Stacking SINAD... is the DAC the weakpoint?
Indeed... Is that not the premise of this website though? ;) I mentioned SINAD in the title, as that seems to be the sites main focus.
It's not. I often see "fresh" members or audiophiles claim that when visiting ASR. I am not sure why. Maybe because it's the first number in the review and Amir has that comparison graph?
Ive been lurking here for some time, and the Engineer in me appreciates the measurement of the audio gear, as the Hifi waffle doesnt tell you much, and even the spec sheets can be misleading, but ive often thought "who can tell the difference between all this?" & "at what point, cant you tell the difference?" and i guess thats the thing i dont know. At what point in the "sinad graph" does it make no difference to how it sounds. 90dB? 100dB, 105?
There's some hard limits discussed here:
Personally, I aim for "better than Red Book" (CD quality), so anything above 96 dB SINAD for electronics. With that performance being available in very cheap components today, it just seems silly not to use it.
Ive read a whole bunch of reviews on here, where the item has been praised and criticised on various results. Some, i can see the reasons for the criticism, Pre-outs being to low, or not very flat, or whatever, and ive seen people get shot down in flames for talking "subjective speak" about how things sound, and that the only thing that matters is the measurements... but if it doesnt matter how it sounds... then whats the point in all of it?
Many people come here claiming to hear vast improvements by swapping X for Y without having tested correctly. It is extremely common for such differences to then disappear once tested under well controlled conditions (blind, level-matched, quick switching). So when asked "how it sounds", the answer often is "identical when properly tested". The question if and when measured performance matters nonetheless depends on many factors. "It doesn't matter" is not the universal answer. Also, good measurements usually point to good engineering, although it is not a guarantee.
From my perspective, the main concern when building my current setup were noise and hiss. So I made sure to get a DAC, an amp and a headphone amp where my speakers and also my sensitive IEMs would not produce any audible noise. That is not difficult anymore today, but it is also not a given with all device combos. So I'm happy I could rely on some good data published on ASR. In other situations, you may need a little headroom for various reasons (EQ, digital attenuation and so on). In that case, it will also be good to know how much headroom there is in each link of the chain.
If speakers are much worse, then so are headphones presumably, so then none of it matters at all?
Headphones are still worse than electronics when it comes to distortion, but at the same SPL they are typically better than speakers. It is not uncommon for a speaker to reach 1% distortion at 94 dB_SPL, while many headphones will still be below 0.5% at that level. IEMs can be even better than that. The variance between different models is huge for all categories, though.
This also does not mean that electronics with less than 1% (-40 dB) distortion are good enough. Distortion can compound along the chain, depending on what type of distortion each device adds. The same is true for noise and other errors. So while the transducers will typically set the lower limit on the error in your reproduction system, you can still make it much worse by adding in more problems elsewhere ;)
So that was the point of the question really, given what ive got and how i'm using it, does an upgrade make sense? So i guess it doesnt.
If a better DAC wont improve things beyond where it is, i'll stick with what i have.
Thanks guys
Adding a measurement mic and configuring some form of room correction would probably be the best bang for buck upgrade in your situation.
To be fair, this alleged SINAD fixation obviously comes from the ranking by it. If you got no prior idea, only "heard things" and you're looking at ASR superficially, you may quickly conclude it's the main measure by which gear gets judged here.
Of course that's false and everyone should do due diligence and investigate further, but at least it's somewhat understandable where this first impression comes from.
Well theres resonances and port chuffing, I guess you could call those noise?
Yup. And those are serious problems.
It isn't at all.
Some people just claim it is the main focus.
SINAD number is just a single number that is easy to rank.
I don't know if you noticed but there are just 4 tiers.
These tiers say something about signal fidelity (NOT sound quality) of a 1kHz signal under equal circumstances.
Nothing more than that. They say nothing about sound quality but say something about the engineering involved.
Otherwise ... what would be the point of all the other measurements.
If SINAD were the focus then only that number would be shown.
At the current levels it is just a pissing game between manufacturers.
Veification of specifications and actual performance.
