Sub for Kali Audio IN-8 V2
King_Pin
Saskatchewan, Canada
I am in Canada and the Kali's aren't available here for another month or so.
I am more than likely ordering the speakers from Sweetwater or ZzSounds and having them shipped here.
I would rather not do that with a sub so I am thinking about using the JBL LSR310s or the Adam SubT10.
Leaning more towards the JBL for the reason that it has a lot more power and is closer in max spl to the Kali's and is available locally.
Is there anything in that price range with xlr in/out that I should be considering?
Kali IN-8 - 117db
JBL - 200 watts - max spl 113db 27hz -120hz
Adam - 130 watts - max spl 104db 28hz-120hz
Since you are going with sub anyway, why not choose the Kali IN-5 and a SVS 3000 Micro for example? Makes more sense to me.
Don't get any of those for 8-inch monitors. The specs (at least the Adam) is at -6db, not -3. They will not add any significant value aside from being able to place it in a more optimal position.
Rather looks at SVS, Monolith, HSU.. Save a bit if you have to, it really is worth it.
Room issues/nulls can make a small sub help with extension down to 25ish even with my in-8v2.
Case in point. I have a small sealed 8inch 110w episode subwoofer that I strategically placed in the room where it excites around 25hz the most. My setup is definitely better off because of it in the sub 30hz region. I will caveat that I use sonarworks DSP to even out response.
I should have put this in my first post but this is a computer setup for listening to music, watching movies etc. Not a professional application.
I have 2-21" subs for my main movie watching.
Sub is going to be placed under my desk and I want more extension down in the mid 20's. But being under a desk size is of importance and I'd rather not spend more than $500-600 CAD for it.
I was looking at the PB1000 or SB1000 but I lose my balanced connections.
I get that, it's actually the reason I have the Adam T10s in the office. I've just gotten spoiled by my HT sub since I got the Adam.
After looking at Erin's measurement of the Kali, they go down to 44Hz, the Adam and JBL are both 32Hz at -3db. So you would still get a bit of extension.
I was looking at both of them at the time and, it's really hard to find data.. What I've scalped on the internet is:
Code:
        T10s     LSR310
-3db    32hz     32hz
-6db    28hz     --
-10db   --       27hz
And yeah, the JBL looks to get louder by the rated power.
Code:
        T10s     LSR310
-3db    32hz     32hz
-6db    28hz     --
-10db   --       27hz
Really what I should do is just build one. I could build a sealed 10-12" with amp and driver for probably $250-300. I'll have to see if there's any premade plans already on AVSguide. I can live without the sub for a while.
Why bother with a subwoofer for the 8" kali's? They go down to 35 hz... Isn't that enough?
the need for a subwoofer is not just to have low frequency extension, it's to reduce harmonic distortion and intermodulation distortion allowing you to listen at a much higher level without the speakers sounding like crap.
it's not really optional imo.
I just checked out the PRESONUS TEMBLOR T10 sub and wow it has the specs of the SVS stuff but not as powerful. :cool:
And it's available right away in Canada unlike the JBL.
https://www.sweetwater.com/store/de...-temblor-t10-10-inch-powered-studio-subwoofer
  • 10" Composite Low Frequency Driver
  • 110dB Continuous SPL
  • Maximum Peak SPL: 113dB
  • 250 watts of Class AB Amplification
  • Variable 50Hz to 130Hz Low Pass Filter
  • 1/4" TRS Bypass Footswitch Jack
  • Continuously Variable Input Gain
  • Phase Switch
  • Pass-Through For Additional Connections
  • Reinforced MDF Cabinet with Bracing
  • 20Hz to 200Hz Frequency Response
