spinorama.org
@pierre
Some feedback regarding the graphs, if you don't mind.
First, the Customization menu was reset to default:
  1. Resizing the browser window resets which graph objects you have enabled/disabled via the legend. Very annoying.
  2. The extra-thick grid line at 0dB can be distracting. Please let us disable it in the Customization menu.
  3. On Axis, EIR, SPL Horizontal, SPL Horizontal Normalized, SPL Vertical, SPL Vertical Normalized:
    I cannot get rid of these Midrange ±3dB dotted lines, as they are not listed in the Legend. Are they supposed to be coupled to the ±3dB Band object?
  4. Depending on the browser window size, the graph title and control icons on the right edge can be cut off:
  5. Why does the Legend position switch back and forth between 'below the graph' and 'to the right of the graph', seemingly at random?
    Screenshot 2026-11-04 205459.pngscreencapture-spinorama-org-compare-html-2026-11-04-20_59_05.pngscreencapture-spinorama-org-compare-html-2026-11-04-20_58_53.pngscreencapture-spinorama-org-compare-html-2026-11-04-20_58_39.pngscreencapture-spinorama-org-compare-html-2026-11-04-20_58_25.pngscreencapture-spinorama-org-compare-html-2026-11-04-20_58_10.png
    I know that this is affected by window size, but the inconsistent behavior is irritating.
  6. SPL Contour:
    The way the graph aspect ratio scales with window size is annoying:
    screencapture-spinorama-org-compare-html-2026-11-04-21_05_18.png screencapture-spinorama-org-compare-html-2026-11-04-21_05_18 (1).png
  7. SPL Contour 3D:
    It would be nice if the rotation and zoom of both graphs were linked to each other, so that however you position one, the other is the same.
  8. SPL Contour Normalized:
    Consider filtering out the small, positive gain "blips" just to reduce visual clutter:
    I believe Klippel made that decision as well a while back:
    Kali IN-8v1 Beamwidth_Horizontal.png -> Kii THREE Horizontal Contour Plot (Normalized) (1).png
  9. SPL Globe:
    -Lags terribly when scrolling or resizing, much more than Contour 3D which is crazy.
    -Weird scaling issues where the legend is placed on the title or the globe:
    -Frequency axis is locked to 0-500Hz linear. What if I want to see full-range?
  10. Radar:
    Missing Legend for turning on/off certain traces limits usefulness:
PS:
My apologies for all this whining about Spinorama, despite it being an incredible resource and free to everyone.
@pierre
    View attachment 569396View attachment 569398View attachment 569399View attachment 569400View attachment 569401View attachment 569402
  6. SPL Contour:
    View attachment 569406 View attachment 569411
  7. SPL Contour 3D:
    View attachment 569414 -> View attachment 569413
  9. SPL Globe:
    View attachment 569416 View attachment 569417
  10. Radar:
PS:
Looks like one of the agent push to prod instead of devs ...
OK the idea is that some people are scrapping the data when they should not and using them for commercial purpose.
I have been think about what we could do about it.
1. there is nothing you can do if someone is determined to get the data. I can automatically extract the data from Erin's YT video in 1 click (I even built a software doing exactly that and i have, at least for now, removed access to it)
2. i blocked access to the api and now you need a key to access it. that was used a lot and i dont think it was for "good" reasons
3. the graphs by default will be a bit harder to read (such that scanning is not easy)
4. there will be an authenticated mode that will give you perfect graphs again. I have not figured out how to qualify someone and how to prevent someone to use this to get the data.
The graphs needs to be fine tuned again and i will do it when i have some time. Slow graphs are likely not using the gpu well.
P.
P.S.: fun fact, i can now generate graphs 30x faster than before with home made tech, playing with AI is cool :)
SPL Globe
@pierre Globe plot has an illogical scale and is difficult to interpret; it also contains redundant information, so it should be omitted as it is of no value. For example, EAC has already removed it to free up space.
I like the globe plot and would be sad to see it go.
Just bring it closer to Klippel's presentation to make it more useful:
Source
LF is just single point and HF may look valuable, but phase axis is not linear. It's simply terrible POS with zero value.
Source
That's not a KLIPPEL output. That's my own output that I generated years back with my own MATLAB script.
I disagree. Most people find it more intuitive. I just got tired of people complaining about the redundancy and gave in. I shouldn't have. And my updated site will allow many viewing options so the reader can choose which they find most intuitive. Obviously you're free to continue with whatever presentation you choose in your own software or website.
:facepalm: Personal intuition does not guarantee anything logical, accurate and valuable. Based on the globe plot, the impression of directivity is highly distorted and bandwidth is limited so it's really bad and unworthy. Of course people are free to like anything, but reviewers and other publishers could have some sense and determination which kind of graphs give full and correct information and impression at first glance. Not just nice colors and shapes.
It is clear you are biased toward a more traditional graphic style and that is fine. As I said, you are more than welcome to stick with your standard contour plots. That's why I provide both options. The purpose of the "globe" is to unwrap the contour plot, allowing the viewer to get a clearer picture of how a speaker radiates sound in different axes. It is indeed, intuitive. And without sounding too blunt, anyone who would argue against intuition implies the desire to be unnecessarily complex.
Given the similarity of presentation style, I suppose you really despise the typical polar plots as well. Which is industry standard in the pro audio world, as you surely already know. Judging by the number of people who ask about it - consumer and manufacturers - there seems to be a strong population who do enjoy it.
Furthermore, one could argue the only graphic we really need is standard frequency response vs angle lines since the contour plots are effectively the same thing, too. But you and others - including myself - still like the "intuitiveness" of those contour plots. Guess intuitive graphics aren't so bad after all...
At any rate, you do you. Having different ways of viewing data is helpful. And the feedback here and elsewhere indicates that they all are helpful in one way or another.
I am biased toward unbiased full range information and proper impression without strong visual weighting of HF. Large colored area has more weight than tiny or non-existing.
You and fans of globe plot may or may not be aware that for example large LF radiator with directivity index of 5-7 dB at bass...lower mid crossed at mid-range to conventional small box with DI=5-8 dB is able to lift sound reproduction to whole new level. So directivity graphs such as globe plot shrinking visual weight and hiding bass are no less than misleading. More is actually less without adequate knowledge to completely skip that visualization. Sure it is possible if better options are available, but gives at least impression that the author just spits more graphical information without much focus to the topic.
No. Polar plot gives correct impression because it does not reduce visual weight and hide bass range. Magnitude as radius gives correct impression at whole range. The problem is single frequency representation which requires adjusting and multiple overlays. So polar plot is not suitable for example for manual or automatic directivity adjustment and sound balancing with crossover.
if I understand correctly, @kimmosto is not opposed to intuitive information design but rather that he weights accuracy above intuitiveness, and he is arguing that globe plots are misleading. I don't understand the particulars, but I'm mentally analogizing with the Mercator projection--a very intuitive way to map the world, but one that is inherently and irremediably a distortion of real scale and distance.
