Subwoofer Comparison
Fairly new offerings:
Argon Berlin 10" at € 900 and 12" at € 1.100
If they deliver what Argon promises? (14-250 Hz ± 6 dB) and (13-250 Hz ± 6 dB), it seems pretty interesting...
To me at least, I had Arendal 1961 1S on my list....
I like the look
I think a spec like "+/- 6dB" is pretty meaningless.
I would never ever buy a subwoofer from a brand that only has two variants of, let’s be honest, rudimentary designed subwoofers.
I just put out there what they report if someone hasn't seen these and could find them relevant. Whatever brands promote, someone wold have to do a reality check before I rely upon specs anyway. Price + announced performance would make them contenders if independent measurements backs it up. No idea if that will happen.
Easier for me to check out these in person than Arendals (or SVS), and not having a separate listening room, they are more palatable. Good or not? Haven't seen any tests yet, but am aware they are out on the review cirquit. Whether they dare to ship them to those who counts for serious audiophiles remains to be seen.
Fair enough. Not sure how many generations they've been through, the Malmö series wasn't interesting to me. However rudimentary the design may or may not be (haven't seen them picked apart and dissected or measured, thus wouldn't know), if they are good they are good and if they are bad they are bad. A bit premature to write them off. Or promote them.
I'm not a basshead, and would believe these should fill in nicely for my purposes. If they are good (enough).
It looks like it has more features than most subs and that they actually took some effort https://argonaudio.com/blogs/insights/berlin-deep-dive the choice for a sealed sub and the ability to customize the crossover rolloff behavior, and the 3 band DSP to hopefully do something against room modes.
One thing I agree with you on is that co-located subs and mains is the way to go for stereo, most on these boards would not agree. See below, after being frustrated with small subs I ended up building some large ones
I agree with you. Of course, I am not part of the 67% majority.
I wonder what the vertical resonance frequency of the Berlin SUB enclosures is on their "specially designed rubber isolation feet"? A standard vibration force transmissibility curve would have been interesting to see. Are those feet soft enough to provide effective vibration isolation?
The 3-band DSP EQ seems limited to notch filtering, used to reduce the intensity of acoustic room resonances. That seems a bit limiting, but it's much better than nothing.
No mention is made of the cut-off frequency of the high-pass infrasonic filter. Once that's added into the signal chain, it might be expected that the group delay performance, which is highlighted in the brochure, will be significantly degraded.
In any case, below is the group delay curve for a closed-box subwoofer with F3 = 18 Hz. This F3 matches the specified low-frequency cut-off point of the 12-inch Berlin SUB 12 sealed subwoofer. The Berlin subwoofer's group delay at 20 Hz, which is about 15 ms, appears to be a little bit greater than what is shown below, which is 11 ms at 20 Hz. Of course, the natural response of the modelled sealed subwoofer does not include any DSP.
This should only be relevant if you are running subs and mains in parallel, without a x-over (highpass for you mains) in place.
The DSP latency affects things with or without a highpass filter on the mains. Its the time delay that's causing the problem, which puts the subwoofers a few feet (metres) behind the main speakers. For example, 6 ms of processimng latency delays the signal by the equivalent of 2.07 metres (6.8 ft). That seems relevant to correct time alignment of the two sets of sound radiating systems.
But I agree that small heavily DSP'd subs with too high Q and bad step response (ringing) may not be the best solution.
Do you have any examples of such? Note that any bandpass filter will show a "bad" step response with "ringing". It's just the nature of the transfer function. The "heavy DSP" may simply be adjusting the natural response of the sealed subwoofer to look more like that of a classical sealed loudspeaker with a maximally-flat response function. The transient response as such would be defined by that total composite transfer function, would it not?
Would be interested in BK Electronics sealed subwoofers (XLS200/300, XXLS400...) measurement.
Being sealed subwoofers, that would be relatively easy for the manufacturer to accomplish. A nearfield sound pressure measurement would more than likely suffice and provide sufficient anechoic chamber-like accuracy. Keele's method from the 1970s would seem to apply here: "Low-Frequency Loudspeaker Assessment by Nearfield Sound-Pressure Measurement" (JAES, Vol. 22, No. 3, pp. 154–162), which presents a loudspeaker test technique that depends on nearfield pressure measurements made in a nonanechoic environment, allowing extremely simple measurements to be made of frequency response, power response, distortion, and electroacoustical efficiency. The test setup, shown below, doesn't seem too difficult to achieve in practice.
Hi everyone,
I see that you guys are interested in the engineering of the Berlin Subwoofer, so I will try to answer them as good as possible! Maybe I can get the approval to post some more measurement graphs that are not in the deep dive or website.
First off, the Malmö Series is our budget friendly series, so it is quite basic from the engineering standpoint - but we think good enough for most entry level setups.
As for the Berlin Series, we introduced it, as we got the feedback from our retail partners that most people are not interested in buying subwoofers, as they are are considered bulky eyesores, boomy and not easily integrated. With the Berlin series we want to offer solutions to all those problems. As for the bulky eyesore, we chose the compact downfire design with simple colors and shapes - and of course high powered amp with a high excursion driver to get good performance. For the problems of being boomy - which is mostly group delay - we combine the sealed cabinet with an intelligent DSP to reduce group delay, more about that below. For integration we introduced Speakermatch, as not everybody has an amp or processor with a good subwoofer integration. Speakermatch is used to integrate the sub with any size or cabinet type full range speaker. In my personal experience, it works really well with making the subwoofer "disappear" - but of course, don't take my word for it. As part of this years EISA awards (which we won one for the Berlin 10 as Best Buy Home Cinema Subwoofer) we sent out lots of samples and hope for reviews and independant measurements coming soon. They are also on the way to retailers, so should you have one in your area, we of course invite you to be the judge yourself - as you should with any hifi equipment.
