Starke Sound Beta5 - Member review
_theaudiofile
G’day!
Unless you’ve been living under a rock, you’ve probably heard the rumours of a new audio messiah. The way the audio community (and maybe even your grandparents) are hyping up the Starke Sound Beta 5 bookshelf speakers, you'd think they turn water into wine. Being the audio nerd that I am, I reached out to Starke Sound directly to get my ears on these and see what all the hype is about.
Full disclosure: I am not being paid a single cent for this review. The mutual agreement was simple: I share my honest, unfiltered thoughts. They haven't interfered, haven't asked for a sneak peek and have had absolutely zilch influence. That earns respect in my book.
These impressions come straight from my ears for now. One day, I'll have the gear to back them up with pro-level measurements.
TL;DR - Overall Rating: 4.8/5
The bottom line: The Starke Sound Beta 5 speakers deliver a killer price-to-performance ratio for $499 (USD). They are built like tanks and offer the refinement and expansive 3D soundstage of speakers costing three times as much. They more than hold their own as a highly engaging music listening experience straight out of the box, but as you’ll read below, there are a few specific ways to really unlock their full potential.
Unboxing
First impressions matter, and Starke Sound knows this. I won't bore you with every little detail and will let the pictures do the talking. No cheap, crumbly polystyrene here; they are secured in precision-cut, high-density foam. The cabinets come wrapped in soft cloth bags; I'm giving that a HD for Hot damn!.
As for the Stand 3S... the "S" might stand for ssssexxyy! 'Nuff said. They are the sexiest stands I own. Granted, they're the only stands I own, but still. I definitely tried to flex them in the pictures because they just present so well.
(Quick heads-up: You might spot a white dot on the bottom of the right speaker in the pics. That's just some dust I noticed after the photoshoot. There's no flaw, I've since cleaned it off, and the cabinet is in perfect condition.)
Build Quality
Out of the box, the first thing that smacks you is the density of these cabinets. Each speaker weighs in at a hefty 6.8 kg. You might be able to use them for bicep curls. Starke Sound dumped their budget where it counts: the engineering and construction. The front baffle is made of polycarbonate and is a beefy 32 mm thick, while the rear wall is 19 mm thick. Internally, my research tells me that it's heavily braced and lined with damping material. Give it the ol' knock test and it’s as dead as a rock, meaning absolutely zero unwanted resonances.
The finish on the veneer is amazing to touch. The Beta 5 sports a 133 mm carbon fiber sandwich cone mid-bass driver with a heavy-duty cast basket; something you almost never see at this price point. Both the 29 mm soft dome tweeter and the mid-bass motor assemblies use copper shorting rings (Faraday rings) to reduce distortion. Around the back, you’ll find a beautifully machined billet aluminium terminal plate with high-quality binding posts. I'm a total sucker for details like this, it makes the audio nerd in me very happy.
Here is my first critique, though. While I love the overall design and how easily it blends into a modern living space, we need to talk about the grille. It features a figure-8 shape structure on the inside. I highly recommend popping it off. Not just because the drivers look great exposed, but because taking the grille off lets the sound completely open up. Any obstruction is the enemy of good audio, and removing it makes a noticeable difference.
What you’re here for:
I hooked these up to my Denon X2800H receiver and tested them out in both a small room and a medium room setup.
Given that this is a 133 mm driver, I kept my expectations in check, I wasn't expecting to get noise complaints from the neighbours anytime soon. But the bass extension on the Beta 5 took me by surprise. They dig down to a rated 45 Hz, and you absolutely feel it. The low-end is punchy, tight and brilliantly controlled. Compared to my SVS Prime Bookshelf speakers, I dare say the Beta 5 delivers more clarity and transparency
Music Experience:
If you appreciate a neutral, studio-reference style of midrange, you are going to be pleasantly surprised. Vocals have beautiful weight and texture to them. Instead of shoving the mids in your face, instruments and voices mix together beautifully. The 29 mm silk dome tweeter is the real MVP here. It delivers a ridiculous amount of air, micro-detail, and clarity, creating a wildly expansive soundstage in both width and depth. I close my eyes and the speakers completely disappear; sonically, of course
I threw different genres at them; Fleetwood Mac, Whitney Houston, Marvin Gaye, Bruno Mars, you name it. When playing Fleetwood Mac’s "The Chain," you can literally hear the subtle scrape of fingers sliding across the acoustic guitar strings, and when that iconic bassline drops, it sits entirely on its own without muddying up the vocal harmonies. Cue up Whitney Houston, and her voice has this incredible, commanding weight to it. You get the actual resonance of the singer's chest, not just sound pushed through a cone.
