klettermann
I’m now using two subs as a summed mono bass system. They’re in opposite corners, time-aligned, gain-matched, and EQ’d together. Crossover is currently around 75 Hz LR24, but I don’t consider that fixed. It sounds great to me but obviously I don't know what I'm missing and it seems like stereo subs are fashionable.
I’ve been playing with REW Room Sim to think through the stereo-sub alternative. If I move the subs near the mains as left/right extensions, the response develops a large and irremediable null. In the current opposite-corner layout, the response has a few big modal peaks below ~80 Hz, but those are relatively easy to cut with EQ. The null is the much bigger problem. That makes me wonder whether stereo subs are sensible in this kind of setup. If the subs are placed for modal control rather than as physical extensions of the mains, summing them mono preserves the main advantage: the two subs can work together as one optimized low-frequency system.
So, the question is: below roughly 80–100 Hz, is there much practical case for stereo subs if stereo-symmetric placement creates substantially worse modal behavior? Or is mono multi-sub optimization usually the better default unless the subs can be placed near the mains without creating serious room-response problems? Any real world experiences on this topic would great. Thanks and cheers,