I have asked our lead engineer if he can provide some SPL measurements - and having one of the 12 inch subs at home for testing, I can say even for rather small size, they can go quite loud.
While on the surface the Berlin subwoofers seem quite rudimentary, the DSP and construction is quite advanced. The processing delay is 0.19ms so around 7cm, which we consider negligable. We don't rely on typical "heavy" DSP'ing with hard limiters or low-cutfilters to control the driver. Rather the DSP uses a “look ahead estimator”, meaning the DSP knows amp power reserves, woofer position and woofer speed. We can therefore handle max output and low end extension much more intelligentlly and at the same time get more of both, without introducing group delay or phase issues. The cut-off for the subsonic filter is at 10Hz, but it is used to get some more amp power overhead and activating it will also not introduce group delay. Edit: I got some of the infos wrong in the my tech materials, sorry for that! The lead engineer sent me a correction about the subsonic filter"the Subsonic (Infrasonic) filter introduces group delay by design. It's a 12dB/oct filter. Its purpose is to reduce excessive pressure build-up below 10 Hz in small rooms, which can affect turntables and may be undesirable for some listeners."
Edit 2: Additional notes from the lead engineer:
A word a about BERLIN Subs low frequency extension and subwoofer system integration. Room gain naturally boosts the lowest frequencies. For that reason, the target anechoic response of BERLIN Subs includes a gentle roll-off to -6 dB at 14 Hz, which we have found provides good in-room performance well into the infrasonic range. Of cause this depends on room size and leakage.
The goal of the BERLIN subwoofers was not to maximize infrasonic output, but to create a subwoofer that integrates easily with a wide range of systems and performs equally well with both music and movies. Extension into the infrasonic range is important because it minimizes phase shift and group delay effects around the crossover region, improving integration with the main speakers. A often overlooked problem.
This was also a key motivation behind the development of SpeakerMatch. BERLIN subs is our first products to incorporate this technology. Many passive loudspeakers exhibit a Butterworth-style low-frequency roll-off, and BW filters are far from optimal for crossovers. SpeakerMatch address this and achieve more predictable integration between passive speakers and subwoofers.
-Michael"
We understand that people might be skeptic with a relatively unknown brand like us comes out with subwoofers with all kinds of high claims on their performance. But that is kind of the point - if we just released another basic, low tech subwoofer nobody would care. That's why we spent around 4 years on this series to make something special, affordable with tech that solves real life problems.
If you have any more questions, I'd be happy to answer them - as long as the mod team allows. I am not here to advertise it, just to give facts and context :)
Best regards
Jasper
Nordic Hi-Fi / Argon Audio
Hi Jasper. I'm wondering how you manage to not introduce additional group delay when inserting the action of a 10 Hz infrasonic high-pass filter? Also, what order is the filter? Did you choose to use a 1st-order or 2nd-order HPF? The processing delay of 0.19 ms is very small, unusually so, I think, for a DSPed subwoofer. Can you provide some further details about how that was achieved?
I have forwarded the questions to the lead engineer and will post the answers as soon as possible :)
Edit: I have heard back from our lead engineer that he is working on white paper that goes into more depth over the deep dive that's online - and it should answer most questions here. I will get back with it once it is released. I can't say yet when that is...
Hi everyone,
-Michael"
Best regards
Jasper
Hello,
Please excuse me but English is not my native language.
I am currently considering replacing my current subwoofer (a Focal vented box monitoring sub).
Your Berlin 12 subwoofer looks very interesting, both technically and aesthetically (suitable for a living room), and offers what appears to be great value for money.
You mention that, despite their size, they can be quite powerful and loud—which is great.
It would be very helpful (if possible) to know the maximum SPL at 1 meter.High output is good, but what does the frequency response curve look like below 30–40 Hz at high volumes?
After all, the point of a subwoofer isn't just to produce mid-bass (40–80 Hz), but also—and above all—to deliver high-quality sub-bass.(Personally, I’m looking for response down to at least 30 Hz at -3 dB, even at high volumes.)
Unfortunately, I worry that the "sealed" design—compared to a ported/vented model—might not allow for that kind of extension (SPL) below 40 Hz (matching the mid-bass level) without significant distortion.
A chart (or curve) showing maximum SPL between 20 and 100 Hz would be useful to see if the bass output is truly maintained at low frequencies during high-volume playback.I often find that most subwoofers (especially sealed, compact models) claiming to reach below 30 Hz can only do so at low volume levels.
The only comparable numbers across subs are CEA-2010 at a defined distance and ground plane - brand "peak power" figures are marketing. If you extend the sheet, add the -6 dB extension point and record whether each measurement was ground-plane or in-room, otherwise the table will mix incomparable data. Output at 20-31.5 Hz is what separates the real subs from the small boxes.
For a 12-inch woofer, with Xmax = 10 mm, the handly SPL calculator at https://www.baudline.com/erik/bass/xmaxer.html produces:
An Xmax = 15 mm gives the following SPL, which is about 3.5 dB higher:
What are the peak SPLs that you are after? With a sealed subwoofer, more than one subwoofer may be required in order to achieve them.
To get a feel for different subs and how they measure under CEA-2010 there is a great test posted by a member here. https://www.audiosciencereview.com/forum/index.php?threads/i-measured-10-subwoofers.49042/ While CEA-2010 is the best we have I feel the distortion tolerance is very high.... ~13% at 20 Hz to pass. If you read all the detail in the tests on the link you will get a feel for what subs can and can't really do. Unfortunately the driving force is size (driver and enclosure) which everyone tries to work around but physics has it's limits.
Hi All, aside from SPL and frequency response, what is the most important spec for a subwoofer?
