martin Logan Depth I
Martin Logan Descent
Martin Logan Descent I
Martin Logan Dyanamo
Martin Logan Dynamo
Martin Logan Dynamo 1000
Martin Logan Dynamo 300
Martin Logan Dynamo 500
Martin Logan Grotto
Martin Logan Grotto I
MB Quart D1000si
MBL 202 A
McIntosh HT-12
McIntosh PS112
McIntosh XLS112
Meadowlark Audio Blackbird
Meridian D1500
Meridian D2500
Miller & Kreisel K-11
Miller & Kreisel K-9
Miller & Kreisel KX-10
Miller & Kreisel V-850
Miller & Kreisel V-851
Miller & Kreisel VX-100
Miller & Kreisel VX-760
Miller & Kreisel VX-860
Mirage OMD-S10 Subwoofer Speaker
Mirage Omni S12 Subwoofer Speaker
Mirage Omni S8
Mirage OMNIS8B1
Mirage Loudspeakers BPS 240i
Mirage Loudspeakers BPS-150i
Mirage Loudspeakers BPS-210
Mirage Loudspeakers BPS-400
Mirage Loudspeakers BPSS-150i
Mirage Loudspeakers FRx-S10 BPS
Mirage Loudspeakers LF150
Mirage Loudspeakers MM-6
Mirage Loudspeakers MM-8
Mirage Loudspeakers OM-200
Mirage Loudspeakers Omni S10
Mirage Loudspeakers OMNI S10 Subwoofer Speaker
Mirage Loudspeakers OMNI S8
Mirage Loudspeakers OMNI S8 Subwoofer Speaker
Mirage Loudspeakers Prestige S10 Subwoofer Speaker
Mirage Loudspeakers Prestige S8 Subwoofer Speaker
Mirage Loudspeakers Substrata 1000
Mirage Loudspeakers Substrata 1500
Mission 70as
Mission 75AS sub
Mission 78AS
Mission AS-1
Mission AS-2
Mission MS10 Subwoofer Speaker
Mission MS8 Subwoofer Speaker
Mission MSM70ASA
MJ Acoustics Pro 50 MKII
MJ Acoustics Ref 150 MkII
MJ Acoustics Ref 200
Monitor Audio Apex AW-12
Monitor Audio ASW 110
Monitor Audio ASW 210
Monitor Audio ASW-100
Monitor Audio Bronze BX-W10
Monitor Audio FB 212
Monitor Audio FB-210
Monitor Audio FB110
Monitor Audio GSW-12
Monitor Audio PLW-15
Monitor Audio R370HD
Monitor Audio Radius R360
Monitor Audio Silver RS W12
Monitor Audio VW-8
Monster Cable Godfather Subwoofer
Monster Cable Monster Eleganza 15"
Mordaunt-Short 308
Mordaunt-Short 309
Mordaunt-Short 907W
Mordaunt-Short MS-909
Mordaunt-Short T-2000
Mordaunt-Short T1000
MTX Audio CT10SW
MTX Audio CT12SW
MTX Audio CT8SW
MTX Audio HTS28W Subwoofer Speaker
MTX Audio Lolita Subwoofer Speaker
MTX Audio PS-15
MTX Audio SUB8
MTX Audio SW1
MTX Audio SW1 Subwoofer Speaker
MTX Audio SW1010
MTX Audio SW1212
MTX Audio SW1515
MTX Audio SW1515 Subwoofer Speaker
MTX Audio SW2
MTX Audio SW2 Subwoofer Speaker
MTX Audio XTL210P Subwoofer Speaker
Nakamichi SW5
NHT 1259
NHT ASW8 Ci
NHT B-10d (B)
NHT B-12d
NHT Classic 12
NHT Sub One
NHT Sub Two
NHT SubOne
NHT SubOnei
NHT SubTwo
NHT Super 8
NHT SW10
NHT SW10ii
NHT SW12
NHT SW2Pi
NHT SW2Si
NHT SW3p
NHT SW3S
NHT U1
NHT U2
Niles Audio Corporation CM8SW Subwoofer Speaker
Niles Audio Corporation CM950SUB Subwoofer Speaker
Niles Audio Corporation CM960SUB Subwoofer Speaker
Niles Audio Corporation PRO-15SW Subwoofer Speaker
Niles Audio Corporation PSW800 Subwoofer Speaker
Niles Audio Corporation SW-300
Niles Audio Corporation SW300
nOrh Marble Subwoofer
nOrh Subwoofer MKII
OEM C-8SW
OEM PS-12
OEM SE-10SWD
OEM Systems C-8SW Subwoofer Speaker
OEM Systems SE-80SWD Subwoofer Speaker
OEM Systems SE10SW Subwoofer Speaker
Ohm N
Ohm N2
Ohm SB-1A
Ohm SB-2A
Ohm SB-4A
Ohm SB-5.2
Ohm Subwoofer for Satellite speaker
ONIX Rocket ELT SW-10
ONIX Rocket UFW-10
Onkyo Bass Reflex Powered Subwoofer Subwoofer Speaker
Onkyo SKW 110
Onkyo SKW-100
Onkyo SKW-204
Onkyo SKW-210
Onkyo SKW-50
Optimus PRO-SW100P
Optimus PRO-SW200P
Optimus SW 12
Optimus SW-14
Optoma DK-SW50 Subwoofer Speaker
Orb Audio Super Eight
Orb Audio Uber Ten
Osborn Monumental
Osborn T12
Osborn T15
Osborn T16
Osborn Twinultimate
Osborn Ultimate
Outlaw Audio ECS-10
Outlaw Audio LFM-1
