"Mainly" is nice word to ignore everything below 50 %.
Where'd did you pull that number from?
What pair of speakers, in your experience, cannot generate a 'soundstage'?Quite much but not entirely.
If it's possible for a loudspeaker to get a very high Preference Rating AND be widely disliked in subjective listening tests, then the rating system is broken / flawed. I love the idea of working together here to address this and improve the rating algorithm.
As an experiment, we made two different DSP tunings for the same (fully active) loudspeaker. Tuning A scores a ~6.5 and Tuning B scores a ~9.2. See attached images.
Tuning A has been optimized for the listening window frequency response (green line, second from top).
Tuning B has been optimized for the predicted in-room response & PIR.
So far, 100% of listeners prefer Tuning A.
"Man this just seems more well-behaved all around."
"I am enjoying the spatial stuff. Seems like less confusion with regard to localization of sounds. Lovely."
"I’ve always kind of struggled with the top end, having to toe out to tame it, but this top end seems less glarey!"
Tuning B was described thusly:
"It’s like the presentation is smothered by a blanket. Where’d the treble go?"
"This profile just seems like a Beats by Dre tuning."
"The speaker no longer sounds like a reference for anything, just bass canons and no more top end sparkle."
I definitely think we can make meaningful progress here, as a group. One possible solution for correlating objective measurements with subjective preference ratings would be to build a special "test mule" loudspeaker that we open source / sell kits at cost / sell assembled versions at cost, then get a bunch of us with this same speaker in our homes, and share different DSP tunings.
If this interests folks here, I'd be happy to support this project and design/make the speaker.
Or just stop trying. If you look at the original 13 speakers Olive used, they were QUITE different. We now (for decades) know "flattish" on axis (I.e. neutral) and "relatively smooth" off axis is preferred in blind listening tests. Throw out the "broken" speakers and relish in the multitude of good, but different, speakers we have to choose from and forget the fake "scores"....One possible solution for correlating objective measurements with subjective preference ratings...
I think one obvious problem with this approach is using a "training set" of one loudspeaker to optimize the tuning method is far too limited. We can easily fall into the classic over-fitting situation, where the results are trained to work well only when the specific design details of the training sample are matched....
As we discussed, optimising for the score without constraint will lead to results that do not make sense. This has been discussed extensively on ASR a few years ago.If it's possible for a loudspeaker to get a very high Preference Rating AND be widely disliked in subjective listening tests, then the rating system is broken / flawed. I love the idea of working together here to address this and improve the rating algorithm.
Predicted in-room response optimization is great, but not at the expense of a flat frequency response on-axis (or maybe slightly off-axis for a concentric driver). Ideally you will have both a flat on-axis frequency response and a linear predicted in-room response. I'm not very familiar with the tuning scores, but perhaps they could use some revision as to how they are calculated.Tuning A has been optimized for the listening window frequency response (green line, second from top).
Based on your attached spinoramas, I find it difficult to believe that you have correctly calculated their Olive PR scores to be 6.5 for A and 9.2 for B.If it's possible for a loudspeaker to get a very high Preference Rating AND be widely disliked in subjective listening tests, then the rating system is broken / flawed. I love the idea of working together here to address this and improve the rating algorithm.
Commendable goal, no doubt, but not a 5 min exercise...If it's possible for a loudspeaker to get a very high Preference Rating AND be widely disliked in subjective listening tests, then the rating system is broken / flawed. I love the idea of working together here to address this and improve the rating algorithm.
www.audiosciencereview.com
It does.A point: Vuitixcad does not compute the vanilla Olive score. The designer Kimmosto is around you can ask him.
It does.
You can use Olive's equation 9 in VituixCAD using Ctrl+'Full space'.
You can use Olive's equation 10 in VituixCAD using Shift+'Full space'.
Unselect all Slope targets (SL_).
Although I think he calculates NBD (or something) slightly differently (maybe using a moving average or something rather than fixed windows (I forget)).
@Maiky76@pierre Could you point me to what changes to made to the SM_PIR calculation?
For bass quality spinorama misses compression and distortion for example. Which are really important there.'Dynamics' is mainly a function of the program material. 'Soundstage' is a function of speaker placement and situational acoustics.
I can get a 'soundstage' with even silly little 'desktop' speakers.
"Bass quality"...? what aspect of 'bass quality' do you think a spinorama misses?
As for the rest, *I* wouldn't want a speaker optimized for 'casual listening anywhere' unless it's a portable speaker meant for e.g. beach listening, any more than *I* desire room EQ that optimizes for everyone within a few seats of the MLP (which they tend to do, unless you modify the measuring radius).
Since the data is never available or only as a picture, that's where you all come in and digitize the picture. I promise I will add the data if someone do the data extraction.For bass quality spinorama misses compression and distortion for example. Which are really important there.
