spinorama.org
@pierre another thought: the EQ graphs are rescaled to align the response with 0dB. It might be useful to skip rescaling to illustrate how much sensitivity is given up for EQ.
Yes but it make it hard to compare them. You can see the preamp gain for the EQ in the EQ file. I can add the value on the graph through.
Also the optimiser is limited to 3dB by default. Most of the time, the pre amp gain is lower than that.
I added the gain (if we have an EQ) in the title.
I hope that I can see the recent measurements by Erin soon, including beloved Revel 126 Be
please petition Erin to send the data to me :)
I did on the FB but I didn't get any response.
I couldn't push too much because I know he is in the tough situation.
At least he started to walk again, and I really hope he's getting happy life again.
I made an update today with
- the latest measurements from ErinsAudioCorner
- changes to the software to speed up the loading of the content (lots of small changes instead of a proper redesign)
Let me know if that breaks on some browsers.
For the IT geeks:
The original idea was to process everything on the browser side and only download static files. Over time the files with the measurement data grew in size and became slow to load. I broke them into pieces and use a service worker to load them asynchronously. LIghthouse is relatively happy. If you want to help to tune the SW and how to do it better, PRs are welcome.
I saw this post claiming that the Edifier MR4 was upgraded: https://www.audiosciencereview.com/...easurements-its-probably-been-upgraded.42941/
Just wanted to let you know, it might be better to update the MR4 EQ, or not.
I would also like to know what's target curve you use for the EQs? Because I extracted the data from the measurements and EQd it to flat target and my MR4s were way brighter than your old and new EQs.
@pierre : will there be a new update with Erin’s and @amirm ‘s latest measurements - perhaps in June?
With google chrome as browser I have no problem to load the Spinorama.org graphs quickly.
Thank you for your work! Speakers are the weakest and therefore the most important part of the chain!
thorsten
If you have a fast connection then yes. A lot of people are still on 3G/slow 4G and then it makes a lot of a difference.
thorsten
Hello all,
I will update the website today. I expect a few things to break that I will try to fix the coming days.
You can have a preview on the dev site: dev.spinorama.org
P.
@Ron Texas
I am guessing I made an error in the link
https://dev.spinorama.org
and not
http://dev.spinorama.org.
P.S.: possibly other errors in my loadbalancer since I changed the config today and I usually dont. I also see some 404s one time over two and that look suspiciously like a miss on 1 of the 2 frontends.
@Ron Texas
and not
P.S.: possibly other errors in my loadbalancer since I changed the config today and I usually dont. I add some 404 one time over two and that look suspiciously like a miss on 1 of the 2 frontends.
Thank you. When I typed in the https address I was able to reach the site.
Hallo,
I am able to reach the side.
Nice, that the bug with the equalized frequency response of the KEF Blade 2 Meta is solved now!
The estimated in-room-response looks now natural.
Thank you!
Thorsten
