Thanks for pointing this out I stopped watching the video when I noticed the accelerometer was placed in different locations on the speaker from trial to trial. I just watched the end with the in-room measurements. there were actually no changes in the Frequency response:Later in the video they measured the sound from the loudspeakers using a microphone. So if there were changes, there were changes in the sound.
They do provide the data, it shows no change.:
On the order of run to run variability, which I am careful to show in the tests I post here. Or maybe the difference is due to the isolation materials, in which case it is verifiably tiny. So no change in the FR.
I guess I am not surprised they then rolled out the time-domain argument, evoking PRaT along the way. The time domain graphs hey show are incredibly weak, and if the time-domain differences are significant then would show up in the FR. And now that you pointed out the end of the video, I now realize they are either naïve, disingenuous, or complete carnival barkers.
Yes there are changes in the vibration spectra of the cabinet, they weren't able to measure sound changes. Once again, they are some effects, but not large enough to change the frequency response. And the measurements actually support.So if there were changes, there were changes in the sound.
And that’s the claim I was addressing - that there was “ no mechanism by which the sound could change.”
They disproved their own product's effectiveness in this video. They should publish a whitepaper with the data, probably include the FR first so we can start with the important things.The level of audibility is another issue, and presumably would be variable depending on the loudspeakers/floor/what might be sitting between them, etc.
I do share your skepticism when it comes to manufacturers not using actual music or sound signals to demonstrate the claims.
For instance, there’s a nice Townshend demonstration video using vibrometers showing how loudspeakers placed on their platform are isolated from impact vibrations on the ground around the loudspeaker. And there’s also a demonstration showing that the loudspeaker on the floor when it is tapped shows ringing, whereas when they are sitting on the platform when they are tapped, they show a much cleaner impulse response without the ringing.
So something is going on there.
However, what I want to see are such results demonstrated using musical signals, or at the very least a Sonic impulse signal sent through the drivers, showing the same phenomenon, rather than just impacts upon the speaker.
