This contributed article by IsoAcoustics` founder and president is an interesting piece that sums up his vast experience in the field, working with professional audio engineers, loudspeaker designers, and music lovers all over the world. The article explores how speakers physically interact with...
audioxpress.com
Recentish article on Isoacoustics. More of an advertisement, really.
They posted this chart, which is hard to read and even misleading in some ways.
If you look at the frequency response, you get these tiny, tiny deviations (well under a dB) in an anechoic setting between speaker spikes and the Isoacoustics GAIA II feet. They also include a secondary axis for velocity measurements using a laser vibrometer, which look much more dramatic. I'll just note here that the bungee cord measurement is at best only academic, since they introduce rocking modes into playback. The writer (the founder Dave Morrison) says as much:
I extracted the GAIA II and spike velocity measurements and converted them to dB using the following formula.
I imported the results into REW. The results at best are about a 10dB reduction vs. spikes.
Here's the same information, plotted against the minimal hearing and vibrotactile thresholds.
The question is how much any of this matters.
You certainly can't feel the difference with your feet.
We have to consider that none of these vibrations will be heard by themselves. The above sweeps were made at around 90dB SPL. Speaker multitone distortion allows maybe 30dB distortion-free range at that level. Maybe 40dB. On top of that, the vibrations will integrate and sum with the response of the speaker, and contribute directly to the measured frequency response. And Morrison states directly that the FR deviates by less than 0.3dB! Think about that: the contribution of the 10dB attenuated vibration is less than 0.3dB at 90dB SPL.
Say the directivity of the vibrations is different from the directivity of the music. That's probably true. I would still guess that the audibility would be subtle-to-none at best. In the range of effectiveness, room modes, SBIR and reverb are active. On top of that you introduce masking from the music itself.
I think this is one of those products that makes sense but only as the tweaker's last rational stand. It might also make sense, as an expensive fix, where there is a prominent vibration problem for some idiosyncratic reason to do with what the speaker is on.
The last thing I'll say is that the more important comparison would not be spikes, which couple the speaker to the floor, and not bare cabinet on carpet, hardwood or concrete, but the normal rubber or elastic dots that most manufacturers include on speaker bottoms. I would imagine the measured difference would be much less significant compared to something so basic.
