I am making an separate thread regarding the dilemma of stereo reproduction and the current research saying that a speaker should ideally show a flat response. I don't know if this has been discussed in length before, although the issue has been touched upon in several threads. According to the research (Harman), listening has been done in the most sensitive mode, meaning a single speaker in mono, both using signals and music material. As far as I know, the research has come to the conclusion that the on-axis response should be dead flat.
Now to the dilemma. If ideal speaker should be flat as judged from mono speaker playing in front of you, you will hear different timbral response if you place the same speaker in a stereo triangle. This is evident from previous research by Shirley, Toole and others. The conclusion from Toole that "stereo is flawed" (which is true) and one should go for multichannel instead. True multichannel recordings are however few, and you are still stuck with tons of ordinary stereo recordings. The real question is however avoided: Given that a flat response is preferred for a mono speaker - stereo speaker cannot show the same flat response if the tonality of the centre phantom image should be the same. So what is the ideal frequency response for speakers playing in stereo?