Yes, some headphones are. In general, at the same volume level (at normal listening level) speakers are worse but when it comes to deviation in frequency response speakers are better, only to be 'fff up' by the room.
Indeed it doesn't as changing the DAC won't change the SINAD of the system.
That's what I would do unless the old one needs replacement, has poor performance, does not exactly what you want it to do, or is defective or lacks connectivity.
Thanks guys
This!
And some light-fingered PEQ / tone controls, loudness contour...
DAC and amps is just a numbers game and shows performance at a certain level at 1kHz only.
To be more specific though, within the test suite;
JSmith
Thats all good info, thanks.
Ive generally felt the following with audio components:
Anything more than 44.1khz, 16 bit is wasted on me. not saying no-one can hear the difference, but i cant.
Ive never really heard any difference between various DACs, but always felt it should be reasonable to not be a weak point. a good budget DAC is a relatively low cost on the grand scheme of things, so may as well get something decent.
Amps should sound the same, but i dont think they do. My mates dad has a Teac amp and it just sounded shit. it didnt sound defective, just shit. flat and lifeless. no idea why. I tested a Rotel amp against my Denon AV amp a few years back. It was largely pointless because, as you say, i couldnt change it instantly to give a proper AB test. I came away thinking that there may have been a slight difference, but one wasnt obviously better than the other, so i didnt bother using the Rotel. It has an AV bypass mode, so i was going to use it for the fronts. As long as its decent enough, has enough power and has a proper feature set, should be fine.
Speakers though... they do sound different, even between very similar designs. The nice ones are also a lot more expensive since i last went speaker shopping (which was probably the 90s, so everything is more expensive now obviously). So My question was really about, ive just bought some £700 and my source is an an ALL-IN-1 double mic preamp ADC, DAC and headphone amp (sort of) that was £150 new, and an amp that was £25 from ebay.... just wanted to know if i was doing the speakers justice.
EQ wise, i could do some EQ on the PC for the PC audio side of things, which is all that matters from a sound quality perspective. i cant DSP the lot, as the latency on the guitar would do my head in. For now though, i'm quite happy with how it sounds. Much happier than i was with the Tannoys.
Regarding my comments about SINAD on here, i should perhaps spend more time on other parts of the website. My apologies if ive been a bit short sighted in that regard. It is an excellent resource.
Thanks All
Thanks All
It's very common for people think ASR is all about SINAD. You aren't the first. :cool:
It is a good indicator of well-designed electronics since to get good noise and distortion performance requires careful layout, grounding, and component selection. And in many cases we see DACs built around chips with intrinsic S/N and Distortion better than 110 or 120dB get hamstrung with large amounts of mains noise and large amounts of harmonic distortion. Even when these are below threshold of audibility, it is a red flag that the design is poor and there are likely other issues. Many examples exist, here are two at the upper end of price-reality:
But you could still have a device with high SINAD but poor frequency response and it would suck to listen to. FR is really audibly important.
Regarding the Teac, it would need to be tested to see if it has issues. I restore and test old gear and much of it has problems that need addressing (mostly the volume and tone controls, switches, and relays). If the Teac is vintage there are dozens of reasons the unit could sound bad. Amps that are properly working are almost indistinguishable. For example David Clark tested amps and people's abilities to distinguish amps from each other, including tube amps, see page 78:
https://americanradiohistory.com/Archive-HiFI-Stereo/80s/HiFi-Stereo-Review-1987-01.pdf
Nobody was able to discern the difference with high confidence in this test, which included a Futterman OTL-1.
I am glad you are enjoying your new speakers, I am not a Tannoy fan but don't want to speculate on the sound. Your pair seemed to have issues.
I think you have a pretty OK DAC, with one odd issue Amir pointed out:
I don't have this Arturia Minifuse unit, would like to explore more what is going on, don't want to speculate too much on the audibility except to say there are ~$100 DACs that have fantastic SINAD across input and output levels. For example:
Good luck!
Good luck!
That is a weird result. i'm probably mostly in the lower end of output level on the Minifuse.
