materialbasis
- Joined
- Dec 16, 2025
- Messages
- 17
- Likes
- 8
Hello all!
I recently picked up a pair of speakers I've wanted for quite some time, a pair of Dunlavy SC-III speakers. The upper mid to lower high range frequencies sound unbearably harsh. They didn't sound this way when I picked them up, given I did not listen to them for a long time. I'm trying to rule out if there is something wrong with the speakers themselves, or maybe my environment is just seriously hard for them to work with? I was running Goldenear Triton 5 speakers before in the same spot, which had the opposite issue, the upper mid/highs were pretty recessed.
I tried changing amplification from a Peachtree Nova150 to an Arcam Radia A25+, did not change much on the front of harshness. I decided to run some pretty amateur measurements, and they seem to confirm what I am hearing.
I did a few sweeps from listening position. I'm using a Dayton Audio IMM-6C, via HouseCurve, using a the calibration file for my specific mic. I also tested using my iPhone's internal mic, similar pattern just at different db levels. So I'm pretty confident in this measurement, unless both the Dayton and iPhone have terribly fucked up mics.
Would I be able to detect something wrong with the drivers from a measurement from listening position? I ran the same tests using one speaker at a time and they look to be relatively the same, so it wouldn't be an issue with one speaker. Are there other tests I should run?
Speakers are around 6 feet apart, listening position is 10 feet away (I know, not ideal.) Speakers are toed in to where I can hardly see the inner panel. I tried changing the position of the speakers, away from the windows and without sidewalls being an issue. The harshness persisted. The speakers were about 8 feet apart, and I was listening from about 8 feet away. I also tried putting some blankets behind the speakers when they were by the windows, it seemed to take down the harshness by 1 or 2 DB but not nearly enough. At its worst, around 2-4k, it's 9db too high.
The details in music sound great, staging is good given the position, I don't necessarily hear obvious distortion. I've checked each speaker individually (except for tweeters). No coil rub, no separation at the spider, tinsels look good. Each speaker seems to be producing sound, none of them appear to be completely dead.
I'm kind of at a loss with these, I've never had to try so hard to get speakers to sound right. Should I have someone come in and test the drivers in a more serious fashion? Could it be a crossover issue? I'm thinking about moving on from these but I'd hate to sell them not knowing if something is wrong with them.
sidewall_stereo.png - both speakers measured at same time
no_sidewalls_stereo.png - measured from new position, without sidewalls being nearby
sidewall_separate - more prominent green is left side, faded green is right. Right side is closer to corner, explaining the different bass response
If folks would like, I can attach a zip with the WAV impulse responses.