Outlaw Audio LFM-1 EX
Outlaw Audio LFM-1 Plus
Outlaw Audio LFM-2
Outlaw Audio M8
Panasonic SBAS35K
Paradigm Reference DSP-3200
Paradigm Reference DSP-3400
Paradigm Reference PDR-10
Paradigm Reference PDR-12
Paradigm Reference PDR-8
Paradigm Reference PS-1000
Paradigm Reference PS-1200
Paradigm Reference PS-800
Paradigm Reference PW 2100
Paradigm Reference PW-2200
Paradigm Reference PW-2500
Paradigm Reference RVC-12SQ
Paradigm Reference SB 8
Paradigm Reference SB 8 Subwoofer Speaker
Paradigm Reference SB-80
Paradigm Reference SB-90
Paradigm Reference Seismicâ„¢ 10
Paradigm Reference Seismicâ„¢ 12
Paradigm Reference Servo 15
Paradigm Reference Servo 15 Version 2
Paradigm Reference Signature Servo
Paradigm Reference Signature SUB 25
Paradigm Reference SUB 12
Paradigm Reference SUB 15
Paradigm Reference UltraCube 10
Parasound PAL-1002 In-Wall Subwoofer
Peavey 15058
Peavey 18018
Peavey DJSSUB
Peavey SP118
Phase Technology DCB-112-SUB
Phase Technology DCB-115-SUB
Phase Technology DCB-210-SUB
Phase Technology FL-10
Phase Technology FL-12
Phase Technology FL-8
Phase Technology HV-1000
Phase Technology HV-1200
Phase Technology HV-800
Phase Technology HV101
Phase Technology HV121
Phase Technology HV81
Phase Technology PC-Sub
Phase Technology Power 10
Phase Technology Power 12
Phase Technology Power 15
Phase Technology Power 8
Phase Technology V-1200
Phase Technology WL-10
Phase Technology WL-12
Phase Technology WL-8
Phoenix Gold AS10SW Subwoofer Speaker
Pinnacle AC Sub 100
Pinnacle ACSUB400
Pinnacle Baby Boomer Plus
Pinnacle BabyBoomer Plus Subwoofer Speaker
Pinnacle BabyBoomer Subwoofer Speaker
Pinnacle CT 80
Pinnacle Digital Sub 150
Pinnacle Digital Sub 250
Pinnacle Digital Sub 600 Dual 12 Inch
Pinnacle DIGITALSUB150
Pinnacle DIGITALSUB600
Pinnacle PS Sub 150
Pinnacle Speakers SUBcompact 6 Subwoofer
Pinnacle Speakers SUBcompact 8 Subwoofer
Pinnacle SubSonic
Pinnacle Supersonic
Pinnacle Supersonic Subwoofer Speaker
Pioneer HTP-102SW
Pioneer S-DW1-K 150 Watt Powered Subwoofer
Pioneer S-W301
Pioneer S-W501
Pioneer S-W601
Pioneer TZ SW05
Platinum Audio Merrimack Subwoofer
PMC SB100
PMC TLE1
PMC TLE1S
PMC XB1-A
PMC XB2
PMC XB3
Polk Audio Atrium Sub 10 Outdoor
Polk Audio Atrium Sub-10
Polk Audio Audio DSW MicroPRO 1000 Subwoofer Speaker
Polk Audio Audio DSW MicroPRO 2000 Subwoofer Speaker
Polk Audio Audio DSW MicroPRO 3000 Subwoofer Speaker
Polk Audio Audio DSW PRO 400 Subwoofer Speaker
Polk Audio Audio DSW PRO 600 Subwoofer Speaker
Polk Audio Audio PSW10 Subwoofer Speaker
Polk Audio Audio PSW1000 Subwoofer Speaker
Polk Audio CSW100
Polk Audio CSW155
Polk Audio CSW200
Polk Audio DB 10 4ohm subwoofer
Polk Audio DSW MicroPRO 4000
Polk Audio DSW PRO 500
Polk Audio DSW Pro440 wi
Polk Audio DSW Pro550 wi
Polk Audio DSW Pro660 wi
Polk Audio PSW10 (Black)
Polk Audio PSW10 Cherry
Polk Audio PSW1000
Polk Audio PSW108
Polk Audio PSW110
Polk Audio PSW110 (Cherry)
Polk Audio PSW111 (Black)
Polk Audio PSW12
Polk Audio PSW120
Polk Audio PSW1200
Polk Audio PSW125 (Black)
Polk Audio PSW125 (CH) 12" 150-watt
Polk Audio PSW140
Polk Audio PSW150
Polk Audio PSW200
Polk Audio PSW202
Polk Audio PSW250
Polk Audio PSW300
Polk Audio PSW303
Polk Audio PSW350
Polk Audio PSW404
Polk Audio PSW450
Polk Audio PSW50
Polk Audio PSW505
Polk Audio PSW550
Polk Audio PSW650
Polk Audio PSWi225
Polk Audio PSWI8M
Premier premier acoustic pa120
ProAc ER1
Proficient IWS10 Subwoofer Speaker
Proficient PS12
Proficient S8 Subwoofer Speaker
Proficient S88 Subwoofer Speaker
PSB Speakers 12 Powered Subwoofer Century SubSonic 2i
PSB Speakers 5.25 Powered Subwoofer Stratus C5
