I'm planning to build a valve-based phono stage as an upcoming autumn/winter project, for no better reason than I have a PCB and time on my hands.
Before anyone suggests a 5534 phono stage instead, I have one of those already, and it works better than any valve based stage ever could, but I have the PCB so fancy building something with it.
The phono stage has three double-triode valves, one input stage, one second stage and a final cathode follower stage.
The passive RIAA equalisation can all be done between the first and second stages or split between the first/second and second/third stage.
The design information I have for the PCB makes no comment about the performance differences between the two, and I can't find anything on-line about the differences, except the usual subjective 'this sounds better' type statements without any corroboration.
Any views on which would result in lower noise and/or better overload performance? I'm inclined to go with split EQ as the noise of the first and second stages are attenuated before passing to the output cathode follower. However, what this does to overload performance I don't know, as there are various options with valve type and stage gain, each which will affect overload performance, so that's a question for another time.
I plan DC heaters and a switchable transformer for MM/MC cartridges.
Thanks for any helpful suggestions.
S.
S.
