Curvature
- Joined
- May 20, 2022
- Messages
- 2,072
- Likes
- 3,199
You need a way to integrate the subwoofer. This means setting an HPF and LPF for the crossover, measuring the acoustic response at your listening position, and then adjusting using EQ.Speaking of subwoofers (if it's the right section) I'll take this opportunity to ask some questions.
I have to replace my very old B&W ASW10 (S1).
Always reading positive reviews or tried SVS SB 2000 a disappointment, an annoying sound like "plastic" long bass that didn't follow the music... in practice it was always annoying as if it dirty the music, probably with home theater use it is better as it has a notable impact and SPL but on music we are not there, I tried every possible adjustment.
To orient myself on something more musical I looked at Rel Serie HT 1005 or Velodyne Deep Blue 10, have you had the chance to listen to them?
I could also play it safe and get the new B&W ASW10 S3 since I was very happy with the old model, but you know when you feel like changing it's a problem!
Thanks in advance.
This can also be done automatically through software like Dirac, if your input/output device is capable.
Just buying a sub and connecting it means leaving the results to chance. Integration is, like it or not, the same kind of thinking and work it takes to make a tweeter correctly play with a woofer. You are inadvertently taking on the speaker designer's role.
The results depends less on the sub itself, which is, compared to speakers, a fairly simple device, than your knowledge. Don't expect another sub to solve the problems you are experiencing.