PSB Speakers Alpha Subsonic 1 Powered Subwoofer
PSB Speakers Alpha SubSonic 5
PSB Speakers Alpha SubZero
PSB Speakers CHS212
PSB Speakers CWS8
PSB Speakers Platinum SubSonic 10
PSB Speakers Stratus Subsonic 3i
PSB Speakers Stratus Subsonic 7
PSB Speakers SubSeries 1
PSB Speakers SubSeries 200
PSB Speakers SubSeries 300
PSB Speakers SubSeries 500
PSB Speakers SubSeries 5i
PSB Speakers SubSeries HD10
PSB Speakers SubSeries HD8
PSB Speakers SubSonic 8
PSB Speakers SubSonic 9
PSB Speakers Subsonic III
Pure Acoustics XP 12-200 Subwoofer Speaker
Pyle PDIWS10 Subwoofer Speaker
Pyle PDIWS12 Subwoofer Speaker
Pyle PDIWS28 Subwoofer Speaker
Pyle PDIWS8 Subwoofer Speaker
Pyle PDSUB10
Pyle PDSUB8
Pyle PDSUB8A Subwoofer Speaker
Pyle PSBW18 Subwoofer Speaker
Pyle PSUB10
QLN Sub 82
QSC AD-S28Tw
QSC HPR151i
QSC HPR181i
QSC Ksub
QSC KW181
Quad L-ite Sub
Quad L-Subwoofer
Quad L2-Sub
QUADRAL SUB 160 DV
QUADRAL SUB 250 DV
QUADRAL SUB 400 DV
QUADRAL Sub 51 DV
QUADRAL SUB 67
QUADRAL SUB 77 DV
QUADRAL SUB 80
QUADRAL SUB 87 DV
RBH Sound 1010-SEP
RBH Sound 12-SE
RBH Sound A-10S
RBH Sound MCS-88
RBH Sound MS-10.1
RBH Sound MS-8.1
RBH Sound SX-10 R
RBH Sound SX-12 R
RBH Sound SX-88
RBH Sound TS-10AN
RBH Sound TS-10AP
RBH Sound TS-12AN
RBH Sound TS-12AP
RCF ART705AS
Rega Vulcan
REL Acoustics Q100E
REL Acoustics Q150E
REL Acoustics Q200E
REL Acoustics Q50
REL Acoustics Quake
REL Acoustics R205
REL Acoustics R305
REL Acoustics R505
REL Acoustics Stadium II
REL Acoustics Stadium III
REL Acoustics Stentor II
REL Acoustics Stentor III
REL Acoustics Storm II
REL Acoustics Storm III
REL Acoustics Strata II
REL Acoustics Strata III
REL Acoustics Studio II
REL Acoustics T1
REL Acoustics T2
REL Acoustics T7
REL Acoustics T9
Revel 15 Powered Subwoofer Sub 1.5 LE 1
Revel B12
Revel B120
Revel B15
Revel Concerta B12 Subwoofer Speaker
Revel Powered Subwoofer Embrace
Revel Sub30
Revel Ultima SUB30 Subwoofer Speaker
Rockustics BP Sub Subwoofer Speaker
Rockustics Punksub
Rockustics Punksub Subwoofer Speaker
Russound Complement SUB85 Subwoofer Speaker
Russound R10DT
Russound R10DT Subwoofer Speaker
Russound R12DT
Russound R8DT
Russound R8DT Subwoofer Speaker
Rythmik Audio D15SE
Rythmik Audio Direct Servo F12
Rythmik Audio Direct Servo F12G
Rythmik Audio Direct Servo FV12
Rythmik Audio E15
Rythmik Audio F12SE
Rythmik Audio F15
Rythmik Audio F15HP
Rythmik Audio F25
Rythmik Audio FV15
Rythmik Audio FV15HP
Salk Sound SongSub
Salk Sound Veracity HTS
Samson dB1500a
Samson dB1800a Subwoofer Speaker
Samson RS15S Subwoofer Speaker
Samson RS18S Subwoofer Speaker
Shahinian Diapason Ensemble
Shahinian Hawk
ShengYa LS-112
SLS CPSS12
SLS PSS12
SLS US115SW
SLS US118SW
SLS US215SW
SLS US218SW
Snell Acoustics PS.10
Snell Acoustics QBx
Snell Acoustics SUB 1800 THX
Soliloquy S-10c
Sonance CRKW Subwoofer Speaker
Sonance Son of Sub
Sonance SUB 10-150 Subwoofer Speaker
Sonance The Sub
Sonance The Sub Subwoofer Speaker
Sonance Virtuoso A800D Subwoofer Speaker
Sonic Impact Maxx Mini
Sonus Faber Cremona
Sonus Faber Gravis
Sony BRAVIA® HT-IS100 Subwoofer Speaker
Sony SA-W2500 10" 60-watt
Sony SA-W3000
Sony SA-W305
Sony SA-W3800 Subwoofer Speaker
Sony SA-WM20
Sony SA-WM200
Sony SA-WM250
Sony SA-WM40
Sony SA-WM500
Sony SA-WX700
Sony SA-WX900
Sony SAW-D100
Sony SAWD200
Sound Dynamics RTS 1000
Sound Dynamics RTS 1200
SoundMatters SUBstage 100
SoundMatters Substage 100 Subwoofer Speaker
SpeakerCraft 8.1Bas
SpeakerCraft 8.1BAS Subwoofer
SpeakerCraft 8.2Bas
SpeakerCraft 8.2BAS Subwoofer
SpeakerCraft Bass
SpeakerCraft BassX
SpeakerCraft BassX Dual 6 Subwoofer
SpeakerCraft BassX Dual 8 Subwoofer
