Stereo Set, which amp should I choose? Cambridge CXA81, Arcam A25+ or Cambridge EXA1000
I know, but, the bass management from WiiM is way better than Denon. From WiiM I can adjust 1Hz at time, the Denon jump to 60Hz from 80Hz. The integration between sub/speakers it’s perfect between 73-75Hz. That’s the main reason I want the bass management from WiiM.
Hooked up this way, you can do bass management with the Wiim. The Denon will simply play whatever it receives from the Wiim.
Done! Now the config it’s almost perfect. I had to increase the volume in the sub to 75% and adjust to +8dB and set to 75Hz in the WiiM, otherwise, the bass would be too low. I used the RoomFit and the Sub Calibration (beta test).
Follow attached the RoomFit graph (L/R)
