terryforsythe
The question "how much power do I need?" sometimes is asked. But, the correct answer is dependent on numerous variables. To help, I have created a spreadsheet for calculating amplifier power requirements and made it publicly available at the following link:
docs.google.com
The yellow boxes are for user data entry. I left the permissions on those cells unblocked, so it should work. If not, the equations can be copied into a spreadsheet on one's own computer.
For "Desired Maximum SPL", ensure the value is high enough to cover transients. Adding an additional 15-20dB may be sufficient in most cases, but perhaps a bit higher in some cases (e.g., uncompressed music).
Some amplifiers can output transient power higher than their RMS rating, but that probably varies from amplifier to amplifier and I don't often see that specified anymore. If it is accurately specified, though, the transient power rating would be what to use for comparison to the "Amplifier Required to Get Desired Maximum SPL" assuming that the "Desired Maximum SPL" is set to include transients.
NOTE: This spreadsheet does not consider the room response and is intended to get someone into the ball park of where they need to be with regard to amplifier power. For a more detailed analysis, also analyze the room (e.g., using REW), and take those results into consideration when setting the "Desired Maximum SPL".
EDIT: I have updated the spreadsheet to add estimates for room gain and gain from speaker placement.
Amplifier Power Requirement
