Hi folks,
Dropping in again for an update on my shenanigans.
As I think various conversations on this thread have indicated, it is difficult to say the least to predict the results of trying to damp resonances/isolate/couple etc with any particular speaker in any particular room. As Frank D. pointed out to me, even just moving the speakers to different spots on a sprung wood floor is likely to change the resonant character/frequencies involved.
So I'm down to, as I've said, throwing spaghetti at the wall, trying things to see what if anything alters the sound in a way I like.
The new thing that has changed is that I now have my Joseph Audio Perspective floor standing speakers back in the system (replacing the Thiel 2.7s referenced in this thread). They are responding slightly differently than the Thiels.
First using them with their supplied outriggers and spikes, they sounded quite nice. The bass is actually a bit more controlled (through some of the spectrum) than the Thiels in this room. But I had the Gaia footers and wanted to see if I could still tighten things up. Unfortunately the Gaia footers fit fine on the back of the speakers, but I could not remove the front spike/cones from the outrigger to install the Gaia (the cones won't come off as apparently they have a stopper - some glue - holding them to the bolt that would separate them from the outrigger).
So I had to just screw the front Gaia in to the existing speaker cone like this:
Results: It just didn't work.
I found no real benefits to the sound, if anything things seemed to get a tad more mushy and diffuse sounding. Directly coupled to the floor sounded more firm and in control.
But I did kind of like the slightly raised soundstage so I thought what the heck, try something else to raise the speakers. I left the Gaias on the back of the speakers, but took them off the front outriggers, put in the bottom 1/2" spike on the speaker cones, then a hockey puck, which was held more firmly in place on the rug by placing the Isoacoustic carpet spike cup beneath the puck (buried in the rug). Since that raised the speakers a bit higher, I also shoved the carpet spikes under the back Gaia, raising the speakers up about another 3/4" vs the previous all Gaia set up:
Well, that the heck? This sounded terrific! First of all it sounded a bit more tight and solid vs the full Gaia set up.
But also the soundstage was raised even a bit higher which increased the subjective sense of scale too. Also the sound
took on an even more pleasing (to me) tonality - a more lush, thick lower midrange especially giving nice richness and heft to the sound.
Now we are cookin' !
My sense from this is that I would like to raise the speakers more, get something under there because I like that raised soundstage and lushness I
was hearing. But I wondered what my options were. So I bought a bunch of other stuff to try. Among them 2" thick cedar fence end caps that replaced the hockey pucks with. Didn't sound as good, went back to more mushy.
Next I tried constructing a make-shift base for the speakers. I used two sheets of 1/2" thick MDF layered together with sound damping material in between.
Felt pretty solid for the knuckle-rap test. The thing is I have TWO important goals for anything under the speakers: Improve sound quality AND it MUST help the speakers be moved more easily along my carpet. The reason is I have a big projection screen and if I can easily shove the speakers a foot to the side, it allows for a larger image.
SO...I drilled holes so I could use some Herbie Audio Lab slider feet, which I'd used under my Thiels for sliding them around:
Ok, so now I had the speakers on that quickly built platform, with the slider feet at each corner.
Results: Not good. Did nothing good for the sound, if anything again a bit more mushy.
Hmmm.....what to do now?
Then for the heck of it I replaced the Herbie footers with the spring footers - the footers mentioned in the beginning of this thread, that look like this:
Well...what do you know?.. that was interesting. The bass did seem to tighten somewhat and loose some boom particularly for the lowest problematic bass torture tracks. But unlike the Thiels, which when raised on those footers became a bit too lean and bright sounding for my taste, it didn't seem to have the same detrimental effect when raising the Joseph speakers. This was promising. But the Joseph speakers do best with some tilt, so I then added the hocky puck under the front spikes. Here's the photo (you can't see the spring footers under the platform because of the high shag rug):
And ...BAM!!!....the sound just clicked in! The speakers just "disappeared" more, got that lush rich sound again, and yet bass test after bass test showed some of the tightest bass I've had in the room. So many of the torture tracks in which well known bass notes would jut out in a bloated manner were now significantly more laid back and in control. And the speakers are raised even a bit more, making for an even more massive sense of soundstaging. Yay!
SO...here is my dilemma and goal:
It looks like I've found a speaker height and angle that I really like. Something has to go under the Joseph speakers to keep them in this position.
But it's still hard to know for sure how much of what I'm liking has to do with JUST the raising and angling I've introduced, vs what is holding the speakers up.
I am quite certain the spring footers are playing a role. As before, unlike using all the other coupling or decoupling stuff, with the spring footers I can feel much less floor vibration when the speakers are playing heavy bass.
The last thing I'd like to try, to strike it off my list, is just sheer mass - some heavy stone, granite perhaps, under the speakers. Ideally a really dark black marble would beautifully match the black parts of the Joseph speakers. But I understand Granite is more solid/heavy.
However, I have a feeling that springs will end up being involved in my final design.
Any thoughts welcome.