SpeakerCraft BassX W10 Subwoofer
SpeakerCraft BassX-10
SpeakerCraft BassX-10 Subwoofer
SpeakerCraft BassX-12
SpeakerCraft BassX-12 Subwoofer
SpeakerCraft BassX-2 Subwoofer
SpeakerCraft BassX-8
SpeakerCraft BassX-8 Subwoofer
SpeakerCraft BassX-W10
SpeakerCraft BassX-W10 AcoustaCell
SpeakerCraft SUB8 Rox Subwoofer
SPECO SPEAKERS SW-12A
SPECO SPEAKERS SW-850
Spendor SUB-3
Streem SW-10
Sunfire High Resolution Series HRS
Sunfire SDS-12
Sunfire SDS-8
Sunfire SDS10
Sunfire SDSWiRX
Sunfire SDSWiTX
Sunfire Solitaire 10
Sunfire Solitaire 12
Sunfire SubRosa SRS-210R SYS
Sunfire SubRosa SRS-210W SYS
Sunfire True Sub Jr Subwoofer Speaker
Sunfire True Subwoofer
Sunfire True Subwoofer EQ
Sunfire True Subwoofer EQ Signature
Sunfire True Subwoofer EQ Signature Subwoofer Speaker
Sunfire True Subwoofer Junior
Sunfire True Subwoofer MKII
Sunfire True Subwoofer Signature
Sunfire True Subwoofer Super Junior
SVS 16-46PC-Plus
SVS 20-39PC-Plus
SVS 25-31PC-Plus
SVS B12-Plus/4
SVS CS-Ultra
SVS Model 16-46CS
SVS Model 16-46CS-Plus
SVS Model 16-46PC
SVS Model 16-46PCi
SVS Model 20-39CS
SVS Model 20-39CS-Plus
SVS Model 20-39PC
SVS Model 20-39PCi
SVS Model 25-31CS
SVS Model 25-31CS-Plus
SVS Model 25-31PC
SVS Model 25-31PCi
SVS PB-13 Ultra
SVS PB10-NSD
SVS PB12-ISD/V
SVS PB12-NSD
SVS PB12-NSD/2
SVS PB12-Plus
SVS PB12-Plus/2
SVS PB12-Ultra
SVS PB12-Ultra/2
SVS PC-Ultra
SVS SS Subwoofer
SVS Subwoofer
SVS SVS SB12 Plus
Swan Sub10
Swan Sub200
Sylvania SL-1200
System Audio SA-SE175
System Audio SA-SE200
Talon Audio Thunderbird
Tangent EVO E10
Tangent EVO E8
Tangent SB-10
Tangent SB-600
Tangent SB-8
Tannoy 108 TB
Tannoy 110 CS
Tannoy Arena
Tannoy B475
Tannoy B950
Tannoy EFX5.1
Tannoy Fusion TS10 Subwoofer Speaker
Tannoy Fusion TS8 Subwoofer Speaker
Tannoy MSUB 10
Tannoy PS110
Tannoy PS115
Tannoy Sensys-DCC
Tannoy SSub 15
Tannoy TD Sub
Tannoy TS10
Tannoy TS112 iDP
Tannoy TS12
Tannoy TS12 Subwoofer Speaker
Tannoy TS212 iDP
Tannoy TS8
Tannoy V8 Power Subwoofer Speaker
Tannoy VS10 BP
Tannoy VS15 BP
Tannoy VS15 HL
Tannoy VS18 DR
Tapco SW10
Tascam LF-S8 Subwoofer Speaker
TBI MAGELLAN VIP ACTIVE BASS MODULE
Technics SBAS100
Technics SBAS500
Theater Solutions Theater Solutions Home Powered Subwoofer
Theater Solutions Theater Solutions RT350 Home Powered Subwoofer
Thiel SS2.2 (Black Ash)
Thiel SS2.2 (Dark Cherry)
Thiel SS2.2 (Natural Cherry)
Thiel USS (Black Ash) Universal SmartSub
Thiel USS (Dark Cherry) Universal SmartSub
Thiel USS (Natural Cherry) Universal SmartSub
TIC Industries TF-50WG
Tivoli Audio Model Subwoofer Subwoofer Speaker
Tivoli Audio Powered Subwoofer for Model Two Radio
TOA Electronics FB-120B
Totem Acoustic Dreamcatcher
Totem Acoustic LIGHTNING
Totem Acoustic Storm Sub
Totem Acoustic THUNDER
Totem Acoustic Tribe Sub
Tunable Audio TA-10
Tyler Acoustics DS12
Tyler Acoustics FS-10
Tyler Acoustics FS-12
Tyler Acoustics PDS15s
Ultimate Sound ST-1212
Ultimate Speaker Company SW-1010
Ultimate Speaker Company SW-1212
UltraLinear ULH10S
UltraLinear ULH10X-65
UltraLinear ULH10X-8
Usher SW-102
Usher SW-103
Usher SW-210
Usher SW-212
Usher SW-520
VAF Research DC-S
Vandersteen 2Wq
Vandersteen V2W
Velodyne Acoustics CHT-10
Velodyne Acoustics CHT-12
Velodyne Acoustics CHT-15
Velodyne Acoustics CHT-8
Velodyne Acoustics CT 80
Velodyne Acoustics CT-100
Velodyne Acoustics CT-120
Velodyne Acoustics CT-150
Velodyne Acoustics CT-80
Velodyne Acoustics DD-10
Velodyne Acoustics DD-12
Velodyne Acoustics DD-15
Velodyne Acoustics DD-15 Subwoofer Speaker
Velodyne Acoustics DD-18
Velodyne Acoustics DEQ-10R
Velodyne Acoustics DEQ-12R
Velodyne Acoustics DEQ-15R
Velodyne Acoustics DEQ-8R
Velodyne Acoustics Digital Drive 1812 Signature Edition
Velodyne Acoustics DLS-3500
Velodyne Acoustics DLS-3500R / CHT-8R
Velodyne Acoustics DLS-3750
Velodyne Acoustics DLS-3750R / CHT-10R
Velodyne Acoustics DLS-4000
Velodyne Acoustics DLS-4000R / CHT-12R
Velodyne Acoustics DLS-5000R / CHT-15R
Velodyne Acoustics DPS-10
Velodyne Acoustics DPS-12
Velodyne Acoustics EQ MAX 15
Velodyne Acoustics EQ MAX 8
Velodyne Acoustics EQ-Max 10
Velodyne Acoustics EQMAX 12
Velodyne Acoustics F-1500
Velodyne Acoustics F-1800R II
Velodyne Acoustics F-1800XR
Velodyne Acoustics FSR 10
Velodyne Acoustics FSR 15
Velodyne Acoustics FSR-12
Velodyne Acoustics FSR-18
Velodyne Acoustics FSX-12
Velodyne Acoustics HGS-10
Velodyne Acoustics HGS-10X
Velodyne Acoustics HGS-12
Velodyne Acoustics HGS-12X
Velodyne Acoustics HGS-15
Velodyne Acoustics HGS-15X
Velodyne Acoustics HGS-18
Velodyne Acoustics Impact-10
Velodyne Acoustics Impact-12
Velodyne Acoustics Impact-Mini
Velodyne Acoustics MicroVee
Velodyne Acoustics MiniVee
Velodyne Acoustics MINIVEE 10
Velodyne Acoustics Optimum-10
Velodyne Acoustics Optimum-12
Velodyne Acoustics Optimum-8
Velodyne Acoustics SC-10
Velodyne Acoustics SC-12
Velodyne Acoustics SC-15
Velodyne Acoustics SC-600IFIC
Velodyne Acoustics SC-8
Velodyne Acoustics SC-IF/IC
Velodyne Acoustics SC-IW
Velodyne Acoustics SCIWDVR in-wall
Velodyne Acoustics SMS-1
Velodyne Acoustics SMS1
Velodyne Acoustics SPL 1500R
Velodyne Acoustics SPL-1000
Velodyne Acoustics SPL-1000 Series II
Velodyne Acoustics SPL-1000R
Velodyne Acoustics SPL-1200
Velodyne Acoustics SPL-1200 Series II
Velodyne Acoustics SPL-1200R
Velodyne Acoustics SPL-800
Velodyne Acoustics SPL-800 Series II
Velodyne Acoustics SPL-800R
Velodyne Acoustics ULD-15
Velodyne Acoustics VA 1512
Velodyne Acoustics VA 806
Velodyne Acoustics VA-1012X
Velodyne Acoustics VA-1210
Velodyne Acoustics VA-1215X II
Velodyne Acoustics VA-1250X
Velodyne Acoustics VA-8100X
Velodyne Acoustics VA-907
Velodyne Acoustics VDR-12BV
Velodyne Acoustics VLF-1012
Velodyne Acoustics VLF-810
Velodyne Acoustics VRP-1000
Velodyne Acoustics VRP-1200
Velodyne Acoustics VX-10
Velodyne Acoustics VX-11
Velodyne Acoustics WiConnect-10
Verity Audio Rocco
Vienna Acoustics Principal Grand
Vienna Acoustics Subson
Vincent Audio LS-112
Vincent Audio SSW-2
VMPS Large Subwoofer
VMPS The New Original
VMPS The Smaller
VocoPro SUB-1200
VocoPro SUB-1500
VocoPro SV-420 Karaoke Vocal Speakers and SUB 1200 Powered Subwoofer Subwoofer
Von Schweikert Research VR-S/1
Waterfall Audio High Force
Westlake Audio BBSM-10swp
Westlake Audio LC 8.1sw
Wharfedale AM-250 Sub
Wharfedale CR2-SUB
Wharfedale DIA 10 SX-SUB
Wharfedale Diamond PowerCube 10 Subwoofer in Black
Wharfedale Diamond PowerCube 12 Subwoofer in Black
Wharfedale Onyx-10SUB
Wharfedale PC Super 15
Wharfedale PC10+
Wharfedale PC12+
Wharfedale PC8+
Wharfedale PowerCube 12 150-Watt Powered Subwoofer
Wharfedale PowerCube 8
Wharfedale RS-10
Wharfedale SPC-10
Wharfedale SPC-12
Wharfedale SPC-8
Wharfedale SW150
Wharfedale SW150 Subwoofer Speaker
Wharfedale SW250
Wharfedale SW250 Subwoofer Speaker
Wharfedale SW300
Wharfedale SW380
Wharfedale Topaz 10
Wharfedale Topaz 12
Wharfedale Topaz 15
Wharfedale Topaz 8
Wharfedale Topaz SW-10 Subwoofer Speaker
Wharfedale Topaz SW-12 Subwoofer Speaker
Wharfedale Topaz SW-15 Subwoofer Speaker
Wharfedale VR - SUB 10
Wharfedale VR - SUB 8
Wharfedale WA-12SB
Wharfedale WA-8SB
Whatmough Monitors Hurricane
Whatmough Monitors Impulse2
Whatmough Monitors Synergy3
Whatmough Monitors Tornado
Whatmough Monitors Tornado2
Whatmough Monitors Typhoon
Wilson Audio Thors Hammer
Wilson Audio Watch Dog
Wilson Audio WHOW
Wilson Audio XS Subwoofer
Xindak SW-120
Yamaha CW115V
Yamaha CW118V
Yamaha CW118V 18" Club Concert Series Subwoofer Pair Subwoofer Speaker
Yamaha MSR400 Subwoofer Speaker
Yamaha MSR800W
Yamaha NS-SP1800 Subwoofer Speaker
Yamaha NS-SW210
Yamaha NS-SW210BR Advanced YST II Subwoofer - Each (Brown) Subwoofer Speaker
Yamaha NS-SW310
Yamaha NS-SW700
Yamaha NS-SW700PN Subwoofer Subwoofer Speaker
Yamaha SA-40
Yamaha Soavo-900SW
Yamaha SW-300
Yamaha SW10
Yamaha SW10 Subwoofer Speaker
Yamaha SW115V Subwoofer Speaker
Yamaha SW118-IV Subwoofer Speaker
Yamaha SW118V
Yamaha SW201
Yamaha SW218V Subwoofer Speaker
Yamaha YST - SW515
Yamaha YST SW105
Yamaha YST SW205
Yamaha YST SW305
Yamaha YST-FSW050 Subwoofer Speaker
Yamaha YST-FSW100 Subwoofer Speaker
Yamaha YST-FSW150
Yamaha YST-RSW300 Subwoofer Speaker
Yamaha YST-SW012 Subwoofer Speaker
Yamaha YST-SW015
Yamaha YST-SW100
Yamaha YST-SW150
Yamaha YST-SW1500
Yamaha YST-SW160
Yamaha YST-SW20
Yamaha YST-SW215
Yamaha YST-SW215 Subwoofer Speaker
Yamaha YST-SW216 Subwoofer Speaker
Yamaha YST-SW225
Yamaha YST-SW225 Subwoofer Speaker
Yamaha YST-SW300
Yamaha YST-SW315
Yamaha YST-SW315PN Subwoofer Speaker
Yamaha YST-SW320
Yamaha YST-SW325
Yamaha YST-SW325 Subwoofer Speaker
Yamaha YST-SW40
Yamaha YST-SW45
Yamaha YST-SW500
Yorkville A215S
Yorkville ES200P
Yorkville ES700P
Yorkville LS1004
Yorkville LS1208
Yorkville LS200P
Yorkville LS608
Yorkville LS700P
Yorkville LS800P
Yorkville LS808
Yorkville LS908
Yorkville NX200S
Yorkville PS110P
Yorkville PS18
Yorkville PS210P
Yorkville PS218P
Yorkville TS18
Yorkville TS18H
Yorkville UCS1
Yorkville Y118S
Zingali OSC 106
Zingali OSC 206
Zingali OSC 406
Websites (outside of ASR) that link back to my post:
2021-02-18 homeboi88 posted it https://www.reddit.com/r/hometheater/comments/lmp6uc 2021-02-18 phoenix_dogfan posted it https://www.reddit.com/r/audiophile/comments/ln6f49 2021-02-23 https://forums.audioholics.com/forums/threads/master-database-for-subwoofers.121337/#post-1463387
2021-02-26 https://forums.hardwarezone.com.sg/...t-home-theatre-recommendations-6468427-5.html
2021-03-13: Avforums mentioned it. https://www.avforums.com/threads/which-xtz-sub.2350291/post-29037339
2021-03-16 Erin mentioned my spreadsheet at the end of the video, and in the description
2021-03-16 JoeNTell reposted the link via his Youtube Community page: https://www.youtube.com/post/Ugykqh01AZgsdbStmqh4AaABCQ
2021-04-10: Avforums mentioned it. https://www.avforums.com/threads/bk-gemini-ii-frequency-range.2355467/post-29140107
2021-04-28: Around 22min mark, user mentioned my spreadsheet.
2021-07-16: Someone oh hifivision posted it https://www.hifivision.com/threads/subwoofer-comparison.85435/
2021-09-22: Around 1hr55min mark, user asked a question about my spreadsheet.
2021-10-26: Around 21min mark, a rep from Monoprice mentioned my spreadsheet.
2021-12-09: I found out that my spreadsheet was referenced several times at AVSforum https://www.avsforum.com/search/2471472/?q=sweetchaos&o=date
LearningToSmile
Very nice, when I was buying a subwoofer jumping between the various sources and comparing was a pain(at first I didn't realize for example that measurements were at different distances and didn't account for the difference). So this is a very useful resource.
Are you interested at all in indicating somehow the products that are technically discontinued but still occasionally in stock or available from dealers? I'm not sure if that's relevant for more manufacturers than SVS, but at least for them it makes a big difference because those are usually the best value by far.
