egothrasher
- Joined
- Jul 17, 2020
- Messages
- 32
- Likes
- 11
So I just got all my equipment in and need help with setting up my speakers and sub.
My setup is Laptop > DAC (usb) > Subwoofer (RCA) > Speakers (Speaker wire - RCA Single).
When I set it up like that, my studio monitors just make a white noise/crackling. I know the monitors work as I have connected them directly to the DAC. So I believe my issue is the cable I made.
I made a cable from RCA to speaker wire. Attaching the positive part of the speaker wire to the sleeve in the RCA cable wire. Then attaching the negative speaker wire part to the other rca cable wire not in the sleeve. I've attached the wire to the high level outputs of the sub.
Any and all help is appreciated.
