Sub 25K active speaker/system choice
JRS
Albuquerque, NM USA
My bad, I was thinking they were active. They should be. :cool: Maybe 750W for the 4 bass modules and 400 for the rest should do. Per side of course. Well thanks for pointing that out. I guess I'll retract the rec even though if I were looking at a dynamic driver system, that would be on my short list. Cost no object: YG Acoustics Sonja XVi. Think those are like a quarter million. Not that the OP has made anything but excellent choices, I would prefer a loudspeaker just bristling with high tech and looking the part.:D
CMB
Here's my late vote: https://www.perlistenaudio.com/products/s7t/
16 to 18K leaving $$ for room treatment and if it were me, some kind of beautiful carpet for the area of first reflections. Sub should you find it necessary. This thing just bleeds SOTA. (Your floor made me think of these, not as a reason).
View attachment 178371, w
Is it just me, to whom those drivers always reminds me fake copies of Louis Vuitton :) ?
onion
First BAACH owner I have seen post here. Is it as good as it is touted--assuming one has narrow directivity speakers? I have even entertained making a trip to NYC just to hear it setup. Several reviewers who I respect say it gets no better when setup properly.
I think it is amazing. I know some prefer multi-channel but I have listened to multichannel audio in my home cinema setup and the 3d performance of Bacch is on another level. With Bacch, sounds from instruments and vocals emanate from a point in the 3d sound-field that is easy to localise and not confined to the speaker planes.
So maybe some advantages for the A16 emulation of multi-channel D&D's in a studio over a two channel Bacch emulation of 8341's taken in a home listening environment.
Just to clarify, the Bacch module I really like is where it uses real loudspeakers, and does not emulate them (Bacch-3d Sound). The headphone module (Bacch-hp) may be similar to the A16. I haven't heard the A16 - may have to arrange a demo for this...
Worth Davis
I'm very interested in LX521 as well, and yes, linkwitz.store sells almost done setups. It's really the look of the "head" (which is purposely designed like that, I know) that makes it difficult to project it in my living room. If I could find a way around it, I might want to try this later. So you've had kii three and lx521 and kept the linkwitz. What made you take this decision ?
As for genelec look, it's really personal indeed. I love the W371A + 8351B combo.
Didn’t own the kii3, my friend is a dealer for them.
L
lherrm
Reunion Island
From my impression maybe worth wait Thomann for a quote, they usually are quite a bit cheaper than others, for this price range the 1-2% difference can be quite hefty
Here's Thomann quote :
8351B : 3360.50 € (excl VAT) x2
W371A : 8352 € (excl VAT) x2
So a total of 23425€ excl VAT
13.8% more expensive than my french dealer !
Ordering soon. W371A available in march, 8351B in May !
L
lherrm
Reunion Island
Thanks for you suggestion, but I don't like the look, don't know the brand much, and favor active speakers anyway (would have made an exception for Salon2), plus it would probably need subs to be full range flat.
Reactions: CMB
L
lherrm
Reunion Island
Thanks to you, I'll be trying BACCH in the next few days, Intro version, with the Focal.
Will see with the results if I keep it and will also check with the Genelec when I get them.
CMB
Just curious, how do you get those delivered to the Réunion island?
Reactions: YSC
L
lherrm
Reunion Island
I think it'll be by plane. The french dealer is looking for a "transitaire". I guess it will be expensive.
W371A are heavy (61kg each).
Reactions: CMB
YSC
wonders will it ended up like the Thomann quote if so.. but yea, plane transport such huge fragile stuffs is expensive
L
lherrm
Reunion Island
Thomann won't match the competitor's offer. Waiting for shipping quote (and Genelec announcement) to go further.
L
lherrm
Reunion Island
1500e for the shipping (170kg - 375lbs), by boat, 30 days.
So I'm looking at (20.5 + 1.5) * 1.23 (23% tax and customs fees) = 27k total delivered.
I can't help but having quite high expectations. Which should lead to delusion.
YSC
well if you are biased to feel it sound like heaven, it's good delusion no?
CMB
I think to remember that you not even listend to the combo yet?
I didn’t dare to suggest, but wouldn’t you start with a pair of white 8361? You would save in terms purchase price and transport. I can’t complain about sound, bass, volume, looks. Our room sizes seem comparable.
Then if you shouldn’t be satisfied… you still could add the W971 in a second step based on onsight observation.
CMB
Maybe, a stupid question again, I don’t remember you having mentioned the costs for the GLM kit. Not that it is considerable, but just that you don’t forget to order it ;-).
L
lherrm
Reunion Island
I would order 8351B instead of 8361A then (I think the first in horizontal position on top of the W371A looks perfect).
Yeah, it would probably be a smart move.
But I would like to go to another planet compared to what I already have.
Not sure the main could do that without the sub.
Reactions: CMB
L
lherrm
Reunion Island
Already ordered and at home :D (delivered in 3 days from Germany ! about 380e shipping & tax included).
Reactions: CMB
CMB
Just seing that each W371 is supplied with GLM user kit.
L
lherrm
Reunion Island
Really ? I have 2 GLM sets to sell then, lol.
That's right :
I'll return the one I just got.
