Here are measurements of the Andersson HIS 2.1 / Pure Acoustics Supernova center speaker.
It was purchased new by me 11 years ago, for ~19 USD (199 SEK).
Andersson is an old Swedish brand that used to make radios, but these days it's just bottom of the barrel OEM.
This center was also sold under the name Pure Acoustics:
www.pure-acoustics.com
I measured at 10 deg increments, using a homemade speaker turntable.
It might look like I forgot to correct the bass response, but I didn't:
As expected with a MTM design, the horizontal directivity is bad, but this one takes it to another level. It might be possessed:
It's probably not a surprise looking at the measurements, but it sounds horrible. It's almost comically bad, with a very boxy/muffled sound anywhere except right in front of the tweeter.
I tried to "fix" it with EQ, but it's no use. You can get rid of the huge bass peak, but everything else just changes depending on where you sit.
I have attached two recordings, 30cm from the tweeter (best case scenario) with and without EQ.
Teardown:
Dual baffle, piano finish and a detachable grille, all for the price of a McDonalds meal with dessert.
Steel bolts. Maybe Danny Richie can turn it into a hifi-speaker by replacing them with tube connectors.
Supernova C - Pure Acoustics
Looking for Supernova C ? Here in Pure Acoustics you can find Supernova C in high quality. For more details, visit our website.
Teardown:
