Thanks for adding "Sort By" dropdown.
Is is possible to add a "USD" currency as well?
I'll gladly gather all the USD prices and send you a spreadsheet.
Missed one.Digitized:
1. Audioholics / Arendal Sound 1723 Monitor
Missed one.
Also noticed that search is working strangely.
I search for LS50 and I only see 1 result, and it should be 3 (LS50, LS50 Meta, LS50 Wireless II).
Also, I finished compiling all USD prices into a spreadsheet...small progress.
Errors:
Nexus MT DIY - not a center, but bookshelf?
LYX SPA8PAS - not passive, active
Elac Debut 2.0 A4.2 - blank graph
Revel W553L -in wall, not bookshelf
Vandersteen 2c - tower, not bookshelf
Polk Audio T50 - tower, not bookshelf
@pierre Thank you for your great work, which I should say at first.
But LW and ER of Revel Ultima2 Studio2 are wrong, resulting PIR and the score being better than the actual.
Please fix.
And, can I ask you to implement "Sort by the score with sub" and "Sort by the score with sub and Eq"?
That would show more interesting results.
The LYXSPA8PAS is passive, that's what the PAS suffix is for, the plain SPA8 model is the active one.Errors:
LW is shown as ER and vice versa.Do you have better/correct data for the Revel? or I do not understand what's wrong.
I added the sort functions. It gives some funny results.
at https://pierreaubert.github.io/spinorama/"Sort by the score with sub" and "Sort by the score with sub and Eq"
Me neither, if I'm honest.I don't see the mentioned sort functions
What's wrong with me or my browser?
Thank you, and indeed the sort functions showed me very interesting results.That's because I forgot to push the new code...
I fixed a few small issues, added the last speakers. Arendal Sound 1723 is still not working ...
I didn't check the EQ for the very special Grimani Alpha. The score is very low which looks strange to me, maybe because of the very constant directivity.
Pushing now and let's see what happens. It usually takes 10-30 minutes so don't jump on it yet.
Let's compare LS50 measured by Amir and the same speaker measured at 3d3a labs (valid above 500hz):
We can confirm high similarity (except for early reflections). Same results with Ascend Acoustics CBM 170:
Why does my comment come at qoatesQuite different to my eyes
I don't know, those Grimani Alpha measurements look not so great, especially for not being super high resolution, and the normal score for sure punishes for the lack of extension. It has very nice constant directivity, but a ton of resonances, and the overall slope is tilted up. The ER matching the LW and on axis above 10kHz is super interesting though.I didn't check the EQ for the very special Grimani Alpha. The score is very low which looks strange to me, maybe because of the very constant directivity.
I was wondering if these measurements could be digitized: https://www.soundandrecording.de/shop/studiomonitore-specialAs usual...If anyone else finds a spinorama online, please let me know and I can digitize.![]()
I don't think that would be legal to post or use them here as they are not offered for free, unless someone gets/buys the rights for them.I was wondering if these measurements could be digitized: https://www.soundandrecording.de/shop/studiomonitore-special
Thread about them here: https://www.audiosciencereview.com/...-loudspeaker-measurements-for-dirt-cheap.6437
