It appears Someone else here enjoys watching 'Homicide Hunter Joe Kenda"My, my, my
One of my fav crime dramas!
We got it bad, ain't we?View attachment 455243
Very nice, where do you get these DUAL head-shells from... I could use a couple...
I'm running out of tables, and what's more - out of cables... Stereophile has been no help
Sell it all now and build a great Atmos playback rig.My cartridge stash is left over largely from my years in the industry. I still have a lot of records, some unplayed for many many years. At some point there'll be a reckoning, but as much of it is appreciating in value currently, it'll be a nice little nest egg for my wife and son to sell on if he's of a mind to.
Yeah.
Man... I hate that!
Maybe at frequencies way beyond audible ones, there could be some effects due to the cable design. For home living room lengths of adequate gauge copper audio cable, no.Maybe unfair, but to me it seems Martin Colloms has been muddying the hi-fi waters for long time.
At the end of the article John Atkinson refers to a 1995 article by Malcolm Omar Hawksford entitled, "The Essex Echo 1995: Electrical Signal Propagation & Cable Theory". That article seems to deal with the speed of propagation of signals within cables, arguing that aspects of the cable, e.g. diameter, can adversely affect transmission.
Since I'm no electrical engineer, scientist, or mathematician it's all gobbledygook to me but might be comprehensible to other people. The question is -- allowing for its from validity -- is it relevant to audio signals?
That is for some really serious 'lectric!Just espied this on the Polk Audio forums - thought this thread was a worthy spot to share it.
Vinyl cultists have had a long run of making zany claims about the ineffable analog magic of the medium. Claim like this “second class” thing and related digital-über-alles suggestions that vinyl doesn’t offer excellent hi-fi reproduction (along with its miscellaneous anachronistic imperfections) are just the same zaniness, inverted.But WHY. All that money spend on a 50 year obsolete medium that offers second class sound quality…
He hasn’t expressly set out to deceive you, or anyone else as far as we know.
How about misguided, deluded, narcissistically grandiose?
Only the ones who haven't had the opportunity to listen to low-generation copies of master tapes.Vinyl cultists have had a long run of making zany claims about the ineffable analog magic of the medium.
In comparison to digital, whether looked at from a subjective or objective viewpoint, I'm sorry sir but that's where your wrong.Vinyl cultists have had a long run of making zany claims about the ineffable analog magic of the medium. Claim like this “second class” thing and related digital-über-alles suggestions that vinyl doesn’t offer excellent hi-fi reproduction (along with its miscellaneous anachronistic imperfections) are just the same zaniness, inverted.
'Excellent' is pushing it a bit. That doesn't happen so often. With a good pressing, disc in perfect condition, mint condition stylus, a couple of grand (at least) spent on the deck arm and cartridge, sometimes you can get there.Vinyl cultists have had a long run of making zany claims about the ineffable analog magic of the medium. Claim like this “second class” thing and related digital-über-alles suggestions that vinyl doesn’t offer excellent hi-fi reproduction (along with its miscellaneous anachronistic imperfections) are just the same zaniness, inverted.
This illustration is labelled incorrectly. The grooves that cause lateral movement in the stylus are actually a sum of left and right ie; a mono audio channel. This is how the brilliant design of the original stereo cartridge and disc remained compatible with mono reproduction equipment. The groove itself is a matrix with the lateral movement being the mono channel and the vertical movement being the difference between the left and right channel. The wiring in the cartridge (4 conductors) allows the matrix to be decoded into left and right signals.
Except then, audiophile bus bars would come onto the market, each with their own 'sonic signature'...How about this for an idea. If you're going to equip your system with something like those D'Agostino things, surely you could cut one of the potential music destroying elements from the system by simply backing your mono-block amp up to the speaker and coupling them with some short lengths of bus bar! By doing this, the Audiophool could avoid the cost of the magical cables and be assured that the amp to speaker connection was the absolute purest it could be! They could still enjoy the wallet draining experience of high-end interconnects so they wouldn't miss out completely![]()
The diagram is correctly labelled. There are no grooves that cause lateral movement. Lateral movement is the vector sum of the left wall and right wall of the grooves. The clever bit is that a pure left signal causes the stylus to move at 45° to the horizontal (or vertical!) and similarly, a pure right signal causes the stylus to move at 45° to the vertical the other side, and 180° out pf phase. Consequently, a mono signal which is identical on both walls but one wall 180° out of phase will cause the stylus to move horizontally only, as the stylus goes up one wall but down the other wall by an equal amount. An out of phase signal causes the stylus to move vertically only, which is why the L-R content has to be carefully controlled to avoid the groove depth going to zero, and the stylus leaving the groove.This illustration is labelled incorrectly. The grooves that cause lateral movement in the stylus are actually a sum of left and right ie; a mono audio channel. This is how the brilliant design of the original stereo cartridge and disc remained compatible with mono reproduction equipment. The groove itself is a matrix with the lateral movement being the mono channel and the vertical movement being the difference between the left and right channel. The wiring in the cartridge (4 conductors) allows the matrix to be decoded into left and right signals.
Nice pictures of dragin a rock thru the ditch Smithy! LOL
