I just got a brand new SMSL M500. it's the latest 1.7 firmware and 1.3 hardware version. (windows shows 2.06 in xmos utility).
The following measurements are done with computer -> USB-> M500 XLR output-> ADI-2 Pro input -> computer.
I use REW to generate the sine wave and plot the fft.
If I play sine wave from both L+R channels, or just the R channel, the FFT looks very normal:
However, if play sine wave only from the left channel, the third harmonics is 0.015%.
I tried different DACs (such as Topping's, or SMSL's M300), swapped cables, swapped L, R input channels, and can confirm this issue only happens with M500 left channel.
The issue only occurs when left channel is playing different audio compared to the right audio --- When L and R are both playing sine wave at the same volume, it's quite normal. When only the left channel is used, or when left is playing 90% volume and right is playing at 70% volume, the problem occurs.
Any guesses why it is like so?
And no, you won't find this test in either
@amirm 's or
@WolfX-700 's review.
Also, since SMSL SU-9 is basically the same hardware and software, an educated guess is this will happen in that device as well. though I'm not very sure.
