Guys, completely lost here and hopefully you can find a solution.
I have my ADI2 connected via the RCA cables to my Rotel A11, which drives my speakers. I also use the balanced output or the ADI2 , connected to my headphones tube amp TA-26S. What I notice is that there always seems to be static noise in the loop. When the RCAs are connected to the A11, and crank up the volume in my headphone amp, you can hear the noise in the headphones. If I put the wires vice versa, i.e. the RCAs connected to the headphone amp and the balanced to the A11, you can then hear the noise in the speakers of the A11. If I remove one of the two devices then the noise goes away. Both amps use a triple connection electricity wire, so I would assume they are grounded.
