incaseoftrouble
- Joined
- May 28, 2026
- Messages
- 3
- Likes
- 1
Hi all,
I get the point of not EQing high frequencies based on in-room / steady-state frequency response, but after reading through Dr. Toole's "Sound Reproduction" (fantastic book, highly recommended!) I also see that applying PEQ based on aneonic / spinorama measurements might be a good idea. A1 Evo AcoustiX offers the possibility to apply custom filters, but only after alignment with the subwoofer.
To my understanding, it would make sense to apply the full range of spinorama measurements but attenuate their effects below the transition range. For example, my Q3 Meta have a suggested PK filter at 52 Hz with 0.25 Q - this has a notable influence well into the HF range. But I don't want to add the filter afterwards, as that would mess with level matching and subwoofer alignment. (I want to EQ the speaker, not the final signal)
I did try to "trick" acoustiX by replacing the measured response with an EQd response in the "custom time alignment" step, but the filters are applied to the full range signal, meaning my subwoofer response is actually boosted slightly if I use the entire suggested AutoEQ.
I guess what would be really cool is a "speaker-EQ" mode, where you can add filters that are applied to the measurement before processing, but these filters then are also incorporated into the final filter chain, attenuated by crossover etc. -- basically acting like having an extra amp with these filters between the AVR and the speakers. I understand this would be yet another feature, but there is strong science to back it up.
Does anyone have experience with this?
EDIT: To clarify, I am not asking whether using spinorama data for EQ makes sense (I am rather convinced of it), rather how to best integrate it in the EQ workflow.
