Starkrimson® Stereo Ultra Integrated -- Coming Soon
orchardaudio
Succasunna, NJ
Coming Soon...500W Stereo Integrated Streaming amplifier
I guess the cat is out of the bag now.
Preliminary test results
All measurements with 8-ohm load, looking very good so far.
Bench mode 22.4kHz BW -- 48kHz DAC Sample Rate
Wideband FFT -40dB output 0dB = 44.72Vrms -- 48kHz DAC Sample Rate
Wideband FFT -40dB output 0dB = 44.72Vrms -- 192kHz DAC sample rate
THD+N Ratio Vs Output Power (22.4kHz BW) -- 48kHz DAC Sample Rate
IMD Distortion (SMPTE Ratio vs Measured Level)-- 22.4kHz BW -- 48kHz DAC Sample Rate
Jitter Specturm and Noise 22.4kHz BW -- 48kHz DAC Sample Rate -- 256kFFT 16 Averages
Matias
São Paulo, Brazil
Nice. What are the inputs?
restorer-john
Just ethernet.
Well it's not an integrated amplifier. The functions of a preamplifier and power amplifer together make an integrated amplifier. Yours is more like a streaming/network amplifier.
Integrated amplifiers have multiple inputs, physical volume and other fuctions (filters/tone/outputs/switching etc).
Is that 3 separate power supplies (standby/5V/SPMPS)?
orchardaudio
orchardaudio
Succasunna, NJ
Well it's not an integrated amplifier. The functions of a preamplifier and power amplifier together make an integrated amplifier. Yours is more like a streaming/network amplifier.
Depending on which manufacturer you look at everybody calls it something different. In general, I agree with you. I have not settled on a final name. The idea is to combine my streamer and amps into a single box and have a very small footprint solution where one only needs to add speakers.
No. There are two power supplies
1. The SMPS1200A100 actually outputs 5 different voltages all of which I use for the amp modules
2. There is a 9V SMPS supply for the DAC and RPi.
The green square PCB with big blue relay is a soft-start module
DonH56
Monument, CO
It looks like there are a couple of XLR inputs on the board on the right front? Could those be plumbed to provide analog inputs?
DonH56
Monument, CO
Those are outputs, not inputs.
Oh. Boo, hiss... I don't know the demand for analog inputs but a pair might be nice if at all possible. OTOH, doesn't sound like they are a requirement for your target market.
What are the pair of large caps tacked on to each of the output boards? They look like afterthoughts though I am sure you have a very good reason for them (serious, judging by this and previous works of yours, I am curious).
USB input a possibility? One thing I miss from most USB interfaces is they won't act as a controller for an external USB disc drive...
orchardaudio
orchardaudio
Succasunna, NJ
For analog inputs you would buy stereo amplifier.
I do not have plan for USB at this time. There may be SPFIF in the future, then a simple USB to SPDIF converter will solve that problem.
Kachda
NY
So the only way to play music from this is via streaming ? That seems a bit limiting. Given that it has a DAC, at least a coax or toslink input should be available ?
Kachda
NY
An electrical wire nut in a piece of electronics?
That is a new one. In transit this can shake and unscrew itself. They are only made for stationary use in electrical panels and such.
Haha, i saw that as well but presumed this was a test unit
DonH56
Monument, CO
Where's @Thomas savage when we need him? He is most qualified to address @amirm 's obsession with nuts.
Edit: Realized that could be taken multiple ways; oh well, too tired to rewrite it...
KingRolo
San Francisco
With volumio you can stream, play digital files from storage.. also connect a Cd-Rom.
It’s 2021 maybe we need to move along with our terminology.
Integrated to me mean’s different media being integrated into a system. Whether it’s analog or digital should not make a difference.
JSmith
Algol Perseus
Not really, it's about integrating separates into one unit... amp, preamp and input switching/controls.
That said a digital input streaming amp is most welcome.
JSmith
