Stylus Wear
Mulder
Gothenburg, Sweden
I happened to come across this article by chance, which discusses the wear and tear of turntable needles. In short, it states that the tip of a turntable stylus wears out much faster than is generally assumed. It’s often said that you should replace the stylus after about a thousand hours, but according to this article, wear begins to become a problem as early as 200 to 300 hours, and the stylus should ideally be replaced after a maximum of 600 hours—though even that is already on the late side. Should we assume this is accurate, and can we assume it applies to all needles, or are there differences between needles of varying quality and brands? As far as I understand, there are no more comprehensive studies on this, but if the article is to be believed, wear and tear is a much bigger problem that sets in much earlier than I, at least, had thought. https://www.****************/2026/0...g-records/?utm_source=fb&utm_campaign=comment
The average flat on a worn diamond spherical tip measured .00145". Even this amount of wear results in distortion, increased noise and excessive record wear. To obtain a flat of .00075" required 140 hours of use. To obtain a flat of .001" required 300 hours of use. To obtain a flat of .00125" required 700 hours of use. To obtain a flat of .0015" required 1,500 hours of average use; this degree of wear resulted in reduced tonal response, high noise level, greatly increased distortion and a considerable amount of record wear.
IA assisted:
Stylus Profile TypeAverage Lifespan (Listening Hours)Key Characteristics
Conical (Spherical)300 to 500 hrsWide but shallow contact; rugged, ideal for older/worn records or DJing.
Elliptical300 to 600 hrsStandard ovoid shape; great price-to-performance ratio, slightly more demanding on record condition.
Hyper Elliptical500 to 800 hrsThinner intermediate profile; improves high-frequency response and reduces wear compared to standard elliptical.
Shibata800 to 1,200 hrsLarge vertical contact area; highly detailed sound, minimal distortion, and enhanced record preservation.
MicroLine / MicroRidge1,000 to 2,000 hrsUltra-precise geometry (copies the original cutting lathe); record-breaking longevity and surgical detail (requires meticulous alignment).
No. The article contains unbenchmarked measurements of stylus wear and asserts that increased wear correlates with degraded performance, without providing any evidence of measured degradation.
So it's an opinion piece based on a commonsense assumption, dug up from 70 years ago and republished by a, erm, stylus manufacturer.
I don't find the AI output helpful either, no references given so it's really just slop.
I used a Nagaoka MP500, which I think is a microline although it is billed as a 'line contact'. Nagaoka say degradation starts after 250 hours. Subjectively, I'd say that's about right.
Replacement stylus is around £250 so a pound per hour of listening or about 80 pence to listen to a whole album.
I decided that was unsustainable so I bought all my favourites again on CD. Cost to play them is now zero and, with the odd exception, better sound quality too. Plus no further wear on my records which are an appreciating asset.
well, i wouldn't use Nagaoka :-), remember that sell styluses is a business anyway (that lifespan is absolutely ridiculous).
The market for used records wouldn't exist; they would be meant to be used for a couple of years and then thrown away, and it's far from that.
I had lots of different brands back in the day, Nag were my favourite.
Bear in mind 250 hours is where sound begins to degrade. You could get another 250 out of it without serious SQ issues. But I was fussy.
I think Nagaoka are just honest about stylus life. I see some manufacturers claiming 2000 hours, which is ludicrous. Of course those are expensive MC cartridges and no-one wants to pay thousands out to only get 500 hours of clean sound before it needs to get sent away for a £500 re-tip. I've encountered people who seemed blissfully unaware the stylus was knackered, even dealers, when demoing to potential customers. I think partly because vinyl can sound really ropey sometimes anyway, so they struggle to discriminate.
Not sure what you mean about the records? It's the stylus that degrades not the record unless you play it a lot with a real nail. Bought a lot of second hand records, very occasionally you do get one that's got groove damage or has no high frequencies left on it. It is rare IME though.
Until proven other wise by documented measurements for a specific model, the needle is still good until you hear that it is not.
Keeping it clean is all that matters.
Case closed.
>Audio-Technica's Shibata styli are built using a nude construction. This means the tip is made from a single, solid piece of diamond rather than a cheaper bonded tip<
The disconnect for me on this subject is the materials. Diamond is among the hardest substances on the planet, vinyl is fairly soft. I can see gunk accumulating on the stylus as a long-term issue . . . but my record collection is clean. Kindly correct my science on the subject here.
Hi folks.
Nice to see a stylus thread for a change.
I have a Nagaoka MP-110 (successor to the MP-11) which is fitted to a Linn LV V tonearm (the bottom of the range but still nice enough) on a CJ Walker CJ55 turntable.
I can remember about 11 years ago when I last used it regularly, being really disciplined about recording how many album sides I had played with it. I used one of these clickers seen below:
This thread prompted me to look again at the estimated lifespan of the Nagaoka JNP-110 stylus. From Nagaoka:
"The stylus replacement interval varies depending on the using condition. But for general use at home, the reference time is 150–200 hours in which the stylus begins to wear and the tone quality deteriorates. Recommend replacing the stylus as early as possible to enjoy clear tone for a long time and not to damage the disc grooves."
The Nagaoka Nagaoka JNP-110 uses a 0.4 x 0.7 mil bonded elliptical diamond stylus tip mounted on a lightweight aluminium alloy cantilever. It's a cheap enough stylus too at around £50 for the cheapest I've seen online today. That's very good as they are more often around £80. I bought the MP-110 as an upgrade to the Audio Technica AT95E as I had issues with inner groove distortion.
Both cartridges were meticulously setup up with a variety of equipment and I sampled audio from both via a USB analogue to digital converter. The samples were then taken into Audacity for analysis. The difference regarding the improvement in inner groove distortion was significant. A test LP was used for this purpose.
The sound from the Nagaoka MP-110, Linn LV V, and CJ Walker CJ55 is truly lovely. Still, I'll take my Marantz CD players any day of the week! :D
Kind of a side topic, but I worry a lot more about the cleanliness of my styli than I do about wear. I know that I will periodically need to replace a stylus just like I know I will have to replace the tires on my car. But without a good way to actually look at the stylus you will never really know if your cleaning process is really getting it clean. I invested in a digital microscope a while ago and I kind of enjoy using it every week or so to take a look. It only takes a few minutes. Here's a couple of photos of the screen showing my AT VMN40xML stylus. I use TOMLOV DM9. Here's a link: https://www.amazon.com/dp/B08G4Y6C65?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
Nice images and thanks for the link. Here's a thread you may find useful:
