Yeah. Those would.My stand mounts can bolt to the stands...![]()
Questionable.With a little blutac it can be hard to separate them, tho.
From a pic in another post, I see that you have a cat. They can knock speakers off their stands, and even knock over attached speakers+stands or towers with narrow-plinths.
Nope, you all ready have 2 pussy-cats.Yes, I'm single...
Yeah. Those would.
Questionable.
Has anyone said Yes , yet ?is it by definition a space saving compromise?
I'm not sure how that's easier than just moving the speaker on a stand...
Plus my (butt ugly, I admit) JBL's have such handy handles! I think the old HSU Sub's make a good stand...
Yes, I'm single...
That is a really unique surround speaker you have in the corner of the room. I'm guessing good for highs + mids, but not great for bass. Have you experimented with any room EQ or placement?
The OP title alone is asking several questions at once.
Floorstanding speakers usually save space. For an equivalent cabinet volume, floorstanding speakers take up less floor space than most equivalent bookshelf models.
Without going into detail, the larger woofer has numerous advantages in maintaining linearity and mechanical stability over a given stroke length. The displacement requirement is an inverse square to frequency, so a small "long-stoke" driver can only offer so much LF output. The upper bandwidth of a larger driver will be limited as the wavelengths grow smaller relative to the radiating area.
As for other points:
Hoffman's Law describes the performance of a closed box. It is perfectly possible to cheat Hoffman's formula with an EBS alignment, but this obscures the larger point, that cabinet size, LF performance, and mass-controlled sensitivity are all closely related.
Boundary interference, such as the floor bounce, can be understood by placing a second "image" speaker mirrored over any hard walls, as particle velocity must collapse at walls. You can determine out the resulting interference by summing the real speaker with the image speaker. If the wavelength involved is very long compared to the separation of the real and image sources, then you should not expect any strong interference nulls.
I have a mount for above the mantle that pulls down to roughly where the TV is now, so that will give me back the hearth...but I have to figure some non-ridiculous way of having the third 708 sit there in the middle of it...or somehow mount it to the bottom of the TV mount...
Could you mount it behind the TV when the TV is in the up position, so when the TV is down it is just above the TV? You could even put it on some kind of mount that also extends out to get it flush in the Y-axis to the TV. I'm just assuming you will only use it when you are watching TV, unless you are doing multi channel audio too.
@Chrispy
The stand-mounted speaker may take up too much space. By this, I mean the models with 12" woofers and larger.
Most people are not interested in large bookshelf models, or so I have come to believe.
