That was what was being discussed at the time.
But yes, this would apply to all of my data. Thank you for asking.
Really appreciate all the data you put online and thank you for clarifying.
Some folks need to read what I wrote before commenting. It would save a lot of time and energy.
Look here:
Call me crazy, but I think the current forum equilibrium of silly vs anal retentiveness is pretty much where it should be. There are bound to be occasional a-holes, but we don't want the cure to be worse than the disease Yes, I completely agree with you. With such a large number of people...
www.audiosciencereview.com
Where it says:
I'm not okay with:
- My data being scanned and converted to a different format and uploaded to a different website.
And then something on a gray area, which also does not seem to apply here from what I understand.
Not trying to put words in your mouth, just trying to get clarity here.
I type out what I think you mean so you can correct me if I interpreted it wrong.
You spend considerable time and money to generate spinorama data, that you took of a speaker someone else build to then share it on your website.
Which you then shared with spinorama.org.
But If I then look at the data *from spinorama.org that originally came from you, interpret the data and see things to improve with EQ
Take data exported from Spinorama by someone else and import it into REW
Then make an EQ with it by hand, not computer optimized
Get the speakers so I can test it and make adjustments before sharing the EQ
And then share the results online, showing a before/after and mentioning the sample measured was by EAC
Would I be in the wrong?
If so, when am I in the wrong according to you, is it when I show both the before and after spinorama in a post on ASR?
Can I show the after or is using your measurements to generate the EQ and sharing that wrong to begin with?
Because I now took your work that you took from someone else their work, to model with and then present my work.
If this is the case, what would you need from me?
And is
@amirm also in the wrong because I shared what I did on this forum?
I will gladly ask him to remove my posts if this is the case and spend my medically retired time exclusively on data generated by Amir.
At this point I have to read posts from you on multiple threads, my time and energy is limited and will simply ignore your data until I have clarity.
Relevant post by me, and again, just want to know what you are thinking, it is your work after all.
As you can see this was just a sneak peak while I was modeling an EQ but before getting the speakers, that are currently on my desk.
Nope. Damn If i knew this is an issue I wouldn't have bought them
Edit: Clarified further, see *, as the data I used is data exported by someone else from spinorama.org, not from your website.
If I am still missing something I'd love to hear it but again, I am doing this for fun and I simply don't want there to be any misunderstanding here.