Browsing the list I noticed that audioholics and data-bass measurements are completely identical, is this just good, compatible methodology or is one of the sources using other sources data? I'd expect at least minor measurement variation, but maybe it's easier than I thought to be consistent. If it's the same maybe it's worth combining the measurements into one line to de-clutter the list a bit.
There are also few models I could have sworn I saw measurements of somewhere that are not in the list, but you used the same sources I browsed and more, so no clue where I could have found them. I'll try to look for them.
somebodyelse
Thanks for putting that together.
It would be good to have rough price and availability for other parts of the world too as there are some significant and inconsistent variations. Rythmik having no EU distribution springs to mind. I know it can't cover everywhere, but there are probably a few representative blocks that will cover a lot of the world.
Why use a URL shortener in the link rather than the actual URL?
HooStat
Calabasas, CA
How about the JL audio v1 subs (F112, F113, etc)? Looks like just the v2 are listed. I don't know of any measurements though.
richard12511
You could make a Best Sub for $X section.
Split it into categories too:
Movies: Take 25Hz and spit out which has the highest SPL under/at $X.
Music: Take 40Hz and spit out which has the highest SPL under/at $X.
I'm not sure I agree with saying max spl at 25Hz means best for movies, or max spl at 40Hz means best for music. Better (imo) to show best for price and Hz. That way people can see what is best for them based on what frequency is their threshold for output limitation(based on budget and room size).
For example, for me, the best sub for both movies and music is the sub that has the most output at 10Hz, as that's where I'm output limited. Output at 40Hz is irrelevant to me, as I have unlimited output there. A sub that gives me 140db(with room gain) at 40Hz is 0% better than a sub that only gives me 130dB at 40Hz, as both will never see more than 120dB. On the other hand, a sub that gives me 100dB at 10Hz is better than a sub that only gives me 90dB at 10Hz, for both movies and music(though less so for music).
I learned this the hard way, at my own expense. I started with JTR professional subwoofers(Growler) which are optimized for 30Hz+ performance. I then went to JBL cinema subwoofers. My thinking at the time was that since my focus is music, 30Hz+ is far more important than sub 20Hz, so that's what I wanted to optimize. Eventually, I heard a lower tuned subwoofer(Funk?) that showed me what I was missing. The lower tuned subs gave up nothing in terms of "tightness", "control"(distortion and group delay well below audible thresholds), or "30Hz output" at even the loudest volume I would ever possibly listen. The higher tuned subs, however, did give up sub 25Hz performance, which was perceptible at high volumes. My thinking was somewhat correct. 30Hz+ is far more important sub 20Hz. My error was in thinking that a 140dB @40Hz sub would somehow sound better(tighter, more controlled, etc.) playing 110dB @40Hz. My current view(always subject to change) is that subs of sufficient quality, and after equalizing their frequency responses, will sound exactly the same at frequencies and volumes for which they can keep distortion well below audible thresholds. Perhaps it's not exactly the same, but I know for sure I can't tell them apart under blind conditions.
