There are several sets of variables involved here:
1. As mentioned, ambient noise and people's sensitivity to hiss vary. Listening distance and room acoustics are some other factors playing a role in this.
2. Excessive hiss may be encountered when:
a) there are ground loop issues with the cabling (primarily when speakers have switch-mode power supplies, like the JBLs)
or
b) input sensitivity is set too high in general.
Regarding 2b), note that input sensitivity adjustment facilities on active speakers vary greatly - a few have none at all (but may differ between balanced and unbalanced inputs, like the Focal Shapes), some 12 dB of range (typically between -10 dBV and +4 dBu), others 24 dB, and some can be turned down pretty much all the way to zero. Models with DSP may have switchable ADC full-scale input level (e.g. the JBLs again, about 2 Vrms / +8 dBu vs. +20 dBu) plus digital level control.
BTW, if anyone wants my old Tascam VL-X5s (230 V) as a fixer-upper project, you can have them for whatever postage is from Germany to your place via DHL (preferably within the EU, SEPA bank transfer), assuming their boxes are still in my parents' attic. One had occasional issues with a duff relay on the woofer (a known issue in certain lots), the other emits some buzz that I'll attribute to a bad (or not properly soldered) cap. Always been like that, was a closeout special at Thomann way back when. They require balanced connections, too. But hiss, hiss never was an issue with them - in fact they have less of that than even my current O110s! Be warned that getting into them requires some trickery and brute force, being screwed and glued shut. It's just that they're probably not getting any better in my basement either, and I haven't used them for months now.
or
