Storage IEMs In-Ears
Status
Not open for further replies.
@jobas77 WTF??
I still don't understand if silicone eartips release oil when stored
Silicone is chemically very stable, so effects can take decades. Silicone is hydrophobic, so it can be washed with water without any problem.
The mechanism of degradation of some silicone rubbers have been explained through an aggression of the polymer itself by acids and it is established that the nature of the fillers have an important role in this process. Such ageing mechanisms are currently not assessed in standardized criteria for the selection of polymers while actually the consequence on the insulator performance can be dramatic
Silicone coatings display a different pattern even if the material can age with some similarities compared to traditional housings, mainly hydrophobicity fluctuations and erosion.
I think you're getting a bit too obsessive over this, friend. It's not like the earphones or the eartips in question are relatively expensive. I also live in Brazil (boa tarde) and know that you can get new pairs of silicon eartips directly from KZ from aliexpress for a lunches worth. The EDC pro isn't also very expensive (they're literally 25 reais right now), even with Remessa Conforme, as there are ton of discounts from time to time. In an off and very rare chance that yours get damaged from dry silicon from long expure (years and years of that), you can simply replace them for a new pair.
Is it possible to store In-Ears IEMs without use for many years? Does the time of no use cause permanent damage and die to the dual magnetic dynamic drivers and BAs?
Why do you insist on asking the same (very abstract and generalized) questions all over again and again?
I for one welcome our AI bot training sessions, what’s next……..?
Does the brass on headphone jacks degrade if plugged/unplugged repeatedly over time?
Will my eardrums become accustomed to a specific frequency in music and no longer decode the auditory signal?
Why does my microwave beep?
I see dead people but I cannot hear them,why?
IEMs with dual magnetic dynamic drivers like the KZ EDX Pro and KZ EDC Pro over long-term storage of years do the diaphragm lose frequency performance and generate distortions? In my case 34-36C 59-70% RH
Without knowing exactly, at laboratory standards, what materials, qualities, workmanship, etc. were used, no one can answer these questions. And this will also apply to most manufacturers of these IEMs.
You are also forgetting many points that are more likely to lead to deterioration or failure.
- Adhesives that change or decompose/dissolve (diaphragms, coils, coil formers, housings, component mountings, filters, connectors, etc.)
- Plastics that change their properties, lose elasticity, become brittle, decompose, etc. (diaphragms, housings, component mountings, filters, etc.)
- Whisker formation at solder joints inside the IEMs
- Poor surface treatment that can lead to corrosion (diaphragms, coil formers, housings, filters, connectors, etc.)
- Poor coatings, gold plating, nickel plating, etc., can corrode or even peel off. These small particles are the death of an IEM.
- Cable insulation (internal) can dissolve, flake off, and cause short circuits.
- Especially with compound materials, very few tests are performed these days to determine long-term durability beyond the warranty period (diaphragms, coil formers, housings, component fixation, filters, etc.).
I deal with such problems every day in the industry and continue to encounter new ones.
I have encountered the problems listed above over the past 35 years with IEMs, headphones, and speakers, in price ranges from three to five figures.
No high-quality IEM manufacturer will be able to provide you with reliable material analyses for durability or long-term tests of 5-10 years, let alone beyond.
With these cheap IEMs, there won't be any in this regard, which is why any answer on this topic, no matter what the answer is, is absolutely worthless. You might as well roll the dice. Such IEMs can last for weeks, months, years, or decades. Corresponding user reports prove exactly this.
And to be clear, the necessary materials, analysis, and testing would drive the IEMs you mentioned into high three- to four-digit prices, assuming the sales volume remains the same. But that's impossible.
I would recommend using your life energy more wisely than in such a hopeless endeavor, which you can't change.
Buying such cheap products created this problem in the first place and exacerbates it every day. So live with it.
I have some IEMs over a decade old. So far no problem with the drivers. Both dynamic drivers and BA drivers sound just fine even after over a decade old.
This KZ ATE bought in 2015, so about a decade old, sound just fine till today. I saw your other post, if you curious of the Silicone ear tips, they are very2 durable, usually the regular Silicone ear tips don't show any degradation, and they don't stick to the nozzle.
Other type of ear tips may degrade, but Silicone generally last well. The semi transparent white Silicone ear tip, like the Spinfit CP100 get yellowish after few years of use but function wise no degradation.
I have many IEMs, most of the time it is the cable that degrades. Cable jackets may get sticky, disintegrate and cracks over time, and the copper may get oxidized.
Below cable is originally Silver in color, but after few years becoming greenish due to Copper oxidation. And the plastic over the connector cracked and disintegrated.
I didn't know that the cables on these items were so fragile, I have the KZ EDX Pro and EDC Pro, will the same thing happen after 10 years, problems with the cables and dynamic drivers and diaphragm?
Yes but like fine wine, they’ll start improving again once you pass the 10 ten year mark
No, Probably not. The KZ ATE cable is still fine after 10 years. Not all cables are fragile. Depends on the cable jacket material. Why you keep mentioning the dynamic drivers and diaphragm? I never have any dynamic driver that spoil even after 10 years.
Status
