Streamer with a good app? digital only
locoliberty
Looking for a streamer recommendation with a good app for spotify/tidal connect, supporting tidal MQA. Also want it to have AES output. Dont need a DAC in it at all as ill connect it to my D90
Tried this MOON MIND2 and the app is soo terrible i cant bring myself to keep it. Open to recommendations under like 2k. Either that i replace my whole pre-amp to something with a built in streamer and DIRAC
I guess just trying to cover all the options. There are things that play on "max" on my hifi rose rs201 that the mind2 only plays on "high". So /shrug
I don't know the answer to your question, but can may make the choice a lot easier for you. Aes output is hardly ever featured on a streamer and easily circumvented as there are spdif to aes converters, should you really need one.
That opens up the whole streaming market to you, where ime the main differences are in app stability and usability. I rate the WiiM ultra highly and use it daily. I hear good things about Eversolo, but haven't used it myself.
A third contender could be Bluesound as it also has Dirac, but my impressions from using it and reviews here, is that it's software and user interface is ok rather than great.
High end streamers ime are really not worth it: you pay a premium for a worse user experience and a sound that's equal to the WiiM or Eversolo. If you want to be 100% sure, you could use the digital output like I do, but it really is more about convenience than an audible difference.
Eq is where differences can be made. For example I used to eq slots in the WiiM streamer to eq my speakers for the room.
Hope this helps.
I am unfamiliar with streamers with an AES output.
Consider whether you have any options to use an adapter for the AES input on the D90.
If so, you may be able to connect a digital output from a WiiM streamer to the AES input.
Is MQA even relevant at this point? I don't think TIDAL supports it at all anymore.
there are still some old tracks on Tidal that are considered "MQA compatible" and lid the MQA led on my SMSL PO100
Chase - Twinkles (for example)
I've used Allo for years now.
I have some tracks on a usb stick and also use tidal on it.
Control it with Squeezer and run picoreplayer.
Highly customizable... So it should cover anything you want.
I find the app a bit weird... But now I just got used to it.
I believe you can download many different apps for this player... But haven't tried any other... Though I know one of my friends run Roon on it and is very satisfied.
From Tidal:
Why is my digital to analog converter (DAC) still showing tracks are being played in MQA?
There were some tracks that were only delivered in the MQA format from content providers when we made this change. In these cases, the FLAC files available for streaming are produced from an MQA source file and certain DACs read them as MQA files.
From Tidal:
Are these FLACs declared as such openly? If not, it's basically a lie.
We've had a few streamers. Native connect function is important to us.
Using Spotify app or Qobuz app etc is vastly preferable to us than to some inbuilt interface in a Streamer App.
Few sensibly priced ones seem to do both Spotify Lossless Connect and Qobuz Connect it seems.
The newly released Fosi S3 and S3 lite do, Wiim Pro etc do too..
The streamers largely all sound the same.. I've compared A/B a few times between Sonore Rendu / Primare NP5, Wiim Pro Plus and now the S3 lite.
Better to put money and effort into transducers..
Honestly that S3 lite, and maybe the power supply if I want to be extra, looks like the ticket for proper tidal connect
Just know that it's basically the first gen of this product. The WiiM products are much more mature by now. The S3 seems to be stable, but fairly bare-bones vs WiiM.
Don't do that. It's totally pointless.
Yeah, I've got the S3 Lite on the supplied power supply and it sounds just as good as a Primare NP5 on a MCRU supply:D
S3 Lite all working perfectly.
Hows it work for a new product? I like it over the wiim, from the window shopping atleast
It's been out a while now so is stable - they have been very responsive to issuing OTA updates when there have been bugs.
I followed it from day one, the S3 with dac / pre came earlier so took most of the teething troubles.
You didn't mention budget but I am happy with the Innuos Sense application and it does support Tidal MQA. (Edit: I now see you did mention budget and a Stream1 will be well over $2K).
Depending on the Innuos Streamer model, most if not all can support an AES output.
I use a Stream1 and prefer using a USB output that connects to a USB DAC input on my preamp but adding an optional SPDIF board would support AES.
Have S3 and S3 Lite both, each works great. Also have a WiiM Mini, it's a great simple device. The WiiM application is a bit more clean/functional than Fosi's, but Fosi is continuing to improve theirs pretty quickly. My major issue with it was the EQ control, and I read that they are about to drop a new version ASAP that will improve that.
With Spotify Connect, I can bounce the stream to whatever device I want around the house and control from either my PC or my iPhone. That's basically all the flexibility I need.
I think the Innuos Sense app is very good indeed. The only reason to get into there product range IMHO.
Certainly not the current products that are eye wateringly expensive, but there are many great deals on 2nd hand or ex demo.