It does an amazing job across the board. Using standard 12 AWG OFC Monoprice speaker cables, I'd give the music experience a 4.7/5. But swapping in my custom Canare 4S11 cables? It brought so much clarity and depth, lifting the music experience to a 4.9/5, which is basically as close to perfection as possible for this tier. (For the cable myth-busters out there reading this, I know this is controversial, so please lower your pitchforks and let's just respect each other's views!).
Movie Experience:
This is the only slightly negative thing I can say about this speaker. While it is near perfection for music, the cinematic experience is a little lacking out of the box, earning a 4.2/5. Don't get me wrong, the imaging is fantastic. If you throw on Top Gun: Maverick, the dialogue is dead-center and crisp, and as the jets scream across the screen, the spatial panning is pinpoint accurate thanks to that highly revealing tweeter. You might actually duck when Tom Cruise buzzes the tower.
But when those afterburners kick in, or when that massive, room-shaking synth drops in the opening scene of Blade Runner 2049, you hit the physical limitations of a 5.25-inch driver. It lacks that deep, room-pressurizing, visceral rumble that makes home theatre so ridiculously fun. I also threw on The Batman, specifically the rainy Batmobile chase scene. The Beta 5s perfectly captured the sharp screeching of the tyres, the shattering glass, and the raw growl of the engine, but you don't actually feel that engine idling in your chest.
Usually, I rely on my SVS PB2000 subwoofer to fill out the bottom end, and if you're using these for movies, you'll definitely want a capable sub to handle those deep, subsonic frequencies. Once you cross them over to a dedicated subwoofer and let it do the heavy lifting, though? Absolute cinema.
Stats for the nerds
I'm not getting paid to be their technical writer. If you want the deep-dive specs, refer to their website.
Frequency Response: 45 Hz – 23 kHz
Impedance: 4 Ohms
Drivers: 1.15-inch (29 mm) soft dome tweeter and a 5.25-inch (133 mm) carbon fibre mid-bass.
The Baffle: 32 mm thick Polycarbonate
Weight: 6.8 kg each
Verdict
Starke Sound nailed the aesthetics and construction here. For my setup, the Aoki Flaxen Grey finish paired with the grey Stand 3S is a match made in heaven. It easily blends into the living space. I'm also a big fan of the discreet logo. Combine those clean looks with the tank-like build, the value is indisputable. Sonically, that expansive 3D soundstage and highly detailed tweeter make these an absolute joy when I just want to sit back for some critical listening.
But nothing is perfect, because these bad boys are rear-ported, you can’t just shove them right up against a wall, dust your hands off and call it a day. I found they really shine with a bit of real estate to breathe and do their thing. Also, because that tweeter is so incredibly revealing, the highs can lean a tiny bit bright if you decide to absolutely blast them past the 95 dB mark. So keep the volume at a reasonable "I'd like to keep my hearing into my retirement" level.
We also need to talk about my biggest gripe: the grille. It features a thick, figure-8 shape structure on the inside. Any obstruction is the enemy of good audio, and leaving these grilles on noticeably holds the speakers back. I suggest Starke Sound consider a fully perforated grille for their successor releases so the sound can remain transparent without any blockage. For now, do yourself a favour and just leave the grilles in the box.
At $499 (USD), I don't think the Starke Sound Beta 5 is just a good speaker; these bad boys are absolutely amazing. Looking at the cast baskets, the Faraday rings, that crazy thick baffle, and the beautifully machined billet aluminium plates, it really feels like Starke Sound blew their entire budget on raw engineering and forgot to hire a marketing department. If you're building a dedicated two-channel setup or upgrading your home theatre fronts and want high-end transparency, dynamic punch, and exceptional build quality without having to take out a second mortgage, the Beta 5 should to be at the top of your list.
Build Quality: 5/5
Sound Quality: 4.5/5
Value: 5/5
A 5"/1" is a proven formula that should be pretty hard to mess up, assuming the crossover has been done anywhere near decently. Driver spacing isn't exactly conducive to nearfield operation. Not entirely surprised about the grille situation, the tweeter is likely to be going very wide in the low-mid treble and a proper waveguide (even a relatively shallow one) would make for better dispersion control. This may well be why it can seem a bit bright, too.
They? They who? Do you mean the manufacturer? So you've got a honey deal directly with the manufacturer, and you publish an uncontrolled subjectivist "review" ... one which means absolutely nothing.
And then you have the gall to say...
This is a data-driven website. It was created by Amir Majidimehr in order to do two things: 1) push back against uncontrolled and unverifiable subjectivist so-called "reviews", and 2) double-check manufacturer's data to make sure that their advertising isn't just blue sky.
You've failed on both counts. :(
Here are Erin's Klippel measurements: https://www.youtube.com/watch?v=s3iaP8sSC1E
It's also just bright on-axis (showroom tuning).
Pretty bad response, poor DI, costs more than monitors with better performance.
It's just waste before it ever gets bought.
