luisfelipe_lfo
- Joined
- Mar 17, 2026
- Messages
- 105
- Likes
- 42
- Thread Starter
- #201
It's just a stereo + sub setup! Yes, I'm using Denon for amplification only.To avoid me going back through 10 pages, is this a surround sound setup via the Denon, or just stereo + sub, and you're using the Denon for amplification only?
For volume control I would normally say take a line out / RCA from the Wiim and put to your front left and right "Ext. In" on the Denon, and use the Wiim for volume control, that way you bypass any processing on the Denon and it's just amplifying a room corrected signal from the WiiM. If you have a TV you can also run that via hdmi to the WiiM, and then plug accessories like your Chromecast onto the TV hdmi inputs. However this isn't necessarily the best idea if you have surround speakers or for some reason you can't plug stuff into your TV, so what are you using it for?
I took a line out/RCA from the WiiM and put to front left and right in DVD, not, "Ext. In", perhaps, that was my mistake.
I'm not using TV.
Thank you so much for the help.
