spinorama.org
With the reviewers having NFS it would be shooting themselves on their foot trying to fake measurements only to have the reviews later showing something completely different.
Reviewers don't need an NFS, above 500 Hz anyone can easily measure and check the frequency response with a gated measurement, while it takes more effort and cost for example to dyno a car.
Reactions: MAB
I know, but AFAIK showing consistently measurements on reviews I think there is only Amir and Erin, very rare to find other reviewers using DIY spins weekly or so.
I did install the software as explained and start the jupyter-lab but then i find myself in this environment:
I was expecting to end up on the webpage and be able to add my own speakers to compare them. Is that even possible like this? Or is there another better way to do this?
I am not a programmer so simple steps sometimes escape my understanding ;).
Hi Finn,
the software does not have a visual interface. I may build one since it should be easy to do with Claude or a friend of.
Currently you need to
1. install the software (https://www.spinorama.org/docs/02_install.html)
2. follow the instruction to add a speaker (https://www.spinorama.org/docs/03_metadata.html)
Then run the test
Code:
./scripts/check_meta.py
Then build the website:
Code:
./update_website.sh
it will fail at the end since you dont have the right to copy to dev or production
Generate a local version:
Code:
./generate_html.py --optim --dev --sitedev=http://localhost:8888
and check it in your browser at http://localhost:8888.
If you are on Linux Ubuntu or MacOS it should work out of the box, if not, i can help.
Hi Finn,
Then run the test
Code:
Code:
./update_website.sh
Code:
Thank you! I run this from my local shell as I understand? Why the jupyter-lab then?
Btw: I use wsl2 on windows.
Hi Finn,
Then run the test
Code:
Code:
./update_website.sh
Code:
So i have tried another time.
at least i was not able to execute ./scripts/setup.sh properly. Which i hat to run as "sudo bash setup.sh", my bad for using zsh.
I get: "
up to date, audited 967 packages in 2s
199 packages are looking for funding
run `npm fund` for details
11 vulnerabilities (4 low, 6 moderate, 1 critical)
To address issues that do not require attention, run:
npm audit fix
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
0
running build_ext
copying build/lib.linux-x86_64-cpython-312/c_compute_scores.cpython-312-x86_64-linux-gnu.so ->
ln: failed to create symbolic link 'c_compute_scores.so': File exists
./scripts/setup.sh: line 73: ./scripts/update_3rdparties.sh: No such file or directory"
when I run it from jupyter lab. (It is misspelled as jupiter-lab in the instructions, and needs to be installed)
Do you use jupyter lab for to work from a remote machine?
I get: "
npm audit fix
0
running build_ext
It is almost working. Would you prefer a Docker container to run the software? Maybe that would be easier.
Well I think that would make things a lot easier. I will try with a Alma Linux today and see if that works. Other then that I am just curious how my designs do in comparison. Maybe a upload feature to check ones owns designs would be nice :).
We could add all these speakers to Spinorama) All measured according to the rules of the art
Yes, @Nuyes is sending them to me.
Docker coming soon.
Also an app to do it without being an expert:
A few new stuff which has been requested over time:
  1. an API to get the data easily: https://api.spinorama.org/docs ; it should be self explanatory but if not please ask.
  2. the app to edit the metadata is working and I have successfully use it to add the last 2 speakers from ASR
    1. You can start the app with python src/metaedit/app.py and follow the workflow.
    2. It generated code that is then included in a git PR ready to be pushed to GitHub. That's still not completely obvious to most people and i will make it simpler over time.
    3. I promise to review any PR. Picture upload and measurement upload is still TBD but the metadata are working.
  3. if you add ?plotly=1 to the URL in the speaker view, the browser generates all the graphs on the fly and does not use picture. That's kind of working but not fully. I need to check how old mobiles react to it
  4. there is a working Docker container @Finn
  5. added the usual last speaker measurements
Have fun!
@pierre that is great :). If understand it correctly. I can add a data set with the metadata app. And then run the docker container to check the webpage?
yes locally of course. You cannot push to spinorama.org. If you add your speakers you are very welcome to push the update the GitHub and I will merge it.
When I click on a graph now and then click on the legend to the bottom right to remove some of the graphs, it only allows me to hide or show all (that's what happens no matter what I click on in the legend). Using Chrome.
I used to be able to click on any one of the graphs to hide or show?
Reactions: CJH
Having the same problem and when you unclick (say soundpower or any of the others), all of them disappear--frustrating.
CJH
@pierre,
The price of the recently measured Hsu Research CCB-8 loudspeaker is $389 each, not per pair.
Hello, could you tell us what happened to the slopes for sound power, reflections and their DIs?
It is justifiable that you wouldn't have reference slopes because the research on the subject is lacking, but if there was a way to make it so that we could superpose slopes with our own parameters on the CEA chart that would be very helpful.
On spinorama.org where speaker measurements appear, under the 'Data & EQ' tab in the 'AutomaticEQ (IIR)' section, we find an instruction like this:
Set preamp gain to: -3.0dB.
I am using Rogue Amoeba's Audio Hijack's Parametric EQ plug-in, and I have inserted a Volume plug-in ahead of each PEQ instance. Volume adjustments appear as percentages and not as decibels. A 3 dB drop would reduce a 100% volume setting to 70.7%, so my corresponding volume setting would be 71%, correct?
Thank you for this great resource!
Not necessarily: it depends if the % are linear or not and what it does model.
If it encode amplitude you are correct, if it encode power it could be 50%.