This will be different for different people, though, depending on their budget and room size. If I had a more commercial sized space with a much further back listening distance(8m), I'd probably go back to a higher tuned sub, like a JBL Cinema sub, or a JTR Orbit Shifter Pro, as they'd probably sound better for that application. Similarly, if I had a much smaller budget, I'd likely go for a higher tuned sub. Few movies have sub 20Hz content(ime), and little music has sub 30Hz content(ime), so if I'm gonna be 30Hz output anyway, then it makes sense to opt for a sub with 30Hz tuning.
sweetchaos
sweetchaos
The Curator
BC, Canada
Thanks for the feedback, everyone! :)
I know SVS has their outlet sale several times per year, where they bring back a discontinued model, for a short run.
It's an interesting idea, we need a lot more input/data for this to make sense.
Good observation...I also noticed that some subwoofer 'data-bass' data match 100% to 'audioholics' data.
Here's what I think happened:
Currently, James Larson measures subwoofers for Audioholics.
Previously, Josh Ricci measured for Audioholics.
Data-bass.com footer says "Site and data maintained by Josh Ricci and Kyle Keating".
Which means that Josh Ricci measured once, but posted on both websites.
Mystery solved.
No problem, I can cover Canadian and US market (if we need to separate those) (for now, all markets prices are converted to USD), but I'll need someone's input for other markets.
Because I can see how often other people are accessing it, and whether it was worth it for me to create or not.
I can see some insights into the frequency and location of users who visit.
Here's the latest stats:
Thanks, added.
If anyone else notices a model I didn't include, let me know and I'll add it.
I've added this for now, to give you a quick reference...
At no $ limit.
I'm sort of leaning towards getting rid of ZOD Audio, from my spreadsheet?
They are horn speakers, but really they're DIY option.
And I wanted to avoid DIY subs from this spreadsheet, which is why I didn't include DIY subs from data-bass.com.
Let me know if you think so as well.
pozz
Слава Україні
Editor
max spl at ...Hz
The lower the bass goes, the more of it I want. I feel kind of sad when I don't get a clean 20Hz for music.
Side note. Barely related to the discussion.
Nice going @sweetchaos
hardisj
Reviewer
North Alabama
I say don't put the DIY options with the powered subwoofer options. They aren't apples to apples. With DIY, you'll have to add your own amplification. Sure, not too costly but still not a fair comparison without that taken in to account.
sweetchaos
sweetchaos
The Curator
BC, Canada
I'm still curious what happened here. Maybe he just got tired of doing it? Hopefully nothing more serious than that.
No clue. Maybe he got tired of measuring 550lbs (250kg) subwoofers? That ZOD Audio's MAUL is a beast.
Erin, please preserve your health when measuring heavy subwoofers.
sweetchaos
sweetchaos
The Curator
BC, Canada
Took out ZOD Audio.
This data was taken from data-bass.com.
1. There's no website, so it's discontinued now? I don't know the full story of this.
2. It's also DIY, so it doesn't belong.
This changes the top-ranked subs to be:
hardisj
Reviewer
North Alabama
I was just wondering if anyone here might know what happened to him/his testing.
I bought a dang dolly for subwoofer testing. Those aren't the ones I'm worried about. It's the heavy tower speakers that scare me. :eek:
somebodyelse
Ah - I bookmarked the destination. I'm slightly surprised Google don't give you that, but I'm not a Google user...
What's the preferred contribution method for non-google-account people?
Pity - if anything I'm more interested in the DIY options than most of the commercial ones, and it's good to know how they compare. Not that I really need a new sub...
sweetchaos
sweetchaos
The Curator
BC, Canada
The simplest method I know is just to use Google Spreadsheet.
Update: It doesn't actually require you to be logged into Google!
I've made the spreadsheet with everyone having "editor" access, which means anyone can edit it (and contribute).
Here it is:
https://docs.google.com/spreadsheets/d/1RecmBnxcFrYXfTbwsWL4JYHrncTRsH89CpKbYD-8OqI/edit#gid=0
To add another currency, just use one of the blank columns.
Once you're done, I'll merge with my spreadsheet. :)
sweetchaos
sweetchaos
The Curator
BC, Canada
Improvements:
1. Added column "Passive", which indicates if the subwoofer requires an external amplifier to function (based on Erin's feedback)
2. Added column "XLR inputs", which indicates if the subwoofer has XLR balanced inputs. This is useful for people who have 'studio monitors' and want to connect to a subwoofer. (based on my own interest)
3. Added another tab "TableLegend", which explains all columns, and colour codes. (thanks to txbdan feedback)
