D
Deleted member 95443
Guest
Not sure this is right forum..
My first post .
I own the Yamaha AS701. Evoke 20 speakers.
I want to add 1 or 2 sub to the amp . My understanding this is difficult since the amp has fixed low pass filter shy of 100 Hz.
Can I connect the SVS or another sub from another manufacturer to the AS701 sub output and use either 50 Hz or 80 Hz. Would I get bass filtering issues if I adjust the sub to 100 Hz.
Considering the Wiim Ultra streamer …
I keep reading the sub connection is more intuitive for active speakers . Is this true ?
Would it be better to use speaker terminal B and by pass the Yamaha sub filter ? SVs tells me this is better , and I can use the extra spare terminals. Is this true ?
Read you need connect the sub (high level) to the same terminals like the speakers .
Or is it better to invest in the Wiim Ultra Amp . This surly has to be made for sub management.
Thanks !
My first post .
Thanks !
