Stacking SINAD... is the DAC the weakpoint?
champ222
Hi All
So i'll try and keep this as short as possible.
Old system
  • PC, with Arturia Mini-fuse 2 audio interface - Review here: Review
  • Balanced out from the interface to a Presonus SUB8 - Notes on the IN/OUT here (It adds some noise): Filter test
  • Balanced out from Sub to Tannoy Gold 5 monitors.
Functionality is key here. The kids use the PC, so tuning up the volume on the audio interface makes sound. sub and tannoys have auto switch on. I use the analogue inputs of the interface for my guitar modeller, and i can blend PC audio and guitar audio with the mix knob. All is well. I added the sub because the tannoys lack a bit of bass, even compared to other 5 inch monitors.
Issue
I was getting some interference from one of the tannoys. swapping them left to right, the noise stayed on the left. Unplug the input, noise still there. Connected a mains extension, walked it around the house. In various positions, it would pick up noise. I think its from the mobile phone mast nearby. I cant move the desk, so decided to change speakers.
New system
I dont "need" studio monitors, i bought them because they would work well with the interface, so i bought some passive HIFI speakers, so now i'm setup like this:
  • Balanced out from Sub to Extron XPA U 1002 amp - This is a newer variant of the amp reviewed here: Review
  • Dali Opticon 1 Mk2 speakers
The internal layout of my amp is very different to the pics later in the thread of the amp review. So i'm assuming the amp should be of similar quality, but i guess we dont know for sure without someone measuring it.
So my question (finally). Reviews seemed positive for the amp, but less so for the interface. Considering the noise added through the sub and the amp used, is there any benefit in switching the Arturia minifuse 2 to, say, the Motu M2? review here: Motu M2 (it has much better DAC results) or would the noise added by the sub, and the amp used (assuming similar performance to the one tested) make any interface upgrades pointless?
I could change the sub, or route the signal differently if this noise is likely the biggest issue, but sound wise, it does the job for the tiny room i'm in and its convenient, wired this way.
Thanks
PS, if i wanted to submit the U variant of the amp for testing, where would i send it?
Thanks
The weak points are the transducers, the background noise in the room and the hearing.
Speakers all perform much worse than the DAC or amps.
You would not believe how poor the SINAD of speakers is and what SINAD (when distortion is dominant) is required to sound 'excellent'.
DAC and amps is just a numbers game and shows performance at a certain level at 1kHz only.
Stop worrying about SINAD unless you hear noise when nothing is playing in which case you need to find a device with a lower noise floor.
What solderdude said. The DAC and amp makers would love you to believe there's something to be gained by exceptional SINAD, but the noise is the important part. And speakers are orders of magnitude worse than modern electronics.
Hi All
Old system
Issue
New system
Thanks
Thanks
How much gain are you using with the power amp? Maybe you will benefit from higher gain at the interface, and lower gain in the power amp? If you aren't already trying to distribute the gain this way to minimize noise.
In return, speakers' SINAD is practically entirely distortion-dominated hehe
Yup. Not a lot of noise unless it has serious problems.
Another way to look at this -- the ambient background noise in my living room is around 30 dB with electronics and appliances off. My "serious" listening level is around 80 dB, maybe 85 dB if I'm rocking, and perhaps a few peaks above that. That's a dynamic range of about 50 to 60 dB at best. My streamer, DAC & amp all have SINADs in excess of 100 dB. It sounds like you had an RFI issue. Hopefully your new setup won't be as sensitive to this interference. The question now is whether or not you will like the way your new speakers sound compared to the Tannoys.
Its only 30dB SPL in total and mainly LF for which human hearing is insensitive but is quite measurable.
But some ported speakers do add port noise which can reach audible levels ;)
Not well-designed ones, but yes it happens more often than I would hope.
Yes I thought that, I guess you could call that "mechanical noise"? Even if inaudible it must be orders of magnitude worse than any electrical noise from crossover opponents and coils.
In addition, some woofers make mechanical noise at high travel, especially accordion surround. That's one reason you don't see accordion surround on many hi-fi woofers.
Indeed... Is that not the premise of this website though? ;) I mentioned SINAD in the title, as that seems to be the sites main focus.
Ive been lurking here for some time, and the Engineer in me appreciates the measurement of the audio gear, as the Hifi waffle doesnt tell you much, and even the spec sheets can be misleading, but ive often thought "who can tell the difference between all this?" & "at what point, cant you tell the difference?" and i guess thats the thing i dont know. At what point in the "sinad graph" does it make no difference to how it sounds. 90dB? 100dB, 105?
Ive read a whole bunch of reviews on here, where the item has been praised and criticised on various results. Some, i can see the reasons for the criticism, Pre-outs being to low, or not very flat, or whatever, and ive seen people get shot down in flames for talking "subjective speak" about how things sound, and that the only thing that matters is the measurements... but if it doesnt matter how it sounds... then whats the point in all of it?
If speakers are much worse, then so are headphones presumably, so then none of it matters at all?
So that was the point of the question really, given what ive got and how i'm using it, does an upgrade make sense? So i guess it doesnt.
If a better DAC wont improve things beyond where it is, i'll stick with what i have.
Thanks guys
I'm not getting any real noise at all now ive moved on from the Tannoys. They have a "gain" control (input attenuator i assume) but the noise was the same wherever that was set, and if there was or wasnt a source connected. The only thing that had any effect was its physical location in space. I get no other noise in anything just these active tannoys. Weird.
You may want to check your cabling., You say you use balanced cables but your sub is apparently unbalanced on the in- and outputs. Using balanced cables in this case can certainly pick up rubbish.
As stated, the noise issue from the tannoys was there, even without anything plugged in but the mains. And also there with and without the sub. Ive already moved on from that, i have a new system now.
Also, from the specs of the sub:
Overview​
Features​
  • 8-inch composite low-frequency driver
  • Bluetooth® 5.0 wireless audio stereo input
  • 50W RMS, Class AB power amplifier
  • 30 Hz to 200 Hz frequency response
  • 100 dB SPL (Peak, @ 1 meter)
  • Input gain control (-30 dB to +6 dB, continuously variable)
  • Continuously variable lowpass filter (50 Hz to 130 Hz)
  • Defeatable highpass filter removes frequency content below 80 Hz from the full-range signal sent from the Eris® Sub 8BT outputs to the main speakers
  • Left and right, balanced ¼-inch TRS and unbalanced RCA main inputs
  • Left and right, balanced ¼-inch TRS and unbalanced RCA pass-through outputs for connecting satellite speakers
  • Polarity invert switch
  • Protection: RF interference, output-current limiting, over-temperature, turn-on/off transient, subsonic filter
  • Power Saver mode (engages after 40 minutes)
Aah, my bad. Didn't see you moved on and misunderstood the specs on presonus's site. Anyway, fun to waste you peoples time., ;P
It was noted in the hiss thread that the Gold 5 have hiss.
yes. This was a lot more than a bit of hiss though.
