Alchemist_
- Joined
- Mar 7, 2020
- Messages
- 153
- Likes
- 23
The store says the hiss level depends on the volume knob. JBL MK2 306
New owner of a pair of Mackie MR524 with A/B amps, i can comfirm that they have no hiss
Everyone says that. On the IN-5 you can get the hiss even lower by lowering the volume knob from the middle a little bit, but it's already really low. On the JBL even with a lowered volume and having the source gain as high as possible, there is hiss. Also disconnected from a source there is hiss. Same with the older Kali monitors. Turning down the knob on the JBL 3 series or old Kali monitors doesn't work to reduce the hiss enough and still have enough reasonable volume, because for most to get rid of the hiss you have to turn it almost all the way down.
Yes, everyone says the hiss level depends on the volume knob. (JBL MK2 306) probably because it is true
A quieter room will not give me the results that you are claiming
There is no audible hiss on my 1st gen LSR-305's at 50% gain and the hiss DOES increase with gain setting and is only audible near maximum gain
Turning down the knob on the JBL 3 series monitors "DOES" work to reduce the hiss enough and still have enough reasonable volume
If your pair is defective, that does not mean that my pair is defective
By a proper choice, do you mean that there are only a few models listed?This graph makes sense to compare brands in-general, but in terms of making a choice properly, it's quite useless.
Same brand can have very high-hiss and low-hiss models of course (i.e. Yamaha MSP series vs HS series).
As a tip, if you use same spreadsheet, select the column, and select "sort a-z", you can sort the actual speaker models from lowest noise to highest.
Having said that, some of these measurements seem a bit questionable to me tbh.
Mine hiss even without any input.
I mean, the graph sorts by brand. You don't choose a brand when getting speakers, you choose a model.By a proper choice, do you mean that there are only a few models listed?
Can you explain what you mean by the measurements being questionable?
Back in the day, the world of analog, you always got a 'hiss' filter for reasons. Looks like we've made a lot of progress over the years. Maybe what is needed is a Dolby circuit for active loudspeakers. LOLCan confirm. Have had two pairs of LSR 305's at different times, there is audible hiss at 1m distance in a quiet room, with no input signal and low gain.
Very true. In their defense though, for their use case, the JBLs have their well earned place. They're still by far the best accurate active speakers in their price range in terms of overall sound, if you have the space to place them 2+ meters away.Back in the day, the world of analog, you always got a 'hiss' filter for reasons. Looks like we've made a lot of progress over the years. Maybe what is needed is a Dolby circuit for active loudspeakers. LOL
In 2021, how a supposedly reputable loudspeaker company can offer this sort of thing, and how anyone can recommend a loudspeaker that comes with its own hiss, is something I'll not hope to understand.
Its fine for me, I use them as surrounds and with movie/gaming content playing I don't hear it anymore. But if they were on my desk and there were silent moments I would hear it for sure.Can confirm. Have had two pairs of LSR 305's at different times, there is audible hiss at 1m distance in a quiet room, with no input signal and low gain.
Some people might not hear it due to age, or listening 5m away, or something else, but the self noise from the integrated amp is definitely there, and quite loud.
Hear (nice play on words, eh?) is what I don't understand. The entire (or mostly entire) ASR loudspeaker thing is to determine who is doing the best of the best engineering. So in this class, the class of 2-way self-powered shoebox monitors, what do we have? Loudspeakers measured and graphed and ranked (or at least judged) based upon how well they fit an 'ideal' wave propagation' schematic. Then, based on that, can be recommended or not, depending upon how they match these ideal graphs..., but with the little caveat, "Just don't sit too close to them because they make their own sound, and that might annoy you at softer SPL, unless you can train yourself to psychologically ignore it, or are too old to hear the defect!"Very true. In their defense though, for their use case, the JBLs have their well earned place. They're still by far the best accurate active speakers in their price range in terms of overall sound,
Maybe it's just a simple price point thing. Your 8030c is a serious shoebox for serious dollars, from a totally reputable and totally serious company (as far as I can tell). On the other hand, you'd think that JBL would be interested in eliminating self-generated noise from their 'studio monitors'--which are marketed as capable instruments to be used for mixing et al. But, then again, the small JBLs don't cost as much as Genelecs.8030c, no hiss in dead silent room at 1ft
I believe it when I hear it. My 8030C had noticeable hiss especially at 1 ft.8030c, no hiss in dead silent room at 1ft
In Genelec model line it's actually lower tiered speaker. When I was in contact with Genelec about hiss issue they recommended going up to more expensive models for less hiss.8030c is a serious shoebox for serious dollars, from a totally reputable and totally serious company (as far as I can tell).
I don't wanna to be rude but you should consider checking out your ears at audiologist maybe(that's really concerning)? I've had Genelec 8030 and heard hiss even at 1m away from them and my room wasn't really the quietest one at that time. I replaced them with Neumann KH120 and it is better but still sometimes noticable at night.8030c, no hiss in dead silent room at 1ft
