"Stand Subwoofers" like the Genelec W371, Kii BXT, etc. Ideally with DSP & Multi-Drivers
ferrellms
Neumann does with the KH870 for the KH420.
However you should refrain from this idea. The best position in a given room for a sub is very seldom identical to the best position for the sats, so either bass suffers or soundstage.
In the cases of the Kiis and Genelecs, they are not really subwoofers, they are specifically designed to extend the bass and improve the directivity of the system as a whole and are designed to used as shown in the photo. In the case of the Genelecs, the GLM software is used to integrate the bass units, top units, and the room EQ.
jhaider
To put it more simply, accurately, and directly, they’re just subwoofers.
To have any impact on “directivity” in a small room they’d need to play up to 500Hz at least.
thewas
They are bass cardioids, by using rear woofers delayed and in 180° phase to create a bass cardioid, something which is more common than most think in the PA world
jhaider
While that is true, there isn’t “directivity” to speak of in this bandwidth in a small room. A cardioid or dipole will excite modes slightly differently, with a significant efficiency penalty. Mode excitation could be “better” or “worse.” “Differently” is the only concept one can use for the general case.
Dutch & Dutch takes the objectively most sensible approach to balance directivity and bass efficiency: cardioid midwoofer in front of monopole bass units.
Hephaestus
Rapture
Genelec W371A does play up to 500Hz.
jhaider
Thanks, I missed that. In that case, I wonder if there would be any real performance difference aside from minor FR variations due to waveguide loading/cabinet diffraction between the different coaxial monitors used with a pair of these.
ferrellms
l
Can subwoofers do this? Flat response 25 to 500hz! Directional from 50hz up! Smart software to EQ and time-align the system as a whole! 123 db! How the heck? I want to at least hear them sometime. At 8K each plus another 8K for a pair of the monitors...
Genelec's goal is to approach the performance of their giant soffit- or wall-mounted monitors in a system that does not need a room specifically designed for them.
Dj7675
Ah yes, the ugly duckling version of the Revel Gem2s.
I actually quite like the look. But the spin looks pretty impressive too considering it’s age.
hvbias
US
I've heard the Kii Three without BXT and I was quite impressed with the sound. My understanding is this- the BXT essentially let you play louder without the speaker protection kicking in (as well as offering some additional extension, more on this later), from what I am reading Kii have made this level fairly high with a firmware update that came out a while back. I can't recall what the SPLs were off the top of my head but I seem to recall thinking it was at the limit where no one would realistically want to listen at those levels, and I do listen to primarily classical so lots of music with wide dynamic range.
My reasoning was either way for my average size room that I intend them for I am going to need to do something to smooth out the bass. The BXT does not fix this issue, it will extend the bass essentially turns it into a truly full range speaker. This does nothing for the room modes and where I think Geddes or Welti multi-sub is still the most high fidelity way to do it. So either way I'll be buying high quality subwoofers to fix these issues, these will also offer the additional extension and relieve some of the low bass duty that would presumably normally kick in the protection without the BXT. Bringing me back to my point that at least for my use (anyone's use if they want truly flat bass?) I can't see the advantage of the BXT.
Absolute
I'm a fan of saying unpopular things, so here goes; Cardioide dispersion below the room transition frequency means diddly squat. The room resonates and becomes one with the speakers below 2-300 hz and no amount of directivity will change that. If you happen to excite certain modes differently in a better way because of directivity, you're lucky.
In a normal room the BXT will be just another subwoofer with high crossover-capability and the benefit of reduced effect of floor dip in the upper bass.
firedog
Unpopular or untrue?
Cardoid dispersion clearly removes lots of room effects - when you hear Kii's or 8c's in your room the difference is obvious. Neither Kii nor D&D claim their speakers eliminate room effects.
Yes you can still have a room node with such a speaker. So what? Easily taken care of with DRC. And then they sound even better.
Matias
São Paulo, Brazil
Absolute
Unfortunately, cardioide dispersion does not help you much in the room's resonating area. Standing waves will build up energy while bouncing around and will ignore the dispersion characteristics because there's no longer any controlled directivity to stop it once the initial wave hits the walls and reflects. In the resonating area the steady-state response is the best metric to use as a visual aid to see what we hear, and in the same steady-state response even Kii and the like will suffer from the same room-behavior as other speakers. Here's a few examples with the Kii;
https://www.stereophile.com/content/kii-audio-three-loudspeaker-measurements
https://www.gearslutz.com/board/high-end/1048540-kii-three-have-you-heard-them-23.html#post12588247
I have a ton of measurements demonstrating the same thing in my own room with Kii and other speakers. Differences can of course be seen, but they are completely dwarfed by the evilness of the room and could mostly be explained by small differences in placements.
Above about 200 hz the effects will begin to show.
Don't take this as criticism of Kii or any other cardioide speakers because it isn't.
Sprint
HEDD Audio has one here
