Adrenal, SVS, and Powersound as well.
Keep forgetting SVS has distribution there....PSA now does too?
I was just informed on here yesterday. I hadn't heard until then, but being in the US I'm not always up...Keep forgetting SVS has distribution there....PSA now does too?
A sub with bass management is a sub with dsp? Something like the kef kc62 for example?
Bass management would include a crossover to high pass the speakers with, and the KEF does appear to have that feature in the form of a high-passed line-out. Does your integrated amp have the ability to use such?
Have literally no idea..
This is the back of the amp if it helps
Not as much as the manual would, but perhaps the variable line level outputs to the sub, and the sub's high passed line outs back to the integrated to one of the line level inputs....but I'd check your manual.
(Ideally it would be thru a pre-out/main-in or tape loop)
I will check
How would that work? The sub would send the signal back to amp?
Yep. Thats consistent with what I stated above.My manual only says this
That will work. If it doesn't for some reason, or becomes a hassle, you could run your front speakers full range and match the subwoofer phase to them. You play a test tone at the crossover frequency and adjust the phase until it sounds like one single source playing the tone.Thats good!
So the line would be Streamer>dac>analogue signal>Sub>high pass>higher analogue signal>amp>amplification>speakers?
If this is correct, my speakers would not play the lower frequencies which will be handled by sub?
Thats good!
So just run the fronts full range and run the sub via preouts and manage the bass and crossover, delay, and phase on the sub to match the fronts. It's a very common setup that will work just fine.
the wide recognition that room correction and DSP are the next biggest improvements in sound quality
Well that bit in the manual doesn't account for feeding a high-passed signal back to the integrated amp. I took a look at your manual, I doubt the analog inputs will be suitable for a loop. You have the two rca inputs, but it doesn't appear either will work for passing the high-passed signal back to the integrated amp as you'll have the input set for the source (say optical input for example) and using the analog rca inputs will be separate from processing of the input source. Once upon a time a tape loop or processor loop would take care of such. You really don't have a good option for even inserting external bass management (like via minidsp) that I can see. Might ask Hegel....
By 'next big improvements', you mean 15 years old AV tech is about to breach the battlements of hifi-world? I'm not holding my breath.
For too many enthusiasts, the definition of hifi is 2 channels and direct signal paths.
cheers
