Is there a floorstander out there using similar directivity control tech to the D&D 8C?
The marketing wank is a little vague, but this seems close.
https://eikonaudio.com/the-image1
They were one of the better things I heard at AXPONA last year.
I'm not sure where you draw the line between "using an important measurement as one of the design goals/decision making process" and "obsession."You know what grinds my gears?
The mentality of some engineer types that worship at the alter of efficiency.
It's like getting obsessed with accuracy, or any obsession for that matter.
I like my room, but I like my speakers more.
The only time where the two are completely integrated is Klipsch corner horns, and as posted somewhere else in this forum they neither measure well nor sound accurate.
Not if the horn is wide enough....A 2 way 'speaker is actually rather difficult to do. If the bass unit is large, it will start beaming long before the tweeter takes over, which has implications for the off-axis response.
And I would add, straight enough. Any bends in a horn and all bets are off. So, where shall we put that straight 20Hz horn.........Not if the horn is wide enough....
Amphion & Gradient have floorstanders with passive cardioid implementations.Is there a floorstander out there using similar directivity control tech to the D&D 8C?
While a 20Hz horn would be coolAnd I would add, straight enough. Any bends in a horn and all bets are off. So, where shall we put that straight 20Hz horn.........
I'm not convinced. Tannoy's tweeter is a horn, concentric with the woofer, crossing over at 1kHz, and that has problems integrating properly with a 12 or 15" woofer. The Decca horn tweeter was also quite a good device, but the systems they were used in struggled as 2 ways.While a 20Hz horn would be coolwe were only talking about needing it down to the point the directivity will fairly closely match the woofer. Lots of horn speakers can do that to below 1000 Hz. Curved horns can work OK for that.
The absolute thickness is unimportant. For speakers of any form factor, the amount of fibrous damping required to treat air column resonances is proportionately similar. The resulting loss of vent efficiency is similar for short and tall speaker cabinets, depending on the volume portion occupied and such.The problem of thick absorbers needed to reduce the relatively low frequency standing wave in a floorstander vs. a Helmholtz resonator is that they also reduce the bass output, especially in the ported designs (so most of commercially available loudspeakers nowadays)
ME Geithain made cardioid speakers before D&D and makes them fully cardioid (down to 30 Hz). See https://www.me-geithain.de/en/rl-901k2.html for example:Is there a floorstander out there using similar directivity control tech to the D&D 8C? The only somewhat-comparable active I'm aware of is the JBL M2(not really the same) and I guess the Beolab 90, but that's way out of the price range and also really weird looking.
Almost all the high tech, active controlled directivity speakers seem to be bookshelf-sized studio monitors.
The highest profile speaker that does a pretty good job is probably the JBL M2 (15" woofer). The JBL 4722 (popular with home theater guys) does a pretty good job. And of course numerous DIY designs (for Tannoy fans, take a look at the DIYSG Vortex 12/15).I'm not convinced. Tannoy's tweeter is a horn....
Insisting that towers playing full range, or subs placed right next to or under the main speakers is an antiquated, sub optimal 2 channel belief of the past. Yes, placing subs near boundaries does give some free sensitivity that will keep distortion lower and increase output without additional power. A benefit no matter how you look at it. The main advantage of multiple subwoofers is being able to place them *away* from the main speakers in the optimal positions for a smooth, accurate, high fidelity frequency response. Again, the goal is high fidelity.You know what grinds my gears?
I mean I get it and completely appreciate it most times, but when it blinds one to the inescapably obvious it's time to put the old efficiency and maximization thing to rest.
I just don't need my sub to sound any louder via room boundary phenomena, that's what the volume control dial is for.
I think I covered the rest of of your post. Just may add that their is a time and place for coupling, and a time and place for decoupling.
You must decided if you want to listen to your speakers or your room.
However Klipsch corner horns are very efficient, but in my opinion efficiency is not enough and not a sole reason for doing anything.
Geithains aren’t cardioid through the midrange, just bass.ME Geithain made cardioid speakers before D&D and makes them fully cardioid (down to 30 Hz). See https://www.me-geithain.de/en/rl-901k2.html for example:
https://www.me-geithain.de/en/me-804k.html or https://www.me-geithain.de/en/me-800k.html can be considered towers, I guess.
Sure, but isn't the whole point of cardioid dispersion to avoid exciting room modes? If your dispersion is even, not being cardioid in the midrange isn't necessarily bad, as reflections will be tonally similar to the direct sound.Geithains aren’t cardioid through the midrange, just bass.
They are slightly congested compared to the Kiis/8Cs.
The 8C is cardioid from 100 Hz onwards, it does make sense that modes are tamed in that range; don't really the point here.The stuff out of the front is still going to excite room modes, Dutch&Dutch used to make an 8M model , similar enclosure to the 8C but not cardioid and didn’t have the two rear bass drivers.
Apart from the bass extension the difference was the clearer , less congested midrange.
The PDF posted is for multiple subs, and the article posted says:
This is the problem I ran into (more multi-sub info than single sub info), but was able to weed though the information and misinformation and obtain single subwoofer optimization.
I concur with your observations about center location and resonances giving away the sub's location.
My sub is NOT undersized for the room in my opinion, and has 12" push pull drivers with dual voice coils (as I recall). If anything I want a smaller sub to minimize possible cabinet interference with sound-stage. As this sub is designed to be on the floor (one driver aimed down) I will not be lifting it to the 1/3 height level recommended by Mr. Foley in his video.
A single sub will never work well. 2 subs should be placed in opposite corners which will significantly cancel modes, not either side of the main speakers.
