analogonly
- Joined
- Oct 8, 2023
- Messages
- 107
- Likes
- 119
How expensive are Rythmik and Speedwoofer in your location?
I don't know about Speedwoofer, but could you import a flat pack from Rythmik?The most expensive there is - not available![]()
If that's in your shortlist, the Ascilab C8C should also be there, they are close in price, both are cardioid, and surprisingly, both speakers are exactly the same size. And even more surprisingly, the Ascilab has a higher air displacement.c) I was also entertaining the idea of active cardioid Buchardt A700 SE
Love mine in a very open and shared space similar to yours.Well yes, in fact I have. As there is a really nice (almost mint condition) used F208 on sale here, for literally half the price of the Kef. However, I’ve been reading up on the wide vs narrow directivity (offerd by the coaxial driver) which should suit me better, as I’m listening music in my sweet spot, 90% of the time. And I should avoid Revel due to wise dispersion and the influence those windows might have on the reflections?
Mind you, this is my layman’s understanding of this, I could be overthinking this altogether… so should I re-consider the F208?
For HT yes but music is 2 channel from a Bluesound NODE USB out to Oppo 205’s DAC (Tidal streaming)With sub/s?
Enjoy! Walnut is gonna be hard, Focal.used to have that venner but the subs were just average. Dynaudio has walnut, but their subs are pricy. I'll try to remember more.Pulled the trigger on a pair of walnut 888s, let's see if they work well enough in my room (and to my preference) to negate the need for subs. If they do - happy camper, if they don't - the search for a pair of nice (maybe walnut?) subs continues...
BK is the best bet. There is also REL Classic 99, but that thing is ridiculously expensive for what it brings to the table - 4k EUR list price, for 2 x 12inch sealed subs at -6 dB at 24Hz.Enjoy! Walnut is gonna be hard, Focal.used to have that venner but the subs were just average. Dynaudio has walnut, but their subs are pricy. I'll try to remember more.
I am sincerely curious to know the amount of people recommending subs who actually integrate them properly. Properly integrating a sub means measuring the sub alone in the room, measuring the speaker alone in the room, then designing a filter allowing sub and speaker to cleanly merge. Electrical low/high pass at the same frequency is better than nothing but very far from the panacea.Definitely need to go with subs.
One practical question, if you’re willing to share your opinion. If you look back at the last page and my room plan with the only potential positions for subs - would it even be worth it? Or would the bass null persist, as they would be on almost the same horizontal plane as the LR speakers?I am sincerely curious to know the amount of people recommending subs who actually integrate them properly. Properly integrating a sub means measuring the sub alone in the room, measuring the speaker alone in the room, then designing a filter allowing sub and speaker to cleanly merge. Electrical low/high pass at the same frequency is better than nothing but very far from the panacea.
If you are ready to jump into the room EQ rabbit hole, which I recommend, @OCA has some very nice videos https://www.youtube.com/@ocaudiophile.
Try 1/4 of the way up the side walls. A measurement mic and REW can simulate speaker and sub placement FWIW.I think this is the only way to get rid of that bass null. If you know a better, or cheaper way, please share
Been playing with placement, moved them further back towards the front wall - better, but not as good as I stand up.
So frustrating, when I get up and walk around the room, the bass is ALL THERE. But when I sit down, 20%-30% of it dissapears.
I just did, in the last line of my commentIf you know a better, or cheaper way, please share
Not impossibleOr would the bass null persist
He wasn't arguing against subs. He was arguing for proper sub integration. And shared a method:I think this is the only way to get rid of that bass null. If you know a better, or cheaper way, please share![]()
Seems from OP's description, the integration isn't sorted out.Properly integrating a sub means measuring the sub alone in the room, measuring the speaker alone in the room, then designing a filter allowing sub and speaker to cleanly merge. Electrical low/high pass at the same frequency is better than nothing but very far from the panacea.
