Bart LXIX
- Joined
- Sep 7, 2025
- Messages
- 8
- Likes
- 4
I have some SS-5 and SS-5R diodes that seem out of spec enough to replace (I know they are supposedly indestructible). But from what I can gather, they should read around 0.4v and mine are reading 0.58 and 0.59v. Is this enough to be concerned? Is the info I found accurate? My thought is to use FR1004Gs and solder wire under the board to bridge the cathode (SS-5) and anode (SS-5R) sides.
Are the readings I'm finding legit and should I bother? They're already pulled from the boards (Sansui G-8000), so I can replace them or they can go right back in.
