It might be - seems pretty steep to me as well.
It's fine if you don't like these loudspeakers. However how can you be sure that this is because of your 'slow woofer' theory and not because of some well-understood factors such as e.g. 1) loudspeaker-room interactions, 2) Kali's frequency response peculiarities, 3) Kali's specific dispersion pattern, 4) some combination of the three? IMHO you'd need to eliminate all of these first before it even makes sense to look at alternative explanations.
Of course i have eleminate this first. I have the kali in near field 1 m, 70 cm away or 50 cm away hear(only mid/woofer at 50 cm). the less stereo width stay same. see measure of JBL 104 and kali. the kali have larger dispersion. I dont notice that dispersion pattern have such a big influence of stereo width and depth of field.
The 'rise-time' of a step response is determined by the low-pass filter / high frequency content of the driver and *not* by the low frequency extension / slope (which instead controls the 'decay time' of the step response). This has been explained before in posts
#29,
#32,
#43,
#59,
#61 and
#63.
Step responses can of course be useful in certain cases, but it is important to understand that it is just another view of the same data as the frequency (magnitude+phase) response.
yes i know. In Fact the speaker driver work too as a HP+Lowpass filter. the LP crossover filter+ driver highpass filtering give the raise time of step response . and a faster speaker is a speaker that have less db/octave Filter and a faster driver. and to see this, a step response is usefull. or wy should buy a speaker with a slow rise time ?.
the phase response is for me not usefull. because many speakers have lots diffrence. I have the iloud mtm this do phase shifts to get better phase. it sound wider as kali of course but the eris 3.5 was a little better and the jbl 104 was even more better. maybe it is because of the 2 woofers the mt have. i did not know.
and wy do you think does a faster LP filter with less phase shift and a faster driver can not sound better when it have faster raise time and decay time to 80 ?
and so the step response can help to find best speakers. so wy step response should not post on a test ?.
is this not real logical ?. I translate from german to english with google translate
A bass / mid driver that manages 5 kHz -3 db takes 200 µsec to reach 70% of the level. if it were faster than 200 µsec, then it would also manage higher frequencies. People who can hear ITD, however, interpret time differences above 20 µsec for the direction of sound and spatial representation of frequencies below about 1.5 khz. 1 khz has a period time for 1 half-wave of 500 µsec.
the left and right speakers output different levels and frequencies in stereo music. it can happen that the level of left channel not change in a time of 1 ms and remains at a peak. the loudspeaker reaches the peak without delay. The right channel has to change its value. this then automatically changes the frequency of the loudspeakers (left right) differently. If you have a full range speaker with a tweeter together or without a tweeter, then it is much faster in the mid range and reaches the levels for the left and right speakers with 3-4 times less delay. Therefore, many people are of the opinion that broadband drivers bring a better stereo image.
In addition, there is the delay of a steep-sided LP filter. Because the left and right channels play with different frequencies, the delay is also shifted between left and right. That's why I think steep-edged LP filters also sound bad. the kali has probably 48 db. Have only BW 24 db LP in the DSP. but already at 500 hz it makes a massive phase shift. Am I calculating correctly? 500 Hz 45 degrees would then be: 500 Hz are 2000 µsec period time / 360 * 45 = 250 µsec. which is too much for good ITD. the JBL 104 only has a 6 db filter. with coax systems this works better with flat LP filters
the left and right channel on stereo signals play on same time diffrent frequency. there is a free VST plugin wave observer light. this can freeze and show left and right channel as overlay. here can see that left and right have diffrent peak and valley positions this result in diffrent frequency. and diffrent frequency give on much db /octave filters lots of phase shift between channels. i notice 24 db filters sound bad in stereo width
very even and wide dispersion pattern, which then makes use of side-wall reflections to create a wider and more enveloping soundstage.
this is maybe true when the speakers are in a concert room or concert hall that sound good. but when speakers put in a a living room(10- 30 qm) reverb sound not good. I hear nearfield 50 cm away my JBL and 80 cm distance between left and right. and it sound wide the kali not. and that a magnapan dipol sound wide fit also in my theory. they sound wide because they have electrostatic and fast Mid system.
have you hear the audio examples of the speakers ?. correct is that you hear 2 guitars 1 left 1 right that come out of speaker. i
If you think the guitars are more in mid as the left and right position of the speaker, then this is worser stereo widt. do you really think a speaker with wider disperson the guitars then hear magically at correct position
and also notice. I talk about good sounding speakers when hear around 70 db volume. when speakers make very loud then of course the kali can sound better. but it is not good for ears.