Regarding the Tannoys. I dont think there is anything specifically wrong with mine, i just think the design isnt very good at blocking out interference. both speakers behave the exactly the same and they arent sold as pairs, they are sold individually, so its unlikely they have both developed the same weird fault. I'll take them into work and see if they behave themselves there. I suspect they will be perfectly quiet.
Interesting to note... While the Minifuse' ADC is not great and has a few odd issues, it's good enough that you could loopback the output to the ADC's input to explore what is going on at low voltage. Measure if your unit has the same issue. You could use Room Equalization Wizard for these measurements, which is free and awesome. It might be an interesting way to spend a couple evenings. Becoming proficient using tools to diagnose audio issues and evaluate benefits and degradations is more what the forum is about. It may also be a pointless exercise in frustration and/or boredom, so take my comments with a grain of salt.
I see, sorry I misinterpreted. Do you like the sound of them?
Ive used REW plenty of times. thats a good shout, i might do that if i can find the time. Ive done way more car audio stuff, than home audio stuff. so ive used REW quite a bit for that, with a measurement mic, and measuring frequency response coming out of modern car stereos (which is awful in most cases) which incidentally, was the reason i bought the Audio interface in the first place, to replace the TASCAM i had before that that stopped working with modern windows.
The tannoys are ok. The look the part, and people that use them for mixing are generally very pleased with them, but they are studio monitors. There is a reason why people dont use hifi speakers for mixing, and i guess that works the other way also. i found them a bit "in my face" for my use case. Sound great with the guitar, slightly better than the new setup, but the Dalis are nicer to listen to music on. I dont need them to be accurate for mixing, just to sound nice.
I've been meaning to test some of my old Soundstream car audio gear just for fun. I did measure my old A/D/S autosound speakers, they still test very well.
It would be interesting to see measurements on the Tannoy. You could also use the interface plus mic for that. Or a USB mic, like a UMIK-1, or even a cheapo USM measurement mic. I am intrigued at how Tannoy executed the concentric driver. It looks rather odd, and may be an adventure for tweeter/woofer integration. Studio monitors don't have to sound dramatically different from good hifi speakers and visa-versa. People have been using good- and bad-sounding HiFi speakers in the studio, good- and bad-sounding studio monitors at home, and all combinations. I have several good-sounding studio monitors I prefer listening to over most gear at the HiFi shop. One pair is particularly ugly, but I feel many HiFi speakers are gaudy and even worse to look at. Check out some of the reviews of studio monitors at ASR, some of them are fantastic, others are questionable, just like the home HiFi market.
In any case, enjoy!
Its only 30dB SPL in total and mainly LF for which human hearing is insensitive but is quite measurable.
Decided to do a little experiment. I generated a 3 KHz tone (about where human hearing is most sensitive) and recorded a 5 second tone at zero dB in Adobe Audition and added a few seconds of silence. Then I copied/pasted that at -10 dB, -20 dB, -30 db, etc. down to -80 dB. Then I set the volume on the stereo where the initial tone played at 85 dB, measured with a sound meter. (A very annoying tone at that level!) Then I listened as the level dropped. At - 50 dB it was very quiet -- probably impossible to hear if it was a background tone that was part of any louder music. Then at -60 dB it was just barely audible. One has to be concentrating and looking for that specific sound; would have otherwise not noticed it at all. And the -70 dB and -80 dB sounds were completely inaudible. The room seemed dead quiet.
My conclusion is that an in-room dynamic range of 60 dB is more than enough for music playback. No way am I hearing the difference between one piece of gear with a SINAD of 90 dB vs one with 120 dB if that's the only difference. That said, I do realize that noise can be cumulative with multiple pieces of kit, and I also realize that some people listen much louder than I do, and that younger people may have better hearing (beyond just frequency response). Even then the residual noise of most modern electronics should be well beyond anyone's perception.
I remain the biggest variable in my stereo system!
I have done similar experiments but with music playing pretty loud and found that attenuation of -70 dB was complete silence.
Basically resulting in an effective dynamic range of about 60dB for normal listening level.
This is why I am of the opinion that 80dB SINAD is enough and for digital volume controlled DACs a SINAD of 100 is sufficient.