To the OP, welcome to ASR. Folks here generally like to see some in depth measurements of speakers alongside the subjective impressions. Without both, it's really hard to truly understand the speakers performance. I can't say I've heard of this company though.
G’day!
View attachment 525057View attachment 525058
Unboxing
Build Quality
Music Experience:
Movie Experience:
Stats for the nerds
Impedance: 4 Ohms
Weight: 6.8 kg each
Verdict
Build Quality: 5/5
Value: 5/5
Without measurements the review is rather useless. Thanks for the comment regarding build quality though. Just listening to the speaker in stereo however has no meaning except for yourself - sorry to say it like this but it's the sad truth (humans are wired that way). For example changing the speaker cables as described does not change the sound coming out of the speakers.
Looking at the speaker I notice a missing wave guide and a longer than necessary distance between tweeter and woofer. The former leads to uneven off axis frequency response, the latter to a longer minimum distance. Hence no reason to buy it as there are other speakers available which do it right.
G’day!
Unboxing
Build Quality
Music Experience:
Movie Experience:
Stats for the nerds
Impedance: 4 Ohms
Weight: 6.8 kg each
Verdict
Build Quality: 5/5
Value: 5/5
Looks like Starke has the Beta 5 bundled with an Eversolo Play...........supposedly a Tuned system "There will be a UI to select the designed UI/Beta5 icon on Eversolo Play." That is what Starke told me. Sounds like a good thing.......be nice to see some measurements using the "Tuned System"
Does anyone else think OP just asked ChatGPT for a good speaker review based on the specs alone? Maybe this post was a semi-grift to get free speakers?
Or perhaps OP (and maybe even the post just before this one) are both from a marketing firm working for Starke?
Because contrary to OP's assertion, I had not heard a single thing about these speakers, let alone any religious implications about them, before this post...
At a minimum I think OP agreed to pimp the speakers in exchange for a free pair. Could be wrong, but that’s my guess.
I appreciate the skepticism.
Honesty and transparency are vital in this hobby, which is why I disclosed the nature of the review at the very beginning of the post. However, I’d like to clear up a few assumptions.
In response to the free speakers:
I already have a collection of quality speakers in my home setup. To be blunt, adding a $499 pair of speakers that doesn't even match my current system adds zero value to my sound setup. I didn't do this to "get free gear." I did it because these speakers have a lot of hype on YouTube right now, and I simply wanted to hear them for myself and share that experience. I can only use so many speakers at once; my goal here is to get more involved in the community, learn, and contribute not to flip budget gear.
On the Lack of Measurements:
As a newcomer to reviewing, I’ve come to learned that impressions aren't always enough for this community without measurements to provide depth. I see that as my own "barrier to entry" right now. I respect the need for data, and I’m currently looking into measurement tool options so I can provide that level of technical detail in the future.
On the Use of AI:
The accusation that I just "asked ChatGPT" based on specs is honestly pretty discouraging. I spent multiple weeks testing these and went through hours of revisions to make the review as comprehensive as possible. I did use AI to help with punctuation and to smooth out the wording for better flow, but the actual listening experience, the opinions and the time spent were all mine.
I’m here to learn and be a part of the conversation. I’m happy to take the feedback on the data side, but the marketing firm and grift speculations are inaccurate.
On the Use of AI:
Hey, thanks for the follow-up and sorry for disparaging your writing like that. We're innundated with "AI slop" on this forum and everywhere else (work, reading articles online) so it's a knee-jerk thing to assume something is mostly the work of AI. Your style was pretty on the nose for a non-technical speaker review (e.g. that you might read on Techradar or similar) so I started to think the worst of it. As far as that goes, for what it's worth, I felt like it was up to that professional standard.
ASR is one of the roughest audiences to share this kind of content with, we tend not to pay attention unless there are graphs to look at. If you read Amir's reviews, they are somewhat the opposite of a typical speaker review - 95% graphs and 5% commentary, sometimes 0%.
It's possible this would go over better on other forums.
As far as doing measurements, if you intend to keep doing speaker reviews, I would definitely encourage it. You can get pretty far with a measurement mic and a turntable by doing gated measurements. I believe @Ageve is able to generate fairly detailed measurements of speakers with this method.
If you enjoy writing the subjective impression stuff, and you are able to correlate that well with measurements and do extended commentary in that context, you can bridge the gap between subjective reviewers regular people like reading, and objective reviewers that nerds like ASR members like reading.
The data from erin's video shows that this speaker is designed to be placed closer to the wall and slightly off axis depending on the listening room's reflections and it does place deeper than DB63 if you have the amplifier. I don't understand the obsession with reading the data as flat and thinking that it will do the same in your room. Sure, data is good to have but room reflections and speaker placement do have some effect even above 200Hz no matter how well the speaker is designed as people don't often sit in the ideal place and listen to music or watch content on a TV. Blind obsession with data might be a bad thing afterall.
